Question about Dana 30 to G2 Dana 44 front swap - Page 3 - JeepForum.com
post #31 of 32 Old 04-08-2013, 08:28 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Originally Posted by btn View Post
And the whole reverse thing with a high pinion axle is ridiculous. I don't know though, maybe you like a challenge and do trails in reverse.
It's not about doing trails in reverse, its about torque peaks when backing in reverse, even though rare. For example, backing uphill whilst pulling someone else out. I guess the u-joints or shafts would probably fail first, but the R and P would see a lot of stress in a situation like that. Just because an axles does almost all of it's work in one direction doesn't mean it won't see greater torque loads in the rare opposite direction.
In reality, it may not be a problem for people. But surely the R and P would see it's greatest stresses in such an uphill backing, towing situation.
When they introduced the 4:88 gears for the low and high pinion Dana 30's, the internet logic said that because the pinion was so tiny that they would explode if you even got them near a trail.
The theory was sound in that a smaller pinion is or has the potential to be weaker, actual practice has proven that to not be an issue.
You are correct in that it will be weaker driven on the coast side backing up hills. You are incorrect in that it will likely ever be an issue.
I am Savvy
blackmagicbrakes.com
mrblaine is online now
post #32 of 32 Old 04-08-2013, 07:29 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Originally Posted by koreyb10 View Post
i know this thread is old But i just bought a G2 dana 44 4.56 and a Eaton E-locker for my 02 Tj to swap in for my stock D30. i have it totally bolted up. but obviously my front drive shaft is too long. i was just wondering if anybody out there knows what the correct length would now be? i am considering measuring and having a machine shop cut and balance it for me. or buy a custom Tom woods. But it would make my life easier if someone had already done this swap and knows what the dimensions are. My jeep is a 4.0 5 speed NV 3550 tranny and NV 231 T.C.
You should measure on your specific setup.
There are too many variables to ask someone else about this.
Wheelin98TJ is offline
axle , swap , dana 30 , dana 44
Dana 35 to Dana 44 swap question? Grim Jeeper TJ Wrangler Technical Forum 38 01-31-2014 03:36 AM
my dana 35 snaped again can i swap the parts out of a 1990 dana 35 from a cherokee bulickmcj TJ Wrangler Technical Forum 7 04-02-2009 11:42 AM
Front Bronco Dana 44 Axle swap Question! jamesfromcanada YJ Wrangler Technical Forum 7 04-05-2006 10:05 PM
Front Dana 44 Swap Help! Nickb1907 TJ Wrangler Technical Forum 17 12-22-2005 07:44 PM
QUESTION: front axle(DANA 30) why does mine look like a DANA 35 713JeepTJ TJ Wrangler Technical Forum 5 03-06-2005 08:20 PM
