Question on rear axle strength (Super 35, 8.8)?
| Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line | GR8TOPS Introduces the Exogate HD Tire Carrier | 1984-2001 Jeep XJ Cherokee Lift Kits 3-4.5" with Full |
#1 | |
Hello,
I would like to know how a 31 spline Ford 8.8 rear axle from a 98 or newer Ford Explorer compares with the strength of Super 35 rear axle in a Jeep TJ application. I am new to this site and I have been wanting to discuss this topic with others, have tried posting on other threads twice, but have apparently not found the appropriate thread for it as of yet. So, I started my own. I would just like to know what some of your opinions are on this topic. Please keep your responses informative, not argumentative. I would like this thread to be useful for those who might be considering an 8.8 swap or investing in thier current Dana 35 with a Super 35 kit. I'll start...I have been trying to find some kind of chart that compares axle shaft strength between various axles, such as the 30 spline Super 35 and the 31 spline 8.8, Dana 60, Dana 44, etc. Does anyone know of such a chart? Thank You ![]()
#2 |
NOt even Close.........Building a Dana 35 is like polishing a terd......8.8 is like 120% stronger than the D35.i'm doing the swap on my 92 XJ in a few days.plus the 8.8 tubes are much bigger and thicker..just a much more robust axle and you get free disc brakes too!! only bad thing is that the 8.8 is 1" narrower that the D35 but some spiudertrax wheel spacers will fix that... just make sure to weld the center section to the tubes if you do go this route...BTW Ruff Stuff specialties has an 8.8 easy swap kit for like $120...I hope this helps
WHITE JEEP CLUB MEMBER #2112 NYPD JEEP CLUB MEMBER #1 1992 Jeep Cherokee Police Package 3.5" Rubicon Express Superflex with RE Monotubes, Ford 8.8 Rear Axle, 33x12.50 General Grabber AT2's, RE Gen 2 quick disco's, KC Daylighters 1989 T Bird Super Coupe 5 Speed Last edited by Paulio91184; 10-02-2008 at 02:28 PM.. Reason: ... |
#3 |
![]() Search: I found this with google in less than 10 seconds: http://www.jeepforum.com/forum/f9/tj-rear-axle-options-583412/#post5461998
Useful Write-Ups: SEARCH TUTORIAL TJ Tech BOOT CAMP-A Must Read! FAQ: Cold Air Intakes & K&N's Off-Road Tips and Techniques What is a CV shaft and why do I want one? So you want a Tummy Tuck? Tire size, lift height, bumpstops & shock guide DIY Shock Shifters for Long Travel Shocks Lug nuts and bolt patterns Catalytic Converters Busted TJ Track Bar Bolt Fix Brake Knuckle Divot/Groove Repair Coconut Oil for Drilling and Machining Fabrication & Build: My Build Thread Funny: Will it fit in my Jeep? |
#4 |
HINT*(GOOGLE.COM)
here is some good info http://www.jedi.com/obiwan/jeep/ford88.html has some strength specs in here http://www.jeepsunlimited.com/forums/showthread.php?t=674123 -- Axle shaft Strength and output torque rating by Warn and 4 Wheeler The axle shaft strength tested by Warn Ind: F8.8= 6,500 (lb. ft.) D44= 4,600-5,000 (lb. ft.) D35C= 4,000-4,300 (lb. ft.) COT: Continuous output torque rating MOT: Maximum output torque rating (Numbers from January edition of Fourwheeler, page 60.) Dana 35 rear axle COT: 870 MOT: 3480 Dana 44 rear axle COT: 1100 MOT: 4460 Ford 8.8 28spline COT: 1250 MOT: 4600 Ford 8.8 31spline COT: 1360 MOT: 5100 Dana60 semifloat COT: 1500 MOT: 5500]
-------XJ FOR SALE--------- 2000 XJ; JC Offroad bumper http://www.jcroffroad.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=2XJRST2&Cate gory_Code=XJB JKS Quicker Disconnects, Moab Rims with 33's, 6.5" Rusty's lift, Tom Wood drive shaft, slip yolk eliminator, some fender hacking AND an 8.8 that needs to be installed!!! |
#5 | |
Thanks. |
#6 | |
Also, any chart that throws the shaft from the Super 8.8 in the comparo with the other axles would be some good information. Thanks |
#7 | |||
read up; http://www.jeepforum.com/forum/f9/tj-rear-axle-options-583412/ if you don't believe me, cross check the facts; http://www.jeepsunlimited.com/forums/showthread.php?t=674123 Quote:
They compare stock shafts Quote:
A reasonable assumption of S35 shaft strength would be; equal to a D44 shaft made from 4130. This would logically make it stronger than a regular 44 shaft. Also keep in mind. The strength of an axle assembly is not based on just the shaft strength.
Get Savvy Last edited by never monday; 10-02-2008 at 03:07 PM.. |
#8 |
I've never seen a chart of breaking strength of a super axle. But they DO say that a super axle is 30 to 35% stronger. So just take those numbers above and add 35% to them. The super 88 does not include a locker and eliminates the c-clips, and adds 3/4 ton bearings.
I put a 30/30(AlloyUSA's version of a super 30) in a few years ago after a streak of axle issues, no issues sense. I am convinced in super axles. They are worth having(just don't spend a lot on a dana 35). |
#9 |
thank you for contributing on this post Never Monday. I did not intend to anger anyone when I posted on your thread regarding the Super 35/D44/8.8.
just new to the site and have been looking for a place to start an healthy discussion regarding this subject. |
#10 | |
this will be a good one for hashing out the opinion...and I have some
Get Savvy |
#11 |
Never Monday,
As I am sure you have realized, I have the 8.8 in my TJ. I'm not saying its better than anything else. Its just what I chose over a super 35 kit or dana 44 swap. You have mentioned on the fact that there are some common misconceptions about the 8.8 as a good swap canidate, but have not elaborated as of yet because the current thread was not the place to. I was just curious about your perspective. There may be something that I am not aware of. Please elaborate about the disadvantages of the 8.8. I already know about how its a custom set-up (not bolt-in), c-clip axle. But what else? This in not me being sarcastic, I am wanting to learn more on the subject, and I like the discussion. Thanks |
#12 |
C-clip shafts
3 welds hold the tubes to the center (same as 35. 44 has 6) increased tube dia = decreased ground clearance increased casting = decreased ground clearance none are bolt in for a TJ and require welding offset chunk; not a big deal but won't work with a GenRight strech tank thin cover thiner tubes than a 35 or 44 (although the strength is about equal due to dia) narrower track no locker (S35 has a locker, R44 has a locker) all can be over come. I just don't see enough strength gain to go through all the work. I do see the 8.8 as a viable, readily available axle to convert for a TJ.
Get Savvy |
#13 | |
IMHO If you're breaking S35's, then why not step up to a shaved 9" semi floater? You're not looking at that much more unless you slap a high pinion third on it.
#14 |
[QUOTE=never monday;5786482]too much in this post is factually incorrect
read up; http://www.jeepforum.com/forum/showthread.php?t=583412 if you don't believe me, cross check the facts; http://www.jeepsunlimited.com/forums/showthread.php?t=674123 What is Incorrect?
WHITE JEEP CLUB MEMBER #2112 NYPD JEEP CLUB MEMBER #1 1992 Jeep Cherokee Police Package 3.5" Rubicon Express Superflex with RE Monotubes, Ford 8.8 Rear Axle, 33x12.50 General Grabber AT2's, RE Gen 2 quick disco's, KC Daylighters 1989 T Bird Super Coupe 5 Speed |
#15 | |
Get Savvy |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
