Question on rear axle strength (Super 35, 8.8)?
#91 | ||
I haven't updated my profile ![]() If you must know I initially thought that was the way to go, but through further research I'm not so sure. ![]() ![]() ![]()
__________________ "The only physical problem Obamacare won't be able to fix, is bustin' your @$$." – Dennis Miller |
#93 | |
#94 |
I'm not convinced either, and with the narrower track, I don't see how that is benificial for stability? As common as the Exploder is in these parts you'd expect to find a diff out of the things for a hundred bucks ... but not where I live? Unless you run into a guy that thought the 8.8 swap was the best route to go and then accidentally welded the perches on wrong so he's discounting the thing to get rid of it. j/k
#95 | |
Brake Wizard
I am Savvy I am handling the sales of Black Magic Brakes on www.blackmagicbrakes.com |
#96 | |
Ps- I thought the diff was only .625"-.750" narrower per side?? I can't recall the specifics?
#97 |
Brake Wizard
The width from the kit is because of the c-clip eliminator housing ends. It was not determined by how how much too narrow the housing was.
#98 | ||
pete montie on here pulls them and sells them. He shipped me my 4.10 from Michigan to CA for $400. Now that I moved within 5 miles of a pick and pull, i have been there 5 times in the last 5 months and they are selling axles for $200 each and there are tons of 4.10 8.8's. once a month they have 50% off - i could snag one for $100. Wish i waited now, but I wanted to buy one before I moved here. Quote:
differential offset has caused zero problems for me...that angle is minimal. As for the brackets - you are correct....if you cannot trust yourself to locate the brackets correctly...then you are probably better off getting the S35 kit.
-0|||||||0-
He who hunts in a pack is still a dog. The lion hunts alone, and so do I. - Napoleon Conducting an argument by appealing to authority is not using your intelligence; it is just using your memory. - Leonardo Da Vinci |
#99 |
The thing i wonder though is everyone gets the disc brake 8.8 but yet complains about c clips. correct me if i am wrong but if it does fail wont the breaks keep it from coming out where the drums on the 35 dont hold it in. i know the super 35 eliminates the c clips i am just wondering because the c clip worried me origanlly on my 8.8 but i then thought the brakes will hold it if it fails
1997 Jeep Wrangler 5.0 ho gt40p motor w/ e303 cam, ax15 trans. 241j rock trac transfer case from 05 rubicon. 05 front rubicon 44 with yukon chromoly shafts and rear rubicon dana 44 and rubicon rims with 33x11.50x16 mtrs |
#100 |
I went with the S35 kit as its a DD and wanted to keep the stock axle until its retired. But with the 35 being a weak axle, I did the best they offer as an up-grade to it. I have wheeled it many times now, And have had great results. IMO if I'm going to take it out, I'm going to put something worth while in, D60, 9", etc not a 8.8. But it is a good swap just not for me.
Couple TJ's and a XJ |
#101 | |||
Glad you got a laugh, but two vehicles at the same height, yet one has a narrower track, that one is more likely to turn over in an off-camber situation ... granted the difference is not great, but given the option, I'll take the wider track, and it doesn't seem necessary to go beyond S35 capabilities for my use? I will give to the fact that straight ahead a narrower track can help get through a tight spot ... but then your front is compromising you some in that regard right? Quote:
![]() I would hate to think it's right and then miss it by a hair, although a slight variation I concede will likely not give you any real vibs, but who knows, unless Jessie's stunt double from Extreme 4x4 is doing the welding, it might not be right. I just think for the average shade tree, the cheaper route is beefing up the D35.
#102 | |
#103 | |||||
Well joe,
i think it all comes down to personal preference. Quote:
again, i am a pretty anal person and I detect no difference. 1/2 inch on each side is hardly detectable when you are looking at 12.5" wide tires over a 96" wheelbase. Quote:
many vehicles come straight from the factory with offsets. my '53 M38A1 doesn't have a centered differential, either and it has worked like that for 55 years just fine. Quote:
that is what a tuneable suspension is for, my friend. on a side note, if you plan that V-8 conversion you might start looking at a minimum at an 8.8 or above.
-0|||||||0-
He who hunts in a pack is still a dog. The lion hunts alone, and so do I. - Napoleon Conducting an argument by appealing to authority is not using your intelligence; it is just using your memory. - Leonardo Da Vinci Last edited by Greg_Volkman; 10-13-2008 at 03:03 AM.. |
#104 | |
1998 TJ, 4.0L Auto | 3" Nth Springs | JKS QDs | D30 Detroit True Trac | Nth Tummy Tucker | 35x12.50r15 Goodyear MT/R | JB Super Short SYE| 1.25" BL | Novak Tcase Shifter
Rolled Red Jeep Club Member #7 |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
