Quantcast Questions regarding Body Lift and Motor mount lift - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Questions regarding Body Lift and Motor mount lift
Old 11-26-2007, 11:28 AM   #1
ToddEdge
I have a JKS 1.25" BL and the MORE motor mount lift. I plan to install this weekend. With both installed, I don't have to mess with the transfer case linkage, do I? I thought that if I did both, I could eliminate messing with that linkage. Also, with both, I don't have to do any radiator fan adjusting, right?
Lastly, I have a 4" lift and the transfer case drop installed. Once I do the MML, I can remount the transfer case/skid plate in the stock location, right?
Thanks,
Todd
'2001 TJ
Lifted & geared...
ToddEdge is offline   Reply With Quote
Old 11-26-2007, 11:50 AM   #2
KRAMONUT
From my experience installing both, I did not have to mess with the transfercase shifter linkage.
You will not have to modify the height of the fan shroud when doing both.
I'd be surprised if you don't end up with vibes w/ adding a body lift & motor mount lift on top of the 4" lift...even after removing the tcase drop. You can always install them & take out the tcase drop & see if you have vibes. But you should really budget for a SYE, driveshaft & upper adjustable control arms at that height.
KRAMONUT is offline   Reply With Quote
Old 11-26-2007, 11:52 AM   #3
[ITA]Tsunami
Italian Wheeler in Mexico
[ITA]Tsunami's Avatar
You may or may not. Jks on their instructions sais that if you do BL+MML you do not need the drop bracket. By my experience by the way i had to use it. This with JKS 1.25 BL and JKS 1" MML.
With 4" of lift, a MML will do nothing at all to get rid of vibes. The only improvement will be +1" of clearance under the oil pan, the no need to trim the fan shroud and.. that's it! You still need the tc drop as long as you don't go with SYE/CV DS.
Originally Posted by mdm
However it is a strange twist in the cosmic thread that will not allow the driver of a Jeep that has experienced air bag deployment off-road to consume beef for 48 hours after the event. You can consume chicken, pork, turkey, or emu.
[ITA]Tsunami is offline   Reply With Quote
Old 11-26-2007, 11:55 AM   #4
TheBoogieman
Demonic Jeep Freak!
TheBoogieman's Avatar
Should be NO for both
TheBoogieman is offline   Reply With Quote
Old 11-26-2007, 12:35 PM   #5
ToddEdge
I was planning to get rid of the TC drop so that I can get an accurate measurement for the driveshaft/SYE and order/install those ASAP.
Thanks,
Todd
'2001 TJ
Lifted & geared...
Old 11-26-2007, 01:52 PM   #6
beryl
so take out the drop and jack the skid up to the frame and get your measurement
i'd also be surprised if you didn't have vibes even with the MML
you may or may not need the bracket.
06x-6speed...hard/soft top, BPE's, 2" coils, 1" PA BL, 32 bfg mt's, 15x8 MT alloys, big daddy rocker guards, flowmaster, RE gen II discos, rear bumper and tire carrier, 10" MTX sub with 800watt kenwood amp, mossy oak mats, sony stereo
beryl is offline   Reply With Quote
Glock Forum
