#1 | |
Radiator and an a/c recharge?
So I discovered a fairly sizable puddle of green in the driveway and to the shop she went. They said my radiator's bad and they also said that they have to recharge my a/c along with the new radiator install. Is this true? I didn't think that would have to be done after replacing a radiator.
#2 |
no a/c work needed, maybe do it yourself it's very easy, they are padding the bill.
2004 WJ 4.0 limited "I'LL TAKE A COLD INTERIOR OVER CLADDING" Still have heated seats! 2008 Ranger, 2003 Powerstroke lariat straight pipe tuned, 2000 TJ Sport, leaky stak 3 speed and bunch of other stuff that i don't care to add up. |
#3 | |
You can replace the radiator as it has no bearing on the A/C as replacement. The A/C may be low on R134A refrigerant and need recharging. I would get the rad. changed first and wait for warmer weather.
2000 Sport. |
#4 |
I was going to do it myself, but they said something about the a/c needing a recharge and that I shouldn't do that myself, which I agree with.
#5 |
If it's just recharging the AC, that's a cinch to do yourself.
#6 |
Yup. Piece of cake, all you need is a gauge and a can. They sell kits, and they're pretty cheap.
Blue Jeep Club Member #197 '02 TJ - 31" BFG AT's, some armor, yadda yadda. 2" BDS lift. '94 ZJ - May it rest in pieces. |
#7 |
You have ac
. You can most likely do fix on your own if you are up to it.
1997 TJ with 4.5 Rubicon Express lift, Warn winch, sliders, 8.8, 5.7L LS1 V8, MTI X1 cam, long tube headers, tune, and a 4L60E. |
#8 |
The faux feather finish
They are fishin for $$$. You don't need to pull the A/C condenser out for the radiator on a 2000 (or any of them I think). Like the others said, pick up a can of r-134a and swap the radiator yourself. It's an Saturday afternoon job with lots of time for beer.
2000greenTJ 1954 CJ3B "...Indeed I have burned the candle at both ends, and it gave off such a glorious light..." - Christopher Hitchens tales from the bard side |
#9 |
I've never had to pull the A/C condenser on any vehicle I've swapped the radiator on, including my TJ. Some have been a bit tight, but I haven't had to take an A/C line loose yet...knock on wood.
Swapping the radiator in a TJ is pretty easy. If I remember right, there are a couple of bolts that can be tricky to get to, but otherwise it is pretty straightforward. Go ahead and replace the hoses and thermostat while you have everything apart. |
#10 |
So what you're saying is that taking the condenser off the old radiator and putting it on the new one requires no interruption of the refrigerant in the a/c lines? And that they're just trying to get money from me by saying that it will?
#11 |
Pretty descriptive write up here.
http://www.dailydriventj.com/forum/viewtopic.php?t=618 Hope this helps. Jeff |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
