Quantcast quick plz! installing cat back, cant squeeze tail pipe through - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > quick plz! installing cat back, cant squeeze tail pipe through
Old 08-20-2008, 04:08 PM   #1
alecmcmahon
alecmcmahon's Avatar
hey guys, hoping for a quick response here,
in the middle of installing dynomax cat back, and im having issues trying to find a way to get the tail pipe through, in one peice.
for those who have done this can you offer any advice?
99 TJ 2.5L
thanks!
- Alec
edit, btw i am doing this in my drive way with a simple floor jack, goes up to about 15" or so.
-my build thread-
alecmcmahon is offline   Reply With Quote
Old 08-20-2008, 04:41 PM   #2
paulthejeeper
What part of the Jeep are you jacking up??? Place the jack forward of the rear dif on the passenger side and jack until just before the tire come off the ground... This should give you enough space between the body and axle... Use a block under your jack if its not tall enough... And of course, safety first, chock the tires and pull EB....
Yeah I take it offroad...my scratches have scratches!!!
[SIZE="2"][/SIZE]03 [COLOR="Silver"]BRIGHT SILVER METALLIC,[/COLOR]TJ,
4.0, auto,
4" rough country lift,
33" baja claws,
black 15" crawler rims,
more mods as budget allows...
[SIZE="5"]J[SIZE="2"]UST [SIZE="5"]E[SIZE="2"]MPTY [SIZE="5"]E[SIZE="2"]VERY [SIZE="5"]P[SIZE="2"]OCKET[/SIZE][/SIZE][/SIZE][/SIZE][/SIZE][/SIZE][/SIZE][/SIZE]
[U][COLOR="Blue"]USN JEEP CLUB MEMBER HULL#61[/COLOR][/U]
[COLOR="Silver"][U]BRIGHT SILVER METALLIC JEEP CLUB MEMBER #61[/U][/COLOR]
paulthejeeper is offline   Reply With Quote
Old 08-20-2008, 04:46 PM   #3
Chewie4299
I had a similar problem....
I jacked up under the rear bumper with a big block of wood till the axle was sagging as far as it would go and managed to man-handle the thing through.
Chewie4299 is offline   Reply With Quote
Old 08-20-2008, 05:45 PM   #4
alecmcmahon
thanks duders, got it in.
lifted it up right a foot from the wheel, and had to take off the rear bracket for the exhaust and force that bugger in.
dynomax is in, looks good, sounds pretty good so far in the driveway.
-my build thread-
Glock Forum
