Question for D30 U-joint replacement - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Question for D30 U-joint replacement
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueStainless Steel Door Hinge PinsPoly Door Hinge Bushings
Unread 08-15-2006, 07:57 PM   #1
edzakory
I plan on changing the front U-Joints on my D30 front axle w/Spicer 5-760X replacements. I recently put in Aussie lockers and changed the gear lube with Royal Purple Max Gear 75W90 synthetic.
Is it necessary to drain the differential to pull the axle(s)? I thought I might be able to jack one side up at a time higher than the differential case to prevent oil from leaking out the seal.
Will this procedure work or does anyone have some suggestions that may have changed U-joints without draining the differential?
Thanks
edzakory is offline   Reply With Quote
Unread 08-15-2006, 08:30 PM   #2
JamboreeTJ
1946 CJ2A
You "should" be OK on level surface. Standing still, the oil should be just below the seal. I've seen them pulled without draining the diff. Last one was at our club's tech day with one of the TJs up on a lift at a local shop.
JamboreeTJ is offline   Reply With Quote
Unread 08-15-2006, 08:51 PM   #3
Stu Olson
Stu Olson's Avatar
Agreed....I routinely pull the shafts on mine without any leakage of diff lube.
Stu Olson
ARB Locked & Loaded
www.stu-offroad.com
Stu Olson is offline   Reply With Quote
Unread 08-16-2006, 06:50 AM   #4
Pottymouth
Location: 30 minutes south of Baghdad....oops....I mean Detroit.
I concur with the above two statements. When I changed both of my front axle U-joints, I didn't do anything to the diff. Pull off the wheels, brake calipers (be careful of the brake lines), rotors, unscrew the hub assembly, and the axle shafts should slide right out. Just be very careful when you are pulling the shafts out (and putting back in), you do not want to tear the seal in the housing.
1997 Jeep Wrangler TJ - Red
2.5L 4cyl - 5 speed
33 x 12.5 x 15 Mastercraft Courser MT
10" Kicker Compvx Subwoofer
350W Kicker Amp
A big back seat for some fun with the lady friends
Pottymouth is offline   Reply With Quote
Unread 08-16-2006, 08:10 AM   #5
jayr
Thanks
slightly but I want to do the same and was wondering if you are running stock shafts with these u-joints? IOW will the Spicer 5-760X joints work with D30 stock shafts on newer (97-06) TJs?
TIA
jayr is offline   Reply With Quote
Unread 08-16-2006, 09:59 AM   #6
edzakory
Yes; I am running stock axles on my D30. I was going to upgrade the axles but understand that they donít have the breaking problems the D35C have.
I did a cross check with NAPA and the Dana Spicer 5-760X is the number listed for my 2000 TJ. I read where these may not work on all D30 axles; probably before the new TJ in í97. NAPA does not sell Spicer anymore and have gone to Precision Gear made by Federal-Mongul. They looked like a good HD unit but my preference was for the upgraded Spicer model. They are hard to find local so I have to order via Internet/mail-order.
