question on cowl snorkel write up... - JeepForum.com
post #1 of 12 Old 07-18-2008, 01:39 PM Thread Starter
majkowskid
i was interested in doing the cowl snorkel mod that someone outlined on here. seriously looking into it.
but i was thinking, how much more clearance are you actually gaining? the airbox on my jeep is on the front right fender, with the opening facing up. placing it in the cowl maybe gains 6 more inches right? or is there something i'm missing?
majkowskid is offline
post #2 of 12 Old 07-18-2008, 01:46 PM
esad_b
your not gaining just 6inches, your gaining the height of the pipe over the hood and over your roof.. your gaining as far as the air opening (top) goes. do you understand what i mean? Like in the pic he can go as deep as the red line
But if you go as deep as the red line, your looking at some serious problem, loosing control of the jeep and probably getting taken by the stream...
esad_b is offline
post #3 of 12 Old 07-18-2008, 01:46 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
what your missing is that water crossings and streams usually involve dipping down quite a bit to actually get into the water. often your headlights will become submerged, but once your in the stream, water will be up to the doorsill or turn signals (about 3-6 inches below the stock horn).
if you're cowl deep in water, you've got bigger problems than wondering if your engine is breathing, like how you're going to get out of the jeep so you don't drown.
if you're headlight deep in water, then you should be worried about your engine.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #4 of 12 Old 07-18-2008, 06:46 PM
Border Dave
Got Sand?
Border Dave's Avatar
Don't forget about the benefits of drawing cooler air into your engine with using a cowl snorkel. Power and mileage might be slightly better.
My favorite shops in the Northwest:
Border Dave is online now
post #5 of 12 Old 07-18-2008, 08:40 PM Thread Starter
majkowskid
maybe i didn't state it clearly. i understand a REGULAR TOTAL SNOKEL... i mean the semi snorkel setup people are doing putting an open air filter under the windshield wipers. doesn't it get wet there every time it rains or anything also? those vents allow rain and everything in....
post #6 of 12 Old 07-22-2009, 12:40 PM
JeepDVL45
Back in the game
JeepDVL45's Avatar
Unlimited04 hit the nail on the head. When you drop in to water the front end of your Jeep will submerge, then when you get you butt-end in you will sit level again --think of driving down a hill when you reach the bottom, you nose down until you get level again -- its the same thing, except with water. Moving the intake back from your grill makes it harder to get water into the airbox
And yes water gets in, but there is a drain for the water in your cowl, otherwise the water will drain into your Jeep through the AC/Heater intake (if you didn't have the cowl intake). The cone filter doesn't sit directly under the cowl vent so it doesn't get directly wet from rain/water, and in most cases, from what everyone as written up, it actually stays VERY dry, the drain in the cowl apparently has a good amount of flow to keep it dry in there.
NOTE: I have not put a cowl intake in my jeep, yet.... That is actually this week's project, I've been reading up on any, and every thread I can find on it, on this forum and many others. This by no means makes me an expert (or even close to it), but it seems like a common queation about this set up, one that I asked myself a couple times.
JeepDVL45
"Real men hide their feelings, WHY?!
BECAUSE IT’S NONE OF YOUR ****** BUSINESS!!!!
Men do not cry. Men do not pout. Men jack you in the ******* jaw and say…thanks for comin’ out." - Boondock Saints II
JeepDVL45 is offline
post #7 of 12 Old 07-22-2009, 06:05 PM
crusher242
If your going to do it, go for a Hummer style setup. You'll love it.
Hold onto something... Quick!!!
crusher242 is offline
post #8 of 12 Old 07-22-2009, 06:41 PM
biffgnar
biffgnar's Avatar
If you are worried about the filter getting wet, do the buick or windstar (or one of the other options) airbox mod. I have the windstar which has the airbox under the hood so all that goes through the firewall is the trumpet. It is off center to the vent and intake is perpendicular to the way water would come in. Its also a couple inches off the bottom of the cowl, so the drain (which is pretty big in my 06) would have to clog and cowl would have to fill. Water may actually drain through the AC before getting in to the trumpet. I even went ahead and put on backward facing cowl scoop covering the vent but that was overkill.
biffgnar is online now
post #9 of 12 Old 07-22-2009, 07:22 PM
Border Dave
Got Sand?
Guys, this thread is over a year old. You know that, right?
post #10 of 12 Old 07-22-2009, 07:22 PM
rubicon1000
if u are going to do it, do the hummer style thats what i did and i love it first i tryed the filter sitting under the cowl at the one end away from the vent. but the only problem was i was out of the country for 35 days and came home to my engine being full of water because the drain was cloged from crap and heavy rains added up to a hydro locked motor kind of scary to come home too. so i thought it was time for the hummer snorkle and i love it dont worrie about anything anymore flying thru big puddles here in fl. look at my past replys under my user name and u can see my pics and my set up with the real 4.5 inch hummer snorkel cap
'12 unlimited sport S, 3.73, trac loc, towing package, rubicon unlimited springs and shocks
SOLD 03 Rubicon , nv 3550 ,4'' RC lift ,1'' RC MM lift, 1.25'' body lift, HD rear bumper, hummer snorkel cap with buick airbox and custom piping, 265/75 r 16 tread wright retread mud tires on stock rubicon wheels, smitty built 8k winch, cobra cb radio, rrc front bumper, pre-runner rear bumper, HID headlights in Hella housings
rubicon1000 is offline
post #11 of 12 Old 07-22-2009, 07:24 PM
rubicon1000
oh yeah haha
post #12 of 12 Old 07-23-2009, 07:23 AM
JeepDVL45
Back in the game
JeepDVL45's Avatar
HAHA just caught that too. I just saw the date, I never looked at the year..... I'll bite, I'm the dumb*** that revived it.
JeepDVL45
JK Custom Cowl Snorkel? warCryr JK Wrangler Technical Forum 111 11-07-2015 12:53 PM
cowl air intake write up badoosh27 TJ Wrangler Technical Forum 10 12-28-2011 11:16 AM
Snorkel into cowl vent? RODKNOCKER YJ Wrangler Technical Forum 4 02-27-2005 11:01 PM
cowl snorkel Dome TJ Wrangler Technical Forum 2 11-08-2003 11:21 PM
YJ cowl intake (snorkel). BamaJeeper YJ Wrangler Technical Forum 8 03-13-2003 01:46 AM
