Quantcast radiator recommendation??? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > radiator recommendation???
Old 09-29-2009, 05:02 PM   #1
robtre
2005 TJ 43K miles radiator failed today I want a GREAT replacement.......
His:2005 Wrangler Rocky Mountain Edition
Hers:2005 Grand Cherokee Laredo
robtre is offline   Reply With Quote
Old 09-29-2009, 05:17 PM   #2
robtre
anyone please im in a bad spot here
Old 09-29-2009, 07:17 PM   #3
Pyle-it
champion 3 row alluminium is my recomendation
Pyle-it is offline   Reply With Quote
Old 09-29-2009, 07:26 PM   #4
pdangerp
pdangerp's Avatar
For those of you purchasing an aftermarket radiator, I'm in the same boat and wonder about how they are mounted? Does everything mount back in the same, or do you have to drill into things and make your own brackets?
pdangerp is offline   Reply With Quote
Old 09-29-2009, 09:11 PM   #5
Thunderstrike
Thunderstrike's Avatar
2009 JK Wrangler
http://www.jeepforum.com/forum/f9/what-did-you-do-your-tj-today-236432/index1102.html#post6622457
See the post about aluminum radiator. Around $135.
Fast Radiator FAS-2102AA
2009 JK Rubicon.
Auto, Skid Row Engine Skid, Lower Control Arm skid & Evaporator Skid; Rock Hard Gas Tank Skid; Warn Stainless Steel Differential Skid Front & Rear; 11,000# Pull-Pal, Uniden 520XL CB with 3' FireStik Whip.
Shrockworks Mid-width Front Bumper with Warn 9.5Ti -- Ordered 7/17/2009; Bumper Received 12/4/2009.
Visit here to view my wheeling Pics: Moab-4/2006, 5/2008, 4/2009, 5/2011; Ouray-8/2007, Rubicon-9/2008.
http://community.webshots.com/user/thunder1strike
Thunderstrike is offline   Reply With Quote
Old 09-29-2009, 11:28 PM   #6
pdangerp
pdangerp's Avatar
I found Radiator.com and I've read a couple of good things about their speed and customer service. I'm probably going to call them when they're open tomorrow.
Old 09-30-2009, 03:02 AM   #7
fatcop
I picked mine up from O'Reilleys and it went right in with no issues with fastenings.
fatcop is offline   Reply With Quote
Old 09-30-2009, 06:33 AM   #8
mikes3860
Need radiator
Check out Auto Parts Fast at RockAuto
Several listed you can make the decision on which one you want.
mikes3860 is offline   Reply With Quote
Old 09-30-2009, 07:15 AM   #9
Knuckelhead
Knuckelhead's Avatar
That's by far the low end of radiators. You can do better...IMO
Originally Posted by Yucca-man View Post
My experience is that poly loves to groan
Knuckelhead is offline   Reply With Quote
Old 09-30-2009, 07:28 AM   #10
finsout
I did what many have done on here and got a 2 row from radiator barn (all metal). no problems at all with installing it. Just bolt right in. I think all told it took about 30 minutes.
my only piece of advice would be to make sure you don't get one of the plastic OEM replacements. go all metal.
finsout is offline   Reply With Quote
Old 09-30-2009, 08:01 AM   #11
robtre
you guys are great!!! Thanks
Glock Forum
