Quick Disconnects Worth The Extra $
| RUBICON EXPRESS Lift Kits and Accessories Available at Bas | Spartan Lockers FREE SHIPPING Excellent Prices | Free Shipping on TIRES at KrawlOff-Road |
#1 | |
So i'm not sure if this is where this would go, i guess it would go here because im only asking for TJs....
what is the point of quick discos? never had a problem with flex so why should i spend 60 dollars on a set?
#2 |
#3 |
Disco the anti-sway bar results in more flex. Quick disconnects allow this to be done more easily. If your type of wheeling doesn't require more flex, don't worry.
gmb08 |
#4 |
get them!!!
#5 |
IMHO its worth it. Beats the heck out of sitting there for 10 minutes taking the stock bolts loose everytime you want to disconnect. I have enjoyed my wheeling trips disconnected more. If you dont have the extra money, there are threads about making your own.
oh and for the moeny, I like the RE Gen II discos.
/l ,[____], l---L -OlllllllO- ()_)-()_)-o-)_) 8.8 Swap: http://www.jeepforum.com/forum/f9/8-8-swap-into-tj-build-thread-501704/ |
#6 |
ekorb mi
As stated, disconnecting the swaybar allows for more movement of the front axle.
Here are some pics of the swaybar disconnected, you can see how much downtravel it allows for. Obviously different suspension systems allow for more or less travel. ![]() ![]() ![]() ![]() |
#7 |
running with the anti-sway bar disconnected makes a huge difference when crawling over things.
Quick disconnect make the task of disconnecting them easier. If your Jeep is not lifted then its easy enough to make them. There is a write up at using clevis pins @ http://www.4x4xplor.com/homediscos.html Personally I made a set using:
#8 | |||
Disgruntled Jeepforum'er
Location: NY/NJ/PA Tri-State Middletown NY 10941, New York
http://www.jeepforum.com/forum/f37/better-home-brew-disconnects-538245/ ![]() These are ingenious.
-Ryan Google Voice (or the number Grape calls when drunk): 845-476-8182 Quote:
#9 |
Cut to Fit-Paint to Match
Yeah, those are nice.
Running disconnected is the way to go. This was a lot steeper than it looks in the picture. It's good to be able to keep all four tires in contact with the ground. Most of the time, any way. ![]() ![]()
We save dogs: http://www.secondchanceshepherds.org/ |
#10 | |
If guns kill people, then pencils misspell words, cars make people drive drunk, and spoons made Rosie O' Donnell fat! NRA Member '01 TJ Sahara, 3" BB front, 2.25" BB rear, 1.25 JKS BL, 1" MML, Skyjacker Hydro shocks,33/12.50x15 BFG TA/KO All Terrains homemade disco's, Hi-Lift, CB, GPS |
#11 |
where were these pics taken at?
"I'm the guy who does his job, you must be the other guy" '00 XJ 5.5" R.E. Tom Woods,SYE,Discos,HIDs,M/T Wheels 33's... '00 TJ 3.5" R.E. Pro Comp X-Terrain 33's black steelies. SOLD '02 WJ Laredo 4.7 QT II 40k miles! D.D.SOLD |
#12 | |
- 2001 TJ 2.5L, Smittybilt X2O-8 winch, Spartan locker (D30), tube fenders, custom mini-stinger, 2"BB, 1"BL, 35" STTs on Cragar 15x8 Black Steelies - In-Progress: HP30, D44, dual OX lockers, 4.88, 3.5" suspension - Jeep Build: http://s1186.photobucket.com/albums/z373/JFjeld/Jeep_Build/ |
#14 |
My swaybar is disconnected all
#15 |
My sway bar is ----- and I used a few ----- to ----- to the ------
99 TJ Sport 4.0, 5 spd, 2" BB, 31" BFG a/t ko's BLACK JEEP SOCIETY #362
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
