Rain in Jeep causing electric problems. - JeepForum.com
post #1 of 3 Old 07-10-2010, 09:30 AM Thread Starter
sburton1
Well let my top down yesterday and the jeep got drenched, I pulled the floor plugs and went to start it and I got a engine light. I let her dry out over night and she's sputtering and running like crap. I can hear the turn signal sylinoind constantly clicking too. Any ideas do you think she will dry out and be ok or did I fry some thing?
sburton1 is offline
post #2 of 3 Old 07-10-2010, 10:41 AM
NonRubicon
Have you pulled the code to see what popped up? I'd do that first.
Sounds like the steering column got soaked real good. I'd check out the ignition switch as the culprit for your running issues - it may still be wet or could have been damaged.
NonRubicon is offline
post #3 of 3 Old 07-10-2010, 10:43 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Fresh water rarely harms low voltage electrical circuits. I'd bet a dollar everything will be fine and as before once you give it a few days to completely dry out. Mine would do the same thing when I would power wash the engine compartment but once it dried out, it was fine.
Jerry Bransford is online now
rain , tj , wrangler , electric , electrical , problem , turn signal , clicking
New LCA brackets, causing problems Howland TJ Wrangler Technical Forum 3 11-06-2009 08:08 PM
short in rocklights causing other problems. xjgnar TJ Wrangler Technical Forum 4 09-14-2008 04:19 PM
ac causing problems- why is my ac causing my jeep to cut off cvaria TJ Wrangler Technical Forum 6 08-07-2007 09:42 AM
Ice buildup causing problems Korruptor TJ Wrangler Technical Forum 8 12-06-2006 10:46 AM
Rain Soaked Jeep Problems??? Don G. TJ Wrangler Technical Forum 15 04-27-2006 03:42 PM
