Question on manual transmission additive- newbie owner here - JeepForum.com
post #1 of 15 Old 10-30-2013, 12:07 PM Thread Starter
thedirtywaffle
So this is my second TJ, and I got a 2005 rubicon this time and in finding it a little difficult to shift compared to my 05 X.
I have this tube of JB gear oil treatment that I have used in a couple of motorcycle transmissions, and wondering if anyone here has used it before and if it would harm my trans in any way? This stuff has worked well in my other vehicles, but I thought if ask the pros on here before I stuff it in my jeep.
Thanks!
2005 wrangler TJ
thedirtywaffle is offline
post #2 of 15 Old 10-30-2013, 12:34 PM
2jhanna
have you tried changing the tranny's fluid with approved fluid, synchromesh compatable ?
jhanna
denton county, tx
2jhanna is offline
post #3 of 15 Old 10-30-2013, 12:44 PM Thread Starter
thedirtywaffle
Yes. I just changed the fluid about 1000 miles ago.
2005 wrangler TJ
post #4 of 15 Old 10-30-2013, 12:48 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Exactly/specifically what lube did you replace the old lube with?
Jerry Bransford is online now
post #5 of 15 Old 10-30-2013, 01:36 PM
tdavid14
There's other threads about the 6 spds being difficult, the fix is often Royal Purple Synchromax or equivalent.
Sent from my SPH-D710 using JeepForum
tdavid14 is offline
post #6 of 15 Old 10-30-2013, 02:14 PM Thread Starter
thedirtywaffle
I used Kendal versatrans full synthetic ATF ( equivalent to dextron 6 I guess) based on what was recommended to get by my local off road store.
2005 wrangler TJ
post #7 of 15 Old 10-30-2013, 02:18 PM
2jhanna
Wrong stuff.
Your tranny requires synchromax/synchromesh compatable fluid.
I would put the correct fluid in before trying any additives
jhanna
denton county, tx
2jhanna is offline
post #8 of 15 Old 10-30-2013, 02:20 PM
2jhanna
You have several choices to choose from, some synthetic, some non synthetic.
jhanna
denton county, tx
2jhanna is offline
post #9 of 15 Old 10-30-2013, 02:28 PM Thread Starter
thedirtywaffle
Ok. After reading a bit that's the thought I had. Yikes. Hopefully the stuff in there hasn't caused any harm. Is the fluid capacity correct at 1.58 quarts?
2005 wrangler TJ
post #10 of 15 Old 10-30-2013, 02:36 PM
2jhanna
Maybe you should visit the "sticky" section.
http://www.jeepforum.com/forum/f9/fa...cities-489932/
jhanna
denton county, tx
2jhanna is offline
post #11 of 15 Old 10-30-2013, 07:45 PM
Jerry Bransford
Administrator
Redline MTL is one of the very best synthetic transmission lubes made for your particular transmission. You can get it from www.summitracing.com. Our Jeep transmissions are fussy about their lubes, don't use just any "transmission lubricant".
post #12 of 15 Old 10-30-2013, 08:54 PM
J03_TJ
Mine's the NV3550, not sure what the OP has. When I notice mine shifting difficult I've found instant satisfaction after draining/filling it with the proper fluid. Happened 1st at about 50k miles, put the Royal Purple Synchromax in and it was smooth for 30k miles and then was acting fussy so I changed it again and was happy again. Been about 15k since. Always kind of wondered if the factory stuff being that it lasted 50k might be better than the Royal Purple, or my jeep just got to an age when it might be needing a fluid change every 30k? Guess I'll know in another 15k or so. I wonder if there is much of a difference in longevity/function between OEM, Synchromax, or the Redline MTL?
J03_TJ is offline
post #13 of 15 Old 10-30-2013, 11:58 PM
chris142
I realy like the rp stuff mysrlf. Mine holds about 2.
5 qts.
chris142 is offline
post #14 of 15 Old 10-31-2013, 06:17 AM
2jhanna
OPs, '05, has a 6 speed, NSG370, which holds a little over 1.5 qts.
jhanna
denton county, tx
2jhanna is offline
post #15 of 15 Old 10-31-2013, 10:48 AM Thread Starter
thedirtywaffle
Thanks guys. I just picked up a couple quarts of the RP synchro max and am going to change the fluid tonight, providing that the trick-or-treaters let me get it done lol. Thanks for the help!
2005 wrangler TJ
