Radiator Replacement - What WORKED? - Page 4 - JeepForum.com
post #46 of 62 Old 04-08-2012, 05:04 PM
DevilDogDoc
Now there's a pretty boy, where is it made? How many rows? Looks pretty close to that fan clutch so I am guessing it's thicker?
An ugly Jeep with some stuff.
DevilDogDoc is offline
post #47 of 62 Old 04-08-2012, 05:16 PM
freeskier93
Originally Posted by yoshi280zx
It's the metal hose coming FROM the water-pump that runs back to the firewall. Mine was seized to the pump, so had to be replaced. Unfortunately, it's a dealer-only part. Cost about $20...
It's the water pump inlet tube and costs about 10$ at the auto parts store.
freeskier93 is online now
post #48 of 62 Old 04-08-2012, 06:07 PM
paulyboy
2 row not sure where its made probably china like everything else we get.
paulyboy is offline
post #49 of 62 Old 04-08-2012, 06:33 PM
DevilDogDoc
Aw thats a shame, looks nice though! Side tanks huh?
post #50 of 62 Old 04-08-2012, 07:34 PM
paulyboy
yeah i have an external trans cooler so i might make the one side into a power steering cooler . Well I figured it was a risk as some other brands that come from china have horrible quality but from the reviews and research cxracing has a good track record for reliability and quality.
paulyboy is offline
post #51 of 62 Old 04-08-2012, 07:35 PM
paulyboy
and i couldnt say no it looks so pretty and shinny lol
paulyboy is offline
post #52 of 62 Old 04-08-2012, 08:34 PM
LARSONEM
NAPA carries that part too. http://www.napaonline.com/Catalog/Ca...(P_RecType%3aA)
$10.80
Eric Larson
1997 Red Wrangler 4.0L - 5 speed - soft top w/full frame doors - 2 inch spring spacers and 1 inch body lift - 31 x 10.50 BFG on 15 x 8 Pro Comp 8069 rims
LARSONEM is offline
post #53 of 62 Old 04-08-2012, 10:29 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
$10.80
Also know as Heater Hose...
Knuckelhead is offline
post #54 of 62 Old 04-08-2012, 10:35 PM
freeskier93
It's an actual metal tube that's threaded into the water pump, and you have to know the specific name "water pump inlet tube" otherwise the parts monkey behind the counter will never find it/know what you're talking about.
That tube is there for a very good reason, without it you would have to remove the belt and idler pulley to remove the heater hose from the water pump. Ask me how I know because when I replaced the factory water pump the tube was not coming off and none of the parts stores around me had them in stock. So I got a threaded fitting and a new length of heater hose to run it to the water pump. The clamp just barely fits behind the idler pulley and to remove the clamp the belt and idler pulley has to come off.
There's my diatribe for the day.
post #55 of 62 Old 04-08-2012, 10:58 PM
chadsmeltzer
chadsmeltzer's Avatar
I bought a cheap all aluminum one, it leaked the first time I installed it and the radiator cap has never seated correctly. You get what you pay for, and at the time it was all I had money for and could get it fast.
Edit: Just went looking and found it was a Silla.
04 TJ - 2 KC Daylighters, 35x12.5x15 MT/R Kevlar, 3" coils, Rear 4 link, 1.25" JKS BL, 1" JKS BMML, 33 Eng. Hi-Clearance Skid, 8.8 with LS, D30 EZ locker, OBA
chadsmeltzer is offline
post #56 of 62 Old 04-08-2012, 11:43 PM
paulyboy
you know the brand? cx racing has 90 days Anti-leak Warranty on Intercoolers, Radiators,
paulyboy is offline
post #57 of 62 Old 04-09-2012, 12:02 AM
Knuckelhead
AFSOC Retired
And it's not a bypass hose...
post #58 of 62 Old 04-09-2012, 08:06 AM Thread Starter
yoshi280zx
Originally Posted by paulyboy View Post
just got a cx racing all aluminum rad for my zj . My friend who is a certified mechanic and race car builder said his partner uses them in his crx for years with no problems at all racing on the track. I only installed mine the other day but the normal operating tem has dropped about 20 deg. It looked good and only cost 30 dollars more then the factory. If the factory had made the radiator with metal end tanks then they wouldn't be so prone to burst out. Why i replaced mine. Best part it fit perfectly with 0 modification to it.
She's a beauty! $160 with shipping isn't bad at all. I need to check if they have one with the oil cooler lines at the bottom...
James Johnson
1997 Jeep TJ Sport -
1998 Dodge 3500 12V -
1980 280ZX AE -
Follow me on Twitter! @johnsonjamesy
yoshi280zx is offline
post #59 of 62 Old 04-09-2012, 08:09 AM Thread Starter
yoshi280zx
Good info. Weird, because the catalogs at the parts store called it a "bypass hose." They would find the part, show me the picture and then tell me they couldn't even order it. This happened about 4 times before I went to the dealer. Didn't try NAPA, though...
Looking at the receipt now from the dealer and it's listed as a "water-tube." Oh well, I'll now know if I ever need one again... Lesson learned.
James Johnson
1980 280ZX AE -
post #60 of 62 Old 04-09-2012, 11:42 AM Thread Starter
yoshi280zx
Originally Posted by Idaho-Jeep
I purchased this Silla all aluminum radiator Was more than a new stock one but not by much and does not have the plastic top and bottom which have failed a few guys I know of. Out of the box.
The new radiator had two additional lines at the bottom (see photo above) that my stock one did not... These are lines used for cooling automatic transmission fluid. I have a manual so I have no use for them.
Do you remember part number? 2102-AA, 1682-AA?
James Johnson
1980 280ZX AE -
radiator , replacement , tj
replacement radiator, 4 and 6 cyl the same? muddy93 YJ Wrangler Technical Forum 5 01-19-2010 03:12 PM
Radiator replacement vbguru12000 TJ Wrangler Technical Forum 4 12-13-2008 02:35 PM
Radiator Replacement myember YJ Wrangler Technical Forum 20 08-03-2005 01:29 PM
radiator replacement illinijeepster YJ Wrangler Technical Forum 1 12-25-2004 08:31 AM
Radiator replacement? wilyliam YJ Wrangler Technical Forum 12 09-17-2003 08:40 PM
