radiator exploded - JeepForum.com
post #1 of 9 Old 07-27-2010, 09:06 PM Thread Starter
khill8469
radiator exploded
So my jeep was parked and running all of a sudden i heard pop and steam comming from the antifreeze was comming out. i ran to the jeep and shut it off and let it cool off i check the oil and no antifreeze was in the oil then i saw the top of the radidiator blew apart at the 90 degree bend. about 12 inches. the antifreeze overflow was never boiling. now im not sure if my motor is any good. the radiator is a month old. what would cause this. i can get pictures tomorrow night.
khill8469 is offline
post #2 of 9 Old 07-27-2010, 09:12 PM
chris142
How is the rubber on the Radiator cap? If it's swelled out it will act like a cork and wont release pressure which will blow up the radiator. A stock radiator cap is 18psi.......Thats alot of pressure for the plastic tanks to hold back. I see no reason to use more than 13psi caps myself.
Did the manufacturer forget to drill the vent hole where the overflow hose goes?
chris142 is offline
post #3 of 9 Old 07-27-2010, 09:22 PM Thread Starter
khill8469
i put a new cap on when i did the radiator a month ago. and i think the the drill vent is fine. so i dont know what would of casused this. if my motor died i wonder if i can get the place where i got the radiator from to cover it through their insurance.
post #4 of 9 Old 07-28-2010, 04:00 AM
blubaru2002
I don't think your motor is going to just die.
You most likely had a bunch of air introduced into your coolant system when you replaced your radiator. Did you burp the air out of the coolant system properly after you installed the radiator and new cap?
There are a few threads on here about this.
Originally Posted by Patrick Bateman
I have to return some video tapes.
blubaru2002 is offline
post #5 of 9 Old 07-28-2010, 02:15 PM Thread Starter
khill8469
its been running fine for 6 weeks without any trouble. then all off a sudden bang. now the stupid place said i need the recipt to get a new radiator and i cant find it.
post #6 of 9 Old 07-28-2010, 02:44 PM
MisfitSeven
MAiL Crawler.
MisfitSeven's Avatar
maybe your thermostat is stuck closed? maybe you got some crud build up in there and it is clogging the thermostat?
Mail crawling.
MisfitSeven is offline
post #7 of 9 Old 07-28-2010, 02:49 PM
hatfield44
A file cabinet can be your best friend
hatfield44 is offline
post #8 of 9 Old 07-28-2010, 02:52 PM
wtroger
Sounds like a defective radiator or radiator cap. Seen it before both ways. Even if for some reason the engine did get hot it should have just trip the rad cap not split the radiator.
wtroger is offline
post #9 of 9 Old 07-28-2010, 03:10 PM
wushaw
Rockin jeep
wushaw's Avatar
I agree.
wushaw is offline
radiator
dana 35 exploded, what to do neil11 TJ Wrangler Technical Forum 20 12-06-2009 10:55 AM
Changed Radiator Cap. My Radiator EXPLODED blubaru2002 TJ Wrangler Technical Forum 8 08-11-2009 04:42 PM
d30 exploded JohnAxis TJ Wrangler Technical Forum 13 05-01-2008 02:31 PM
CAT EXPLODED. Help? MaineYJ YJ Wrangler Technical Forum 5 02-10-2006 08:13 PM
My radiator EXPLODED! WAMPAROO TJ Wrangler Technical Forum 18 12-05-2005 07:07 PM
