Question about windshield wiper assembly - JeepForum.com
post #1 of 12 Old 09-27-2010, 06:27 PM Thread Starter
gbvTJ
I removed my wiper assembly so that I could install a new wiper motor for my 2000 TJ. When I installed it back in, the wipers don't touch the windshield!! Has anybody ever had this issue?? I moved i around and tried to adjust in different ways, but nothing has worked... Thanks
gbvTJ is offline
post #2 of 12 Old 09-27-2010, 06:52 PM Thread Starter
gbvTJ
Bump
gbvTJ is offline
post #3 of 12 Old 09-28-2010, 10:23 AM Thread Starter
gbvTJ
bump
gbvTJ is offline
post #4 of 12 Old 09-28-2010, 10:24 AM
YellowX
YellowX's Avatar
don't touch the windshield how?
Fred
JAFGJ
YellowX is offline
post #5 of 12 Old 09-28-2010, 10:27 AM Thread Starter
gbvTJ
There is no contact made between the wipers and the windshield. Its about half an inch of the windshield. This wasnt an issue before I uninstalled the wipers
gbvTJ is offline
post #6 of 12 Old 09-28-2010, 10:28 AM
YellowX
YellowX's Avatar
Sounds like you need to pull the little clips out further to seat the arms better on the gear. If you pull on the arms now, they just pop off, right? There should be a little tab underneath that pulls out.
Fred
JAFGJ
YellowX is offline
post #7 of 12 Old 09-28-2010, 10:31 AM Thread Starter
gbvTJ
Yea I have tried that. The tabs are completely pulled out all the way, and the arm sits in as flush as it can. I was wondering if there is anything on the wiper assembly that can be adjusted.
gbvTJ is offline
post #8 of 12 Old 09-28-2010, 10:39 AM
YellowX
YellowX's Avatar
Not that I know of. Did you remove the armature under the cowl, as well as the motor? Or just the motor?
Fred
JAFGJ
YellowX is offline
post #9 of 12 Old 09-28-2010, 10:39 AM
MAMMOTH
Wooly Member
MAMMOTH's Avatar
Push the clips in. This locks them on the mechanism.
When they are pulled out it keeps the spring from folding all the way down.
2004 TJ Rubicon - 3" lift, 1" BL, Brown Dog MML with Super brackets, 33's, Warn Winch, VanCo BBK - (Thanks MisfitSeven), IronRock tierod, Ten Factory shafts.
Future upgrades - Too many to list
1999 XJ - DD with 228k
2007 JK Unlimited - The wife's ride.
MAMMOTH is offline
post #10 of 12 Old 09-28-2010, 10:42 AM
Strebs
Exactly. When the tab is pushed back in, the wipers will be closer to the windshield.
Strebs is offline
post #11 of 12 Old 09-28-2010, 10:57 AM Thread Starter
gbvTJ
im an idiot! Thanks guys!!! Jeep Forum to the rescue again!
gbvTJ is offline
post #12 of 12 Old 09-28-2010, 11:46 AM
MAMMOTH
Wooly Member
MAMMOTH's Avatar
Anytime! JF has bailed me out many times as well.
MAMMOTH is offline
Windshield wiper motor question.... ShowStopper YJ Wrangler Technical Forum 6 08-02-2010 09:12 AM
Windshield Wiper assembly. skidawgz YJ Wrangler Technical Forum 1 09-13-2009 04:19 PM
Windshield wiper question liquidforcedude TJ Wrangler Technical Forum 3 03-15-2008 06:14 PM
Question about Driver's Side Windshield wiper arm... x19delta YJ Wrangler Technical Forum 5 04-25-2005 12:42 PM
Windshield Wiper Question lXl Rebel Wrangler lXl YJ Wrangler Technical Forum 16 06-22-2002 11:56 PM
