radio shuts off while driving - JeepForum.com
post #1 of 10 Old 07-24-2009, 06:12 PM Thread Starter
incagoldjeep
i have the factory cd player and sometimes when im driving and listening to music the music stops and the lights for the cd player turn off so i pulled over turned off the jeep and turned it back on and the cd player is working again except it didnt start off from where it stopped it was like the cd player was still playing but it just turned off idk??? anyone have any suggestions?
incagoldjeep is offline
post #2 of 10 Old 07-24-2009, 06:16 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
Loose ground strap maybe between head and body on the rear of radio?Does the radio lite remain lit when this happens?
GOLENJEEPTJ is offline
post #3 of 10 Old 07-24-2009, 07:03 PM
MisfitSeven
MAiL Crawler.
MisfitSeven's Avatar
this happened to me all the time with my 98. whenever i hit the turn signal it would turn the radio off, then would come on again. the ground strap on the back was solid, but bad. so i had to run a ground wire out to my engine bay on the firewall, then to the negative terminal on the battery. havent had a problem since.
on a side note, it would send my battery gauge to 14 in the red. weird.
Mail crawling.
MisfitSeven is offline
post #4 of 10 Old 07-24-2009, 07:08 PM
armymedic
How much weight do you have on the key ring. Try this start the jeep, turn on the radio with the jeep running pull out on the key slightly if the radio shuts off switch is getting loose. I only run the ignition key on the ring and never have the problem but if i pull on the key it will shut off the radio.
armymedic is offline
post #5 of 10 Old 07-24-2009, 07:15 PM
F9K9
F9K9's Avatar
Yep. a worn key will do this and much more. Jiggle it and see if, it comes back to life then, pay the stealershio to recut a key(s) by your VIN. Solved my radio and fuel guage acting up.
For those who have fought for it, FREEDOM has a taste that the protected will never know."
'03 Rubicon w/a few changes.
F9K9 is offline
post #6 of 10 Old 07-24-2009, 08:28 PM Thread Starter
incagoldjeep
thanks ill try that now
post #7 of 10 Old 07-24-2009, 08:32 PM Thread Starter
incagoldjeep
ok the key comes out a little bit and the radio turns off. so how much would it cost to make a new key from the dealership? also my key doesnt need to be programed so do i have to go to the dealership or can i just go to the locksmith?
post #8 of 10 Old 07-24-2009, 08:39 PM
WahooCreek
If it is the black key, go to a locksmith, hardware store or any other place that makes keys.
WahooCreek is offline
post #9 of 10 Old 07-24-2009, 08:52 PM Thread Starter
incagoldjeep
yea it is a black key. how much would it cost? a rough price range?
post #10 of 10 Old 07-24-2009, 09:15 PM
JMayer
Just a couple bucks to cut a key, like any other really. It's the gray Sentry keys that are a pain if you don't have a pair of them to program the new one.
JMayer is offline
Jeep shuts off while driving, HELP PLEASE! Huge mystery! Apollo12227 YJ Wrangler Technical Forum 92 03-14-2014 07:26 AM
Radio is cutting out while driving leedurr YJ Wrangler Technical Forum 1 04-28-2009 06:50 PM
My GIG radio/nav screen cut out while driving tcc11tcc JK Wrangler Technical Forum 8 02-02-2009 02:10 PM
Help! Jeep just shuts off when driving. Crymsun YJ Wrangler Technical Forum 4 09-17-2004 12:14 PM
engine shuts down while driving jamesscott YJ Wrangler Technical Forum 5 02-03-2002 01:13 PM
