#1 | |
Radiator
Well, I'm finally going to have to replace my Jeep's radiator. It's a 97 TJ (6 cylinder) with 128k+ miles. From what I've read on this forum, I consider myself very lucky that the original radiator has made it this far. Anyway, I think I know which replacement radiator I'm going to go with, but I was wondering if I should replace the hoses too while I have everything apart. The hoses are the originals too and while they look fine from the outside, breaking down on the side of the road with a busted radiator hose is the last thing I want to happen. Does anyone have any advice on if I should worry about installing new hoses while I have the radiator out? If so, where's the best plase to buy the hoses? Thanks
#2 |
at 128K it could not hurt, but if you are short on cash, then I think that the lower hose is more likely to fail. just my opinion
#3 |
I went through the same process (97 TJ, 115k) and I bought new hoses initially, but returned them because when I replaced the radiator, the hoses were still fresh. If money is no object replace them and the thermostat too (the "while you're at it" theory). You can get hoses at any auto parts store.
'08 Unlimited Rubicon totally stock '97 Sport Canadian TJ, 4.0L, AX-15, D30/35, 4.10/4.11, Powr-Lok/Trac-Lok, Superwinch EPi 9.0, 2.5" JKS ACOS, DT-3000, 31x10.50-15 Cooper Discoverer STT on black steelies, O-R Fab sport bar, Jeeperman skidz and bumpers |
#4 |
Money is a factor right now, so I think I may wait a while to do the hoses.
#5 |
At that age/miles, I would do the hoses without a doubt, and thermostat for what they cost. Also a good time to do your belt if it hasen't been replaced recently.
#6 | |
#7 |
Do it right or not at all
![]() Join Date: Jan 2003
With that many miles, you really should replace all the hoses. There are four that are in the radiator cooling system. Upper and lower radiator hoses, and the two hoses leading to the heater. Note those two heater hoses are two different sizes. Any one of the four blowing would cause you to lose all your coolant.
Gone to King of the Hammers, back Sunday! Jerry's Geezer Jeep II Website Getting Savvy... Coolest offroad magazine ever! CRAWL Magazine When you have a choice, buy American.
#8 |
I agree, replace the hoses. It is far easier to replace them with the radiator out. Plus, you have to drain the coolant to change the radiator anyway. two hoses are what $20? What's it worth to you if you blow it on the highway or trail? save the old ones and keep them with you on a trail ride.
-mpyusko _________ '97 SE Black, 4cyl/5spd, Soft top, Jeeperman Rear Bumper, 33x12.5x15 Trxus M/T's, 4" Lift, 1" JKS MML BLACK JEEP Club V2.0 #84 Rust-Bucket Build-Ups Club Member #1 Pictures of my JeepSAVE PARAGON AP!! |
#9 |
def replace them!!
#10 | |
#11 |
I just did this exact job two weeks ago. New radiator (2-row)- $160 shipped from www.radiatorbarn.com, plus $16 ($8 each) for the upper & lower hoses. I also replaced some of the mounting hardware for the radiator- easy to find the nut clips at VIP Auto, new clips & bolts was under $10. My only piece of advice is to really crank down when tightening the hose clamps- mine leaked the next day because they were not tight enough. Good luck-
T |
#12 |
Sometimes hoses that old need to be cut off, so its nice to have new ones on hand. Also a good time to check that water pump while you have the extra room. If the raditor leak is pretty small still, you might get by another week or 2 to get some cash together, not that I would really reccomend waiting.
#13 |
hoses r cheap u will need to replace themm..i have 155k on my motor and the stock radiator from what i can tell n its from 88 n its running like a champ..i check the fluid every week from when it gets cold and no rust or anything
#14 | |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
