Question on rear axle strength (Super 35, 8.8)?
#31 | ||
Brake Wizard
Interestingly to me at least, removal of the c-clips out of the side gears seems to be making them and the stock carriers last longer without failures.
I am Savvy I am handling the sales of Black Magic Brakes on www.blackmagicbrakes.com |
#32 | |
Get Savvy Last edited by never monday; 10-03-2008 at 11:46 AM.. |
#33 |
"Can you verify with testing results the ring and pinion is stronger in an 8.8?"
Ok, you're right, that's my opinion. My statement on RandP strength are not backed by testing results. However, I fail to see the point you are arguing on this. I look at the sheer size difference between the different ring and pinion sizes of a Super 35 and 8.8 and form an opinion that it does imply a strength difference. What is the reason that it would not be stronger, even without testing results? Are the Ford 8.8 ring and pinions made from a weaker material than the Dana's? Please elaborate on your posistion on this topic. I understand that guys are running the Super 35 and not destroying the ring and pinion, so you're right...it is adequate for 35" tires then. But why wouldn't the 8.8 have a stronger ring and pinion than the Super 35? ![]() |
#34 |
I can't make the assumption that bigger is better. Some times bigger is just that, bigger. Ford made the 8.8 to cover a large segment of their vehicle line up. On some it's just adequate, on others it's over kill. I think the 8.8 is more of a one size fits all solution than an engineered solution to a specific application.
I'm not a metallurgist, I can't comment on the quality of the steel. Why carry around all the extra mass if you don't need it?
Get Savvy |
#35 | |
Brake Wizard
Compare the pinions and look at how many spirals they make around the head.
#36 |
Never Monday,
where did you find your deal on the Super 35 kit? Quadratec lists the detroit equipped Superior Super 35 kit at $1,100 and the ARB equipped one for $1,300. If you have a link to a good deal please post it up for others who may be reading this thread and would like to find the kit for cheaper. As for our discussion on the various axle upgrade options, I am pretty much out of stuff to say...how bout you? I won't say mines better or anything like that, because you and I both know that's dumb. We can just agree to disagree. In the end people will do what is right for thier situation and thier goals for thier jeep. I did enjoy the banter back and forth, and if there is anything left to discuss, post it up and I will reply. But I don't really know what else to say.![]() Thanks |
#37 | |
this is a good point. I see what you are saying. |
#38 | |
I got my S35 at Performance Off Road Center I think this thread should be bronzed. It's been one of the calmest, respectful 35/44/8.8 debates ever.
Get Savvy |
#39 |
Now, the next question is...what kind of jobs do we have that we can sit around in the middle of the day on a weekday and talk back and forth about jeeps?
#41 |
that's too funny
#42 | |
Its also easy to think of it from what these axles came in originally to see how much stress they were designed to sustain. D35 = 1/4 ton axle - Jeep Wrangler, Ford Explorer TTB front. D44 = 1/2 ton axle - everything from Jeep Wranglers to Chevy/Ford/Dodge pickups, 1/2 ton and 3/4 ton. Lots of configurations. 8.8 = 1/2 ton axle - Bronco's, F150s, Rangers, Mustang's, Crown Vics, Explorers, etc..again lots of configurations, but lots of Full Size vehicles with V8 engines and/or larger payload capacity. You can add internal components to either axle, but what really plays a roll in how 'strong' the unit as a whole, is lots of factors, like those listed above (just some of the factors). I'd rather have something originally designed for heavy use applications. A SuperD35 is still stronger axles in a weak housing. The housing will still flex, and you'll still be stressing those axles. Why not have stronger axles in a stronger housing?
Useful Write-Ups: SEARCH TUTORIAL TJ Tech BOOT CAMP-A Must Read! FAQ: Cold Air Intakes & K&N's Off-Road Tips and Techniques What is a CV shaft and why do I want one? So you want a Tummy Tuck? Tire size, lift height, bumpstops & shock guide DIY Shock Shifters for Long Travel Shocks Lug nuts and bolt patterns Catalytic Converters Busted TJ Track Bar Bolt Fix Brake Knuckle Divot/Groove Repair Coconut Oil for Drilling and Machining Fabrication & Build: My Build Thread Funny: Will it fit in my Jeep? |
#43 |
Obviously your an engineer. Good for you. I still maintain the 8.8 is a readily available viable alternative axle. It's in no way superior to a 44 or S35 with the same mods an 8.8 would require to live.
on the housing mass = strength comment. Why does the 44a use Aluminum behind V10's and LS engines? Why is the new Currie Rock Jock and Aluminum housing? Again, bigger isn't always better. I could careless if I break something. Heck I intentionally try for failures. This is my racer mentality. Can't change your mind, don't really care too either. Good luck with your 8.8 your responses are examples of "it's what the books said would work" thinking. Not that it's bad, it's a different approach to problem solving than the way tinkerers experiment.
Get Savvy Last edited by never monday; 10-03-2008 at 04:36 PM.. |
#45 |
![]() I had a super 35(with a Detroit) and replaced it with an 8.8(with an ARB) I bent the housing on the 35, so I needed to move on. I still have it, as no one finds it of real value. I can give it away, but can't sell it for what I think it is worth. Someone on here offer me 4 bills for a super 35??? |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
