Question About Rearview Mirror W/ Compass and Temp. - JeepForum.com
post #1 of 5 Old 10-15-2006, 02:17 PM Thread Starter
Nick B
My mirror on my 06 shows the compass heading but for temp it just shows " OC ".
Can anybody help ? TIA, Nick
Nick B is offline
post #2 of 5 Old 10-15-2006, 02:34 PM
mjm
mjm's Avatar
I had a similar problem when I installed my mirror. You probably have an open circuit somewhere. Check to see if the connection to the temp sensor on the driver's side lower front grill has come off or loose.
Good luck,
Mike
mjm is offline
post #3 of 5 Old 10-15-2006, 08:36 PM Thread Starter
Nick B
Good luck,
Mike
Mike can you be a little more specific on where to look ? I'm not clear on what grill you are talking about.
Thanks, Nick
Nick B is offline
post #4 of 5 Old 10-15-2006, 10:01 PM
Rocky529
Rocky529's Avatar
Thanks, Nick
The front 7 slot grill, the temperature sensor should be on the left side of the grill.
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline
post #5 of 5 Old 10-15-2006, 10:06 PM
mjm
mjm's Avatar
Standing in front of your Jeep, look down at the bottom of the front grill. Between the radiator and the bars of the grill, you should see two temperature sensors. These sensors are located at the bottom corners, one on each side. The one on the passenger side is connected to the computer. The one on the drivers side is connected mirror. These sensors are black plastic pieces with a tip on them smaller than a pencil eraser. The connector should not have come loose. TGHere could also be a loose wire somewhere else in the wiring harness. This is covered under your warranty.
I had the OC error when I installed the mirror, but did not install the temerature sensor that was included in the kit. I had to find one that already had the mirror to find out I needed the other sensor.
mjm is offline
Need assistance in removing temp/comp rearview mirror CCJ TJ Wrangler Technical Forum 8 02-05-2009 04:44 PM
Mirror compass temp problem skruske TJ Wrangler Technical Forum 1 08-17-2007 07:08 AM
Temp/Compass Mirror Hiccup? ironpony TJ Wrangler Technical Forum 5 11-10-2005 12:49 AM
temp/compass mirror? silverstone01 TJ Wrangler Technical Forum 5 10-08-2004 09:21 PM
03-04 Compass / Temp rear mirror Questions Help! Tmsnake1 TJ Wrangler Technical Forum 8 12-30-2003 05:45 AM
