Question on rear axle strength (Super 35, 8.8)?
#61 | |
Wonder who we get to donate to the cause and how to go about the testing .
1998 TJ, 4.0L Auto | 3" Nth Springs | JKS QDs | D30 Detroit True Trac | Nth Tummy Tucker | 35x12.50r15 Goodyear MT/R | JB Super Short SYE| 1.25" BL | Novak Tcase Shifter
Rolled Red Jeep Club Member #7 |
#62 |
hahaha!
i've seen joe's rear axle enough to recognize it anywhere ![]()
97 TJ 4.0, AW-4, Clayton, A.R.B., Highly polished HP30, Super 88 There are no shortcuts to any place worth going 91 XJ 4.7 |
#63 |
I have an 8.8, how do I tell what year/model it is?
#64 |
on a related note do you think it is worth putting chromolly parts in an 8.8? I know mosier makes 8.8 axles etc
#65 |
Brake Wizard
Because I can't weld with my eyes closed.
I am Savvy I am handling the sales of Black Magic Brakes on www.blackmagicbrakes.com |
#66 |
Brake Wizard
It is if they are the ones in Superior's Super 88 c-clip eliminator. Not that the c-clips are a problem, but there are several deficiencies the kit addresses.
#67 | |||||
Theres not enough change in strength to justify the expense. Now, moving to 60's or 9" is the next class up. Quote:
Get Savvy |
#68 | |
2. If a D44 is a step up from a S35, but a 8.8 is not a step up from a S35, then shouldn't it read D44 > 8.8 = S35? 3. hhhmmmm 9"...third members...Spidertrax housing's are sexy 4. ![]() I ment .500, reading to much axle specs to keep crap straight. And, TJ D44's tubes are still prone to the same flexing a S35 would be, but the larger center section and larger gears add to strength and lessen the chance of breaking something inside that center section vs a S35.For future reference - thanks to Google and my trusty calculator: Dana 30 - 2.5" x 0.250" wall - Moment of Inertia: .65941 in^4 Dana 35 - 2.5" x 0.250" wall - Moment of Inertia: .65941 in^4 Dana 44 1/2 ton - 3.0" x 0.250" wall - Moment of Inertia: 1.16870 in^4 GM 10-bolt - 3.0" x 0.250" wall - Moment of Inertia: 1.16870 in^4 GM 12-bolt - 3.0" x 0.250" wall - Moment of Inertia: 1.16870 in^4 Ford 8.8 inch - 3.25" x 0.188" wall - Moment of Inertia: 1.1614 in^4 (some say .250", but I've never measured one so I'll stick with never_monday's spec) Ford 9-inch - 3.0" x 0.250" wall - Moment of Inertia: 1.16870 in^4 Dana 44 front 3/4 ton - 2.75" x 0.500" wall - Moment of Inertia: 1.5493 in^4 Dana 60 rear - 3.125" x 0.313" wall - Moment of Inertia: 1.61209 in^4 Dana 60 front - 3.125" x 0.500" wall - Moment of Inertia: 2.3506 in^4 Dana 70 rear - 3.625" x 0.563" wall - Moment of Inertia: 4.1611 in^4 The higher the moment of inertia, the more cross sectional area of material to absorb stress, the stronger the tube.
Useful Write-Ups: SEARCH TUTORIAL TJ Tech BOOT CAMP-A Must Read! FAQ: Cold Air Intakes & K&N's Off-Road Tips and Techniques What is a CV shaft and why do I want one? So you want a Tummy Tuck? Tire size, lift height, bumpstops & shock guide DIY Shock Shifters for Long Travel Shocks Lug nuts and bolt patterns Catalytic Converters Busted TJ Track Bar Bolt Fix Brake Knuckle Divot/Groove Repair Coconut Oil for Drilling and Machining Fabrication & Build: My Build Thread Funny: Will it fit in my Jeep? Last edited by Unlimited04; 10-04-2008 at 11:33 AM.. |
#69 | |||
Because the 44 housing is better than a 35 or 8.8 Quote:
Get Savvy |
#70 | |
I thought XJ D44's were 2.75" and XJ D35s were 2.65", but TJ's were 2.5"? Splitting hairs here, i'm sure Jeep used slightly different size tubes across many of these axles depending on the time period. http://www.4x4wire.com/jeep/tech/axle/xj_dana44_02/
Useful Write-Ups: SEARCH TUTORIAL TJ Tech BOOT CAMP-A Must Read! FAQ: Cold Air Intakes & K&N's Off-Road Tips and Techniques What is a CV shaft and why do I want one? So you want a Tummy Tuck? Tire size, lift height, bumpstops & shock guide DIY Shock Shifters for Long Travel Shocks Lug nuts and bolt patterns Catalytic Converters Busted TJ Track Bar Bolt Fix Brake Knuckle Divot/Groove Repair Coconut Oil for Drilling and Machining Fabrication & Build: My Build Thread Funny: Will it fit in my Jeep? |
#71 | |
in the end for 35" tires it doesn't mater which axle you have all 3 are viable axles.
Get Savvy |
#72 | |
Brake Wizard
#73 | |
I didn't compare tube length at all, but had assumed the D44 shafts would actually be shorter in the same configuration, since the D44 housing is larger & track width is still the same, or at least less bare tube would be exposed. Assuming we're comparing disc and disc and drum to drum axles. What is the difference between the tube lengths of each side? What is the overall tube length of each axle? I could calculate the stress on any length tube using beam bending. For tube strength ONLY, if the overall difference between them is less than 1 to 2 inches, i'm going to guess 8.8 > D44 > D35 based on moment of inertia (MOI), since the 8.8's MOI is almost twice that of the D44/D35 tube. **based solely on tube strength! not overall housing strength**
Useful Write-Ups: SEARCH TUTORIAL TJ Tech BOOT CAMP-A Must Read! FAQ: Cold Air Intakes & K&N's Off-Road Tips and Techniques What is a CV shaft and why do I want one? So you want a Tummy Tuck? Tire size, lift height, bumpstops & shock guide DIY Shock Shifters for Long Travel Shocks Lug nuts and bolt patterns Catalytic Converters Busted TJ Track Bar Bolt Fix Brake Knuckle Divot/Groove Repair Coconut Oil for Drilling and Machining Fabrication & Build: My Build Thread Funny: Will it fit in my Jeep? Last edited by Unlimited04; 10-04-2008 at 07:27 PM.. |
#74 |
I think your still missing real world impact strength of .250 Vs .188
Yes the 3.25x.188 tube will take more to bend. But how about impact resistance when you miss judge the height of the rock in the road at 30-40-50mph. This is where the thicker wall will shine.
Get Savvy |
#75 | |
Impact resistance? It still boils down to shear and stress over a specific area. The more area said shear and stress has to distribute long, the stronger the part will be. Also - impacts get into something a lot more complicated, including non-linear differential equations, but again...it still boils down to force per unit area. Thats why birds have large diameter hollow bones - stronger and lighter. Same with your bones...large diameter & thin cortical wall.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
