Quantcast Question on rear axle strength (Super 35, 8.8)? - Page 4 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Question on rear axle strength (Super 35, 8.8)?
Old 10-03-2008, 04:45 PM   #46
never monday
Originally Posted by jeepster93 View Post
I bent the housing on the 35
How did you bend the housing and where was the failure?
Get Savvy
never monday is offline   Reply With Quote
Old 10-03-2008, 05:07 PM   #47
mrblaine
Brake Wizard
mrblaine's Avatar
. A SuperD35 is still stronger axles in a weak housing. The housing will still flex, and you'll still be stressing those axles. Why not have stronger axles in a stronger housing?
What makes you think the D-44 doesn't flex? And before you answer, I've measured it and it does, and a considerable amount at that.
I am Savvy
I am handling the sales of Black Magic Brakes on www.blackmagicbrakes.com
mrblaine is offline   Reply With Quote
Old 10-03-2008, 05:30 PM   #48
Jeepguy1977
Blaine, I'm will to bet the 8.8 flexes to.
1998 TJ, 4.0L Auto | 3" Nth Springs | JKS QDs | D30 Detroit True Trac | Nth Tummy Tucker | 35x12.50r15 Goodyear MT/R | JB Super Short SYE| 1.25" BL | Novak Tcase Shifter
Rolled Red Jeep Club Member #7
Jeepguy1977 is offline   Reply With Quote
Old 10-03-2008, 08:28 PM   #49
Paulio91184
1992 XJ Cherokee
I almost forgot, i have the 8.8 in my 1990 T bird Super Coupe.ive got tons of mods on that Supercharged 3.8 V6 making about 390ft/lbs of torque and it handles my heavy right foot. granted it's an independent rear suspension but that says alot for housing/R&P strenght
WHITE JEEP CLUB MEMBER #2112
NYPD JEEP CLUB MEMBER #1
1992 Jeep Cherokee Police Package
3.5" Rubicon Express Superflex with RE Monotubes, Ford 8.8 Rear Axle, 33x12.50 General Grabber AT2's, RE Gen 2 quick disco's, KC Daylighters
1989 T Bird Super Coupe 5 Speed
Paulio91184 is offline   Reply With Quote
Old 10-03-2008, 08:32 PM   #50
never monday
weak
try 450hp & 490 lb/ft of torque to a D44
http://www.reefcorner.com/Viper/viper_specs.htm
Get Savvy
Old 10-03-2008, 08:51 PM   #51
clarkjdg
OLD RED NECK!!!
clarkjdg's Avatar
Question: This is the first time Ive seen this forward brace on a 8.8 in a jeep what is it for, and is it a must? Or is it just for theleaf over axle swap? Attachment 55608
LIVE EVERY DAY LIKE IS WAS YOUR LAST...
/_|__\___\
[n___n_[*lllll*]
(o) )-(o) )-*-) )
88 YJ, Smittybilt SRC Front, Side, and Rear Armor, Family Roll Bars, TJ Flares, and Half Doors
4"Leaf, 2"Body, and 1"Leaf Lift, 4.10 Geared Dana 30 Posi with Cable Engage, Ford 8.8 Posi, With 33s BFGs MT KM2
Everything "Black" Inner, Under, and outer "Black" on the Body is "Bed Linered" and I will be Thru the day that I Die!
clarkjdg is offline   Reply With Quote
Old 10-03-2008, 08:58 PM   #52
mrblaine
Brake Wizard
mrblaine's Avatar
I've got a HP Dana 60 for a rear axle and I know for a fact it flexes.
I am Savvy
Old 10-03-2008, 08:59 PM   #53
mrblaine
Brake Wizard
mrblaine's Avatar
Boy, if that's not Joe Dillard's rear 8.8, someone made an identical copy.
I am Savvy
Old 10-03-2008, 09:06 PM   #54
clarkjdg
OLD RED NECK!!!
clarkjdg's Avatar
yes it is but what is it for ive never seen any thing like it?
/_|__\___\
[n___n_[*lllll*]
(o) )-(o) )-*-) )
Old 10-03-2008, 09:14 PM   #55
mrblaine
Brake Wizard
mrblaine's Avatar
It's a traction bar due to excess axle wrap when you go spring over.
I am Savvy
Old 10-03-2008, 09:16 PM   #56
clarkjdg
OLD RED NECK!!!
clarkjdg's Avatar
Thanks!!
/_|__\___\
[n___n_[*lllll*]
(o) )-(o) )-*-) )
Old 10-03-2008, 09:47 PM   #57
Unlimited04
Unlimited04's Avatar
Originally Posted by never monday View Post
on the housing mass = strength comment. Why does the 44a use Aluminum behind V10's and LS engines? Why is the new Currie Rock Jock and Aluminum housing? Again, bigger isn't always better. I could careless if I break something. Heck I intentionally try for failures. This is my racer mentality.
Why breaks something for the fun of it? Do you have that much money that you can afford to? Or are you just breaking other peoples stuff?
Aluminum housings are a totally different story. Again, this fits into the category of alloy of metal used. Those Currie housings and the 44a housing are both very thick aluminum, and very high grade of aluminum at that. Aluminum is actually stronger than steel in many respects, it however does not have the same fatigue life. I'm talking about cast iron and cast/extruded steel when talking about 8.8 vs D44 vs D35 housing strength. A D60 is much heavier than an 8.8 or D44...and much stronger. In general, more material to support stress = more weight and more strength. Sure you can make a lightweight 9", truss it, put 40 spline alloys in it and it will be 1/2 the weight of a D60 and twice as strong, but not many people have a budget for that.
Can't change your mind, don't really care too either. Good luck with your 8.8
Don't need an 8.8, I've got a D44
your responses are examples of "it's what the books said would work" thinking. Not that it's bad, it's a different approach to problem solving than the way tinkerers experiment.
I'm a tinkerer. But I'd rather tinker with an educated guess than simply tinker with something for the hell of it. I'd rather run an 8.8 or D44 vs a D35 or S35. Each have their plus and minus, but for where the money goes, I'd rather spend it on something I know is going to last and take abuse.
so why is it a weaker housing than the TJ 44?
See below.
Never said it wouldn't flex. Just saying it won't flex as much as a D35 housing when under the same stress. And similarly, the 8.8 won't flex as much as a D35 when under the same stress.
That said, hopefully we all know the D44 uses the same tubes as a D35, so the tube flex portion of this 'housing flex' is kind of subjective. The TJ D44 is kind of a 'hybrid D44', like the Rubicon front D44. This makes the TJs D44 less strong than a Ford or Chevy 3/4 ton D44, or even the JK HD D44. We do know however, the walls of the cast housing are thicker in a D44 than the D35, and there is more ribbing built into the D44 housing than the D35 housing. Hopefully, as you know, these mean the housing is stiffer, and therefore flexes less.
As you know, when you get flex you start to move parts. When you move parts, tolerances become extremely important, and you can break parts due to interference, in addition to the shear strength of the axle shaft itself.
You can add to a D35: alloy shafts, truss, c-clip eliminator, add high quality gears, retube the housing with .25", etc, but its going to cost a lot of money and work. Wouldn't it be smarter (and more economical) to just buy an axle that already has the strength you're looking for?
Unlimited04 is offline   Reply With Quote
Old 10-03-2008, 10:08 PM   #58
Tim
i was thinking the same thing
97 TJ 4.0, AW-4, Clayton, A.R.B., Highly polished HP30, Super 88
There are no shortcuts to any place worth going
91 XJ 4.7
Tim is offline   Reply With Quote
Old 10-03-2008, 10:20 PM   #59
Jeepguy1977
Why are you looking at some guys rear end
Old 10-03-2008, 10:31 PM   #60
Greg_Volkman
now, the correct way it should flow is D44 = 8.8 = S35
that is an opinion. you may be able to dismiss the ring gear size and the 31 spline shafts easily, but that still doesn't mean it is true. until they come out with some real world testing no one will really know.
-0|||||||0-
He who hunts in a pack is still a dog. The lion hunts alone, and so do I. - Napoleon
Conducting an argument by appealing to authority is not using your intelligence; it is just using your memory. - Leonardo Da Vinci
Greg_Volkman is offline   Reply With Quote
Glock Forum
