-   TJ Wrangler Technical Forum (http://www.jeepforum.com/forum/f9/)
-   -   Question on rear axle strength (Super 35, 8.8)? (http://www.jeepforum.com/forum/f9/question-rear-axle-strength-super-35-8-8-a-613745/)
Rowdy115 10-02-2008 02:20 PM
Hello,
I would like to know how a 31 spline Ford 8.8 rear axle from a 98 or newer Ford Explorer compares with the strength of Super 35 rear axle in a Jeep TJ application. I am new to this site and I have been wanting to discuss this topic with others, have tried posting on other threads twice, but have apparently not found the appropriate thread for it as of yet. So, I started my own. I would just like to know what some of your opinions are on this topic. Please keep your responses informative, not argumentative. I would like this thread to be useful for those who might be considering an 8.8 swap or investing in thier current Dana 35 with a Super 35 kit.
I'll start...I have been trying to find some kind of chart that compares axle shaft strength between various axles, such as the 30 spline Super 35 and the 31 spline 8.8, Dana 60, Dana 44, etc. Does anyone know of such a chart?
Thank You:)
Paulio91184 10-02-2008 02:24 PM
NOt even Close.........Building a Dana 35 is like polishing a terd......8.8 is like 120% stronger than the D35.i'm doing the swap on my 92 XJ in a few days.plus the 8.8 tubes are much bigger and thicker..just a much more robust axle and you get free disc brakes too!! only bad thing is that the 8.8 is 1" narrower that the D35 but some spiudertrax wheel spacers will fix that... just make sure to weld the center section to the tubes if you do go this route...BTW Ruff Stuff specialties has an 8.8 easy swap kit for like $120...I hope this helps
Unlimited04 10-02-2008 02:25 PM
http://www.jedi.com/obiwan/jeep/pics...ther10_910.jpg
Search:
I found this with google in less than 10 seconds:
http://www.jeepforum.com/forum/showp...98&postcount=1
LILXJ2000 10-02-2008 02:31 PM
8.8
HINT*(GOOGLE.COM)
here is some good info
http://www.jedi.com/obiwan/jeep/ford88.html
has some strength specs in here
http://www.jeepsunlimited.com/forums...d.php?t=674123
Axle shaft Strength and output torque rating by Warn and 4 Wheeler
The axle shaft strength tested by Warn Ind:
F8.8= 6,500 (lb. ft.)
D44= 4,600-5,000 (lb. ft.)
D35C= 4,000-4,300 (lb. ft.)
COT: Continuous output torque rating
MOT: Maximum output torque rating
(Numbers from January edition of Fourwheeler, page 60.)
Dana 35 rear axle COT: 870 MOT: 3480
Dana 44 rear axle COT: 1100 MOT: 4460
Ford 8.8 28spline COT: 1250 MOT: 4600
Ford 8.8 31spline COT: 1360 MOT: 5100
Dana60 semifloat COT: 1500 MOT: 5500]
Rowdy115 10-02-2008 02:37 PM
Thanks for this, but I have seen this one before. Is there a comparison chart out there that compares the "Super" Dana 35 shafts to the others listed above? That is what I can't seem to find using Google.com What is the COT and MOT numbers for a 30 spline Super Dana 35 shaft?
Thanks.
Rowdy115 10-02-2008 02:42 PM
Originally Posted by never monday (Post 5461998)
There are postings of axle shaft failure torque rating. I won't repost them here because it doesn't represent what were discussing accurately.
where is this comparison of axle shaft failure torque rating that includes the Super Dana 35? The above link did provide alot of useful info on the stats of the axles, but this information was not in that thread. Anyone have a link to that comparo? Does a Super 35 shaft equal strength of a Dana 44, 8.8, or better? I don't know and would some info on just how strong they are.
Also, any chart that throws the shaft from the Super 8.8 in the comparo with the other axles would be some good information.
Thanks
never monday 10-02-2008 02:55 PM
too much in this post is factually incorrect
read up;
http://www.jeepforum.com/forum/showthread.php?t=583412
if you don't believe me, cross check the facts;
These number are misleading.
They compare stock shafts
Thanks
I think the magazines are afraid to perform this test.
A reasonable assumption of S35 shaft strength would be; equal to a D44 shaft made from 4130.
This would logically make it stronger than a regular 44 shaft.
Also keep in mind. The strength of an axle assembly is not based on just the shaft strength.
jeepster93 10-02-2008 03:07 PM
I've never seen a chart of breaking strength of a super axle. But they DO say that a super axle is 30 to 35% stronger. So just take those numbers above and add 35% to them. The super 88 does not include a locker and eliminates the c-clips, and adds 3/4 ton bearings.
I put a 30/30(AlloyUSA's version of a super 30) in a few years ago after a streak of axle issues, no issues sense.
I am convinced in super axles. They are worth having(just don't spend a lot on a dana 35).
Rowdy115 10-02-2008 03:14 PM
thank you for contributing on this post Never Monday. I did not intend to anger anyone when I posted on your thread regarding the Super 35/D44/8.8.
just new to the site and have been looking for a place to start an healthy discussion regarding this subject.
never monday 10-02-2008 03:45 PM
NP, I'm trying to keep that thread to the facts for people looking for a different axle.
this will be a good one for hashing out the opinion...and I have some
Rowdy115 10-02-2008 04:15 PM
Never Monday,
As I am sure you have realized, I have the 8.8 in my TJ. I'm not saying its better than anything else. Its just what I chose over a super 35 kit or dana 44 swap. You have mentioned on the fact that there are some common misconceptions about the 8.8 as a good swap canidate, but have not elaborated as of yet because the current thread was not the place to. I was just curious about your perspective. There may be something that I am not aware of. Please elaborate about the disadvantages of the 8.8. I already know about how its a custom set-up (not bolt-in), c-clip axle. But what else? This in not me being sarcastic, I am wanting to learn more on the subject, and I like the discussion.
Thanks
never monday 10-02-2008 04:21 PM
C-clip shafts
3 welds hold the tubes to the center (same as 35. 44 has 6)
increased tube dia = decreased ground clearance
increased casting = decreased ground clearance
none are bolt in for a TJ and require welding
offset chunk; not a big deal but won't work with a GenRight strech tank
thin cover
thiner tubes than a 35 or 44 (although the strength is about equal due to dia)
narrower track
no locker (S35 has a locker, R44 has a locker)
all can be over come. I just don't see enough strength gain to go through all the work. I do see the 8.8 as a viable, readily available axle to convert for a TJ.
silvrjeepr 10-02-2008 05:08 PM
IMHO If you're breaking S35's, then why not step up to a shaved 9" semi floater? You're not looking at that much more unless you slap a high pinion third on it.
Paulio91184 10-02-2008 05:14 PM
[QUOTE=never monday;5786482]too much in this post is factually incorrect
read up;
What is Incorrect?
never monday 10-02-2008 05:32 PM
.8.8 is like 120% stronger than the D35. not a tested and published statistic.
They are larger in dia, BUT thinner walled. There is rumor of a .250 wall housing. But of the 25 or so samples in a pull a part here all were .187. These were under everything from Mustangs, Explorers, F150 and, Crown Vic's.
just a much more robust axle and you get free disc brakes too!! not on all 8.8's
just make sure to weld the center section to the tubes if you do go this route...If you need to weld the casting to the tubes, how can it be a more robust axle?
answers in red
The time now is 11:04 AM.
