Questions on LCG style build for street/mud/rocks - JeepForum.com
post #1 of 18 Old 12-31-2008, 03:10 PM Thread Starter
teCh0010
Ok, I am shopping for a 97 - 2000 TJ right now. First Jeep.
When I finish my MBA and get my last tuition repayment check I will have money for mods. I want to do a buildup more on the low center of gravity side of things, but on a jeep that will still be street driven some. Offroad we do both mud and rocks.
My current plan -
Stage 1 - Budget Boost, DIY Highline Hood mod, 35x12.5 BFG KM2's, gears, lockers, steering stabilizer
Stage 2 - SYE, CV Shaft, Tummy Tuck, bumpers, winch, onboard air, Curry Anti-Rock
Questions -
In general does the combo of a budget boost and Highline Hood/Fenders work well for 35's? Anyone have pics of this setup?
Diff - I have had several people tell me that the rear won't handle 35s, Should I go with a junkyard ford rear or a super 35 kit? Is there a junkyard ford option with the correct width and disk brakes?
Tires - I have had plenty of success on the farm with the older BFG MT's, is everyone generally happy with the newer KM2's? Is there a budget bead lock rim out there or will I need to do a kit on steel wheels? What backspacing are people using for 35's, I hate spacers.
Shocks - I know everyone says to get OME, If they are out of the budget is there a cheaper option? I have heard good things about the Skyjacker Hydros.
teCh0010 is offline
post #2 of 18 Old 12-31-2008, 03:20 PM
vitapimp
Owner of REPOST™
vitapimp's Avatar
Originally Posted by teCh0010 View Post
Ok, I am shopping for a 97 - 2000 TJ right now. First Jeep. find one with a D44
My current plan -
Stage 1 - Budget Boost, DIY Highline Hood mod, 35x12.5 BFG KM2's, gears, lockers, steering stabilizer Don't waste your money on gears or a locker for the rear unless you get a jeep with a D44 or you upgrade the rear axle during this stage.
Questions -
there are several threads regarding LCG builds where rigs have about 2-3 inches of lift, chopped fenders, adjusted bumpstops, and they are running 35's without problems. you will be fine.
buy a jeep with a D44. then during your stage 2 add some stronger axles and carry your factory ones on the trail for spares. if you can't, you will be fine with 35's on the D35 just leave it open and when you are wheeling stay off the skinny pedal. you will be ok for a while but will definitely want to upgrade to a ford 8.8 or D44 during your stage 2.
tires, everyone has their own preference. if you like the BFG's the run those. there are lots of options for full beadlocks or doing a kit. backspacing, i wouldn't go higher than 4.5 inches. i went from 4.5 to 5 and now i am rubbing my control arms when i turn.
I bought my rig used so it already had a 4" teraflex short arm lift and OME shocks. can't help you there.
see above in red...
What you are is God's gift to you...
What you make of yourself is your gift to God.
Make a change. Be different.
vitapimp is offline
post #3 of 18 Old 12-31-2008, 03:37 PM
never monday
http://www.jeepforum.com/forum/showthread.php?t=581403
http://www.jeepforum.com/forum/showthread.php?t=637021
http://www.jeepforum.com/forum/f9/super-35-a-513492/
http://www.jeepforum.com/forum/showthread.php?t=583412
I disagree on a mandatory 44 or 8.8
never monday is offline
post #4 of 18 Old 12-31-2008, 04:36 PM Thread Starter
teCh0010
Yeah, if I can find a TJ with a D44 I will get it, I know it was an option but I heard there are not very many out there.
I don't want to invest in gears and a locker for a D30 and then blow it up and get a d44 or ford, I'd rather do it right from the front end. If I can't find a TJ with a factory d44 I will try to do a ford swap on the front end.
Another which TJ question - is the crawl ratio low enough to two foot the brake and gas on rocks in 1st gear or is an automatic prefered? I will have to drive from 30 - 50 miles on the highway to offroad, and once or twice a year 200 miles, so the 5spd is prefered to me as long as I can put enough gear under it to use 5th on the highway.
teCh0010 is offline
post #5 of 18 Old 12-31-2008, 04:42 PM
never monday
and what if it doesn't blow up?? it's posible....
crawl ratios are all dependent on the gearing you end up with.
Can you get the gearing so low in a TJ to do what you describe? yes you can.
post #6 of 18 Old 12-31-2008, 04:48 PM Thread Starter
teCh0010
Can you get it that low with just gears or do you need the t-case reduction (not in the budget for me)? I think 4.88's are the lowest gears I can find for the D30 up front.
teCh0010 is offline
post #7 of 18 Old 12-31-2008, 04:50 PM
never monday
with a 4:1 in the trans, 2.72 TC and 4.88 axles you will be at 53.23. Not low enough. You'll need TC reduction to accomplish what your after.
post #8 of 18 Old 12-31-2008, 06:52 PM
05JGC
Different animal of sorts but to answer one of your questions, i run a 5 speed in my rubicon and with everything stock and my TC in 4 low i dont even worry about the clutch pedal. It is never needed. I would say to get as close to a 4:1 ratio as you can.
05JGC is offline
post #9 of 18 Old 01-01-2009, 12:00 AM
RogueSpear2023
You'll love that stick on the rocks, if you are considering rock crawling get an auto. As far as axles the front Dana 30 is plenty strong for 35s and a locker, just bigger than that is iffy. As far as the rear an S35 is strong enough, or find a Dana 44, or the Ford 8.8 but it requires welding, and is 5/8" narrower on both sides. Or look into an AW4 swap from a cherokee, if you get a stick, it has OD. The real downfall of the Dana 30 front is you are limited at 4.88 gears.
Max
2003 Jeep Wrangler Rubicon
4.0L, 42RLE, Dual Tops, Full Doors, JKS Front Disconnects, Cragar Soft 8 Black Wheels, 33x12.5x15 Goodyear Duratracs, .75" Front Coil Spacers, Bushwacker 6" Flat Fender Flares, Skid Row Steering Box Skid, LubeLockers, Rubicon Locker Mod, OBA, Cobra 19 Ultra III CB, 3' Firestik, Rough Country 2.2 Steering Stabilizer, RC 1.25" BL, RC 1" MML, RC Grab Handles, Fog Lamp Bent Pin Mod, 4" Apline S Series Speakers, Kenwood Excelon 6.5" Speakers, 6.5" JL Audio 6W3V3 Subwoofer (in center console) w/MTX Thunder 202 amp, IPF H4 Headlight Housing, Sliverstar H4 bulbs.
"Buying a jeep and not taking it off road, is like buying a dragster and never taking it to the track"
RogueSpear2023 is offline
post #10 of 18 Old 06-13-2012, 11:08 AM
redrubi03
if you're only guna be going up to 35's then yes get one with a d44 in the back. DONT BOTHER WITH A S35 KIT. if you ever see yourself going bigger then it doesn't matter what axle is in the rear because you should be upgrading to something bigger than a d44 anyways. a manual can be tough in the rocks but just get yourself a hand throttle for $25 and its a non-issue and you get to have more fun on the street and get better mileage than an auto. ask the automatic first gear is lower than a manual so your 1st gear crawl ratio will be lower in an auto vs. a manual.
89 yj, 4.0, SOA, 9" rear with spool, d30 front with upgraded shafts and locker, 4.56 gears, 37" mtr, warn rockers, psc rear stinger carrier, warn front bumper with hoop
Originally Posted by Opihi59 View Post
your unit will be worth the equivalent of a truckload of dead rats in a tampon factory[/B]
redrubi03 is offline
post #11 of 18 Old 06-13-2012, 04:34 PM
rs4race
Check out my build for a decent lcg rig. 35's on ~1.5-1.75" lift
Keeping low with bigger tires is tough to do on a budget. To add to what the others have said.
Just for tires you will want address:
-strength issuses. At minimum a stronger tie rod, and at least a d44 in the rear or super35. Lots of people complain about brakes as well.
-clearance issues.
While turning the larger tires will rub, Spacers, diff bs wheels, adjusting steering stops are some solutions
Clearance with tires and fenders, diy highline, tube fenders, (metalcloak), bumstops, body lift, and cutting bodywork are some solutions
If you do a BB some shocks slightly longer than stock will be good, just bumpstop accordingly. This wont require the modifications to use long travel shocks. If you keep the stock skid this wont require cv, sye, rear upper arms and trackbar mount upgrades.
If you want to do long travel shocks your looking at alot of work if you want to keep a respectable amount of uptravel. Shock mount relocation, control arms with flex joints. The front trackbar will need to be modified to keep it from binding in downtravel aswell.
If you want to get a TT then most likely you will want the sye, cv, upper arms, and rear trackbar mount to keep away the vibes. You will probably want to remount the rear coil mounts to straighten them out also.
I hope this helps give you some things to look into.
My Build
http://www.jeepforum.com/forum/f22/rs4races-build-957569/
rs4race is offline
post #12 of 18 Old 06-13-2012, 04:49 PM
55willystruck
How long did the search take to find this 4 year old thread?
What determines low COG anymore???
Best of Luck,
Mike
55willystruck is offline
post #13 of 18 Old 06-13-2012, 05:30 PM
rs4race
Best of Luck,
Mike
It is 4 years old! someone bumped it to the top so it was on the first page for me.
Trying to define LCG is really not worth the effort. Seems to me the only reason people ask for a definition of LCOG is to try to stir the pot... for entertainment purpose... not really a sincere question... so I wont bother with that... instead I would like to refer you to the search function....
My Build
rs4race is offline
post #14 of 18 Old 06-13-2012, 05:58 PM
Necromancer_tat
Where'd all my money go?
Necromancer_tat's Avatar
2015 JK Wrangler
If you want LCoG then why not make your control arms out of 3" solid bar stock, and run 2.1/4 ton axles with 3" of lift?
My newest build:
Necromancer_tat is offline
post #15 of 18 Old 06-13-2012, 05:59 PM
Necromancer_tat
2015 JK Wrangler
And yes I know this thread is old.
My newest build:
Questions on Building Prerunner/Race Style TJ ScottyR TJ Wrangler Technical Forum 4 09-24-2009 12:14 PM
Xenon Tubular Style Flares - TJ Wrangler 1997-06 QUESTIONS ??? tdog522 TJ Wrangler Technical Forum 128 06-01-2009 12:25 PM
Sport Style Roll Bar Pic Request/Questions DT5150 YJ Wrangler Technical Forum 11 02-21-2008 11:54 AM
Help - 4x4 questions - street driving McCooter JK Wrangler Technical Forum 23 10-03-2007 07:21 PM
CV driveshaft questions (with belly-up style t/case skid) neZZr TJ Wrangler Technical Forum 3 02-24-2005 05:00 PM
