Question - Check engine light - JeepForum.com
post #1 of 4 Old 04-16-2007, 03:28 PM Thread Starter
odie6423
I've recently bought an '02 4cyl Wrangler. After noticing my check engine light on I found that my gas cap was loose. Assuming this is the only issue, what is the cheapest way to get the light off? Will it shut itself off over time? Will unhooking the battery reset the computer? And more importantly, will fixing this on my own show up in a future diagnostic and void my Limited Drive Train Warranty? Any help is appreciated.....thanks.
odie6423 is offline
post #2 of 4 Old 04-16-2007, 03:35 PM
Conundrum
Conundrum's Avatar
Disconnect the battery for about 5 minutes.
Matt
2001 Jeep Wrangler Sport 4.0L - Amber Fire Pearl Coat
1981 DeLorean DMC-12 VIN: 2953
Conundrum is offline
post #3 of 4 Old 04-16-2007, 04:18 PM
westmichjeeper
2009 JK Wrangler
drive for about 50 miles or so and the lite will shut off
but be sure gas cap is tightly sealed or it will not turn off
i had this happen to me twice once some one stole my gas cap and once i did not remove ice from around seal
2009 jk wrangler 2 dr 3.8 V6
with 285 70 r17 bf all terrians
westmichjeeper is offline
post #4 of 4 Old 04-16-2007, 05:10 PM
kloppk
Take it to you local Autozone. They will scan the computer for FREE and tell
you what the problem(s) that caused the light to go on.
They can also turn the light off too.
Of course if there is still a problem the light will be back on in a while.
kloppk is offline
check engine light question 92renegade YJ Wrangler Technical Forum 17 01-15-2010 07:38 PM
check engine light question greta TJ Wrangler Technical Forum 3 06-15-2009 11:18 AM
Check engine light question agent_J TJ Wrangler Technical Forum 2 08-17-2008 05:43 PM
check engine light question? REDPILL TJ Wrangler Technical Forum 3 10-12-2006 11:32 AM
Check engine light question Jim Smyth TJ Wrangler Technical Forum 4 05-20-2005 05:18 AM
