question on warn/stinger bumper and cutting
| 1984-2001 Jeep XJ Cherokee Lift Kits 3-4.5" with Full | Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line | Spartan Lockers FREE SHIPPING Excellent Prices |
#1 | |
bumper cutting and bolt on stinger
ok, so i have been looking around and have not been able to find a bolt on stinger for the warn rock crawler bumper. do they make one? i thought i have seen one out there before but just not able to find it now.
also, since i currently have the rock crawler bumper, if i cut the ends off right before the fame. will it make the bumper not strong enough for the winch or will it pose any major safety concerns? i dont see how it would, but just making sure before i go citting. below i posted an older picture, i no longer have the fog lights on it. the first picture is the whole bumper. the second is where i plan on cutting it off, the red area. ![]() ![]()
[CENTER]01 TJ. 35 inch KM2's. 4.5 RE. 2 inch body lift. dana 44. Detroit Locker. Olive Drab!! all set for trout and bambi![/CENTER] Last edited by fishinjeeper; 11-02-2009 at 09:56 PM.. |
#2 |
bump......
[CENTER]01 TJ. 35 inch KM2's. 4.5 RE. 2 inch body lift. dana 44. Detroit Locker. Olive Drab!! all set for trout and bambi![/CENTER] |
#3 | |
Straight Up Fool!
I can't imagine how cutting it off outside the frame rails could weaken it between the rails where the winch mounts???
My RHD TJ - Savvy equipped... And loving it! - Durty Rok Carolina Offroad I drive on the right side, what's wrong with you? Quote:
#4 |
Assuming it's bolted from the top and bottom, the only way it would make it weaker is if the shortest distance between the bolt and a free surface is now the cut plane. I think this would only matter if you had a resultant force off axis (not straight forward), like a deformation of the bumper (crash) or getting yanked out crooked. I wouldn't worry about it, just cut it.
I require things to do. |
#5 |
thank you guys!
#6 |
The winch isn't bolted to the bumper anyway, cut all you want.
By "stinger" if you mean the long extended stinger hoop, any welding shop can make you one. But if you just mean a hoop, Warn makes one, I love mine... |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
