QUICK QUESTION: Rear Bump Cup & Spacer.. (already unmounted the springs and parked). - JeepForum.com
post #1 of 4 Old 04-25-2001, 12:47 PM Thread Starter
ak47
I am trying to install the Teraflex budget boost 1.5". I installed the front
and took out the factory spacer which were about 1/2" and left the stocks
original.
Now the rear was little different, it did not have a thick spacer, only a
rubber type of pad,. The bump cup was little different setup,
MY QUESTION IS: Do I insert the bump cup (stop) into the spacer or do i just
leave the bump cup underneath the spacer, please advise, (jeep is parked in
garage lifted with axle down, and waiting for response).
thanks
also, should I am thinking about putting the 1/2" spacer back in the front,
also or should I just leave it out, since I am not using longer shocks.
thanks
ak47 is offline
post #2 of 4 Old 04-25-2001, 02:03 PM
Tonka
2015 JK Wrangler
I can tell you that leaving the stock spacer in will result in more lift. you will be somewhat limited on travel with the stock shocks. Sorry I cant help with the rear.
most auto parts stores sell shock extenders
98 TJ
90 MJ short bed converted to 4x4
90 XJ 2 dr 4x4
Tonka is offline
post #3 of 4 Old 04-25-2001, 04:37 PM
jeepersandcreepers
the Tera spacer 1.5 spacer lift will work with the stock shocks. As for the rear spacer, remove the rubber bump stop, unbolt the cup, install spacer, install bump stop (using new longer bolt)and cup and reinstall rubber bumpstop.
If you have questions, give me a call at
415-387-2323
We are a TeraFlex dealer
James
jeepersandcreepers is offline
post #4 of 4 Old 04-25-2001, 07:31 PM
Real-LD
Probably to late but leave the stock stops on. And yea you insert the cup into spacer before you install it back on the Jeep. Don't worry about the shocks, you can survive on the stock ones until you have money for longer travel shocks.
Rock out with your crack out and call me monkey boy.
Peace
Lar-re D.
97 Tj not so stock but not so modified.
Real-LD is offline
bump stop , teraflex
Fuel Pump looses Pressure when parked - possible quick / cheap fix? Oman Jeep TJ Wrangler Technical Forum 7 03-17-2009 08:03 AM
Quick newb coil spacer question! 97casteeltj TJ Wrangler Technical Forum 10 11-12-2008 08:41 PM
So the lift is on...quick question on putting a spacer in the front. Ford4Now TJ Wrangler Technical Forum 8 05-07-2007 06:28 PM
2in lift,how to mount rear spacer & bump stop motor12 TJ Wrangler Technical Forum 3 03-20-2005 06:55 PM
quick spacer/shock question TONKATJ TJ Wrangler Technical Forum 2 10-01-2003 04:50 PM
