Question about lift kits and spacer kits. - JeepForum.com
post #1 of 5 Old 01-11-2009, 04:48 PM Thread Starter
EvanQuinn
Hi guys, first post here. I have a 2003 black rubicon with a 3" bds suspension lift and a 3" bds body lift. I had an old '97 sahara that i flipped, that had a 4 1/2 inch bds suspension, and a 3 inch bds body lift. I was wondering if I could add a spacer kit to my new jeep to make it a little bit higher like my old one. I don't know if this is possible to have with a body and suspension lift. Thanks guys.
Btw: I don't know much about jeeps, I just like the way they look. Spicer automotive does all of my mechanic work for me in north georgia.
cheers
EvanQuinn is offline
post #2 of 5 Old 01-11-2009, 04:57 PM
neatocj
1981 CJ5
hhmmmm....
Well ditch the gigantor body lift, that much stress on the body mounts can push those pucks right through the floor (actually happened to my friend TODAY).
If you want height just stick a one or two (max) inch body lift get a budget boost kit (spacers for the coils) and the tallest suspension kit you can find.
By the way Welcome to the forum!!
Your not pushing the limits of your jeep until your on your side, then something breaks and it's time to go home.
'70 Camaro - Almost Done
'81 Cj-5 - SOLD
'06 MegaCab Cummins- Great White
neatocj is offline
post #3 of 5 Old 01-11-2009, 05:01 PM
Hesher420
Welcome to the forum.
What size tires are you running?
Do you have any pics of you're current setup? (Maybe you can post a link to them.)
And.... what ^that^ guy said.
"We are one. One society. Digitless."
"I am not a number, I am a free man!"
Hesher420 is offline
post #4 of 5 Old 01-11-2009, 05:12 PM Thread Starter
EvanQuinn
Thanks!
Thanks guys, I am running 35" pro comp all terrains right now.As for the picture, I'll try and get one asap! so you guys are saying I should ditch the 3" body lift, get a 1" or 2" body, and get a spacer and put it around my coil springs? so i can have all 3 at once? hope so!
post #5 of 5 Old 01-11-2009, 05:21 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
drop down to a 1" BL, and buy a real 4" spring lift kit WITH adjustable control arms. anything over 2" and you get into territory requiring longer control arms.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
Quick Question about Buying Lift Kits crankyhobo YJ Wrangler Technical Forum 3 04-07-2009 04:42 PM
question about 4wd hardware lift kits cvdberg13 TJ Wrangler Technical Forum 1 06-23-2008 12:24 PM
Questions about 2" spacer kits roblee TJ Wrangler Technical Forum 3 05-08-2008 11:08 AM
Question On Lift Kits stonehogg TJ Wrangler Technical Forum 2 11-21-2005 04:39 PM
The 2" Spacer Lift Kits by Skyjacker Cidk TJ Wrangler Technical Forum 1 03-27-2003 07:08 PM
