Quick question TC drop - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Quick question TC drop
Stainless Steel Door Hinge PinsPoly Door Hinge BushingsDual Color LED Light Bars White/Amber
Unread 02-04-2014, 09:50 AM   #1
cole_slaww
I have a 2002 wrangler. I am at school and do not have access to any tools. I had a shop put in a new clutch for me a while back and I figured that they might as well put in the TC drop kit that came with my lift that I never bothered putting on. When they installed the spacers however, they did not loosen up the trans mounting bolts. Thsi has caused the shifter boot to bind up. I have been researching and I found one guy that said to loosen the bolts, but do not remove them. Then drive around real quick and then tighten the bolts. Would this be the correct thing to do?
Thanks
cole_slaww is offline   Reply With Quote
Unread 02-04-2014, 10:03 AM   #2
JBTJ
JEEPer For Life
JBTJ's Avatar
Before the TC drop was installed, did you have any driveline vibrations?
JBTJ is offline   Reply With Quote
Unread 02-04-2014, 10:54 AM   #3
cole_slaww
Yes I had vibes in 2nd gear pretty bad.
Unread 02-04-2014, 11:12 AM   #4
TheBoogieman
Demonic Jeep Freak!
TheBoogieman's Avatar
Just loosen the bolts a little and drive it for a couple minutes.
TheBoogieman is offline   Reply With Quote
Unread 02-04-2014, 11:37 AM   #5
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
have a friend take you, or ride the bus, down to the local harbor freight so you can buy this:
http://www.harborfreight.com/105-pie...est-69380.html
or better yet, go to sears and buy this:
http://www.sears.com/craftsman-182-p...a=00933182000P
loosen the bolts, then grab the roll bar and shake/rock the jeep as hard as you can. retighten the bolts and you're done. you don't have to go driving, and you can comfortably reinstate your man card.
Unlimited04 is offline   Reply With Quote
Unread 02-04-2014, 11:56 PM   #6
cole_slaww
Thank you so much guys. Will give this a try tomorrow.
