Question about Dana 30 to G2 Dana 44 front swap - Page 2 - JeepForum.com
post #16 of 32 Old 11-09-2010, 06:21 PM
skyAdam
Originally Posted by btn View Post
I don't get it? It's the laws of physics and mechanics, right? It's not my fault that that's how they work.
Are you paying someone else for the gear setup and everything? Maybe then the price is similar. How much strength are you gaining with an inch of ring gear? You're still using the same bj's, knuckles and outers.
You also realize that you'll only get an extra 1/2" of clearance after the larger pumpkin gets factored in with the new tires.
As for hard parts for the swap, it's gears, bearings and balljoints. What's that, about $400 plus housing? It's the perfect time to learn how to set up gears as it's way better to learn working in a comfortable position on the bench instead of on your side under the jeep.
The HP30 is high up on my swap list. For the actual amount to upgrade the housing as opposed to trying to recoup some of my losses by selling my used d30 stuff it makes sense to me. As soon as this ring set goes I'm hitting the junkyard.
skyAdam is offline
post #17 of 32 Old 11-09-2010, 06:50 PM
pcoplin
If you're against the HP30 (not sure why, been running mine for years), I wouldn't do the LP44. In fact, I wouldn't put low pinion anything in the front.
Take a look at the Currie front 9in with their HP center section. Bolt in, and can reuse your outers.
pcoplin is offline
post #18 of 32 Old 11-09-2010, 08:47 PM
btn
HP front axles are weak whilst torquing in reverse and the 30's R&Ps are small to begin with. The bigger TJ 44 R&P can handle reverse torque peaks yet has a margin of strength in the lesser forward torques due to the larger R&P.
Currie and Dynatrac HPs would be great as they are stronger than a HP30 as far as R&Ps are concerned. I just don't understand them to be necessary if not going over 35" tires. I don't plan on going over 35s, so I want to avoid the weight burden of them.
btn is offline
post #19 of 32 Old 11-09-2010, 09:26 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
Why are you stuck on this reverse thing? I've never seen a front axle R&P break in reverse just as I've never seen anyone do a full throttle rock ledge assault in reverse.
A you high? if you are not going over 35's the clearance penalty of the lp44 (compared to the equivalent or stronger hp30 when traveling in the same direction the rest of us tend to drive off highway.) makes no sense. Your current parts have lifetime warranties don't they?
ratmonkey is offline
post #20 of 32 Old 11-10-2010, 12:22 AM
pcoplin
Yeah, I don't understand the whole reverse thing. I think you've been reading too much on the internet, and don't have any experience. I, and others, are telling you a Hp30 would suit you just fine.
pcoplin is offline
post #21 of 32 Old 01-15-2011, 03:35 PM
christiansteele
I have a HP 30 right now with 36" tires i broke my carrier pin last week and now next week i am geting the g2 dana 44 with a detroit installed for under 3k anyone want a hp dana 30?
christiansteele is offline
post #22 of 32 Old 01-16-2011, 03:26 PM
revoffroad
lol. G2 dana44.....can't wait. I'll be getting one when I get out of afghan.
revoffroad is offline
post #23 of 32 Old 03-29-2011, 06:35 PM
whitesandsjeep
Just reading this thread was making me laugh. Trust me I am also laughing at myself. I swaped in the G2 RJ60 rear and and the 44 front till I can afford the RJ front. My heep has been sitting on jacks for months because I am waiting till I can afford my LA lift with front and rear stretch. I would love to be driving it but cant see buying so many drive shafts. So the LESSON is have your entire build planned with the proper budget ready to spend. By adding the larger axles I didnt take certain things into account. For me lesson learned. Damn HEEP!
whitesandsjeep is offline
post #24 of 32 Old 04-07-2013, 07:05 PM
koreyb10
i know this thread is old But i just bought a G2 dana 44 4.56 and a Eaton E-locker for my 02 Tj to swap in for my stock D30. i have it totally bolted up. but obviously my front drive shaft is too long. i was just wondering if anybody out there knows what the correct length would now be? i am considering measuring and having a machine shop cut and balance it for me. or buy a custom Tom woods. But it would make my life easier if someone had already done this swap and knows what the dimensions are. My jeep is a 4.0 5 speed NV 3550 tranny and NV 231 T.C.
koreyb10 is offline
post #25 of 32 Old 04-07-2013, 07:42 PM
freeskier93
G2 front 44 ins't an upgrade. G2 buys Rubicon D44 front ends from the factory and builds them. As for bolt in axles the Dynatrac ProRock 44 is the only real upgrade D44. A RJ 60 or fabricated 9" would other options. Everything else is going to require fab work.
And the whole reverse thing with a high pinion axle is ridiculous. I don't know though, maybe you like a challenge and do trails in reverse.
Last fall I was wheeling with unlimited04, can't remember why but we backed up a pretty steep hill and parked. I think we were looking at the view (high altitude). We both have high pinion 30s, guess what, nothing broke!
freeskier93 is offline
post #26 of 32 Old 04-07-2013, 09:18 PM
btn
It's not about doing trails in reverse, its about torque peaks when backing in reverse, even though rare. For example, backing uphill whilst pulling someone else out. I guess the u-joints or shafts would probably fail first, but the R and P would see a lot of stress in a situation like that. Just because an axles does almost all of it's work in one direction doesn't mean it won't see greater torque loads in the rare opposite direction.
In reality, it may not be a problem for people. But surely the R and P would see it's greatest stresses in such an uphill backing, towing situation.
2000 TJ, 4.0L, 4" suspension lift, 35s, rear D44 and front HP30 both with ARBs. AX15, 4:1 T-case.
btn is offline
post #27 of 32 Old 04-07-2013, 09:19 PM
btn
Were you trying to pull someone else out when you backed up? If not, then no, nothing probably broke.
It's not about doing trails in reverse, its about torque peaks when backing in reverse, even though rare. For example, backing uphill whilst pulling someone else out. I guess the u-joints or shafts would probably fail first, but the R and P would see a lot of stress in a situation like that. Just because an axle does almost all of it's work in one direction doesn't mean it won't see greater torque loads in the rare opposite direction.
You can argue if you like, but physics is physics. That's just how gravity and force vectors all work.
btn is offline
post #28 of 32 Old 04-07-2013, 09:23 PM
RaggedOleMan
If reverse situations are your concern, then just keep the low pinion 30...it's as strong in reverse, as the hp30 is going forward...
RaggedOleMan is offline
post #29 of 32 Old 04-07-2013, 10:27 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
I like the driveshaft clearance...
Knuckelhead is offline
post #30 of 32 Old 04-08-2013, 07:55 AM
freeskier93
Stop trying to come up rediculous scenerios where stuff breaks. Wheel smart, don't be stupid and you'll be fine. Don't think about it so much and just go have fun. Even if you threw 60s under your rig you could come up with various scenarios where you break stuff.
Stop overanalyzing and just go wheel!
axle , swap , dana 30 , dana 44
Dana 35 to Dana 44 swap question? Grim Jeeper TJ Wrangler Technical Forum 38 01-31-2014 03:36 AM
my dana 35 snaped again can i swap the parts out of a 1990 dana 35 from a cherokee bulickmcj TJ Wrangler Technical Forum 7 04-02-2009 11:42 AM
Front Bronco Dana 44 Axle swap Question! jamesfromcanada YJ Wrangler Technical Forum 7 04-05-2006 10:05 PM
Front Dana 44 Swap Help! Nickb1907 TJ Wrangler Technical Forum 17 12-22-2005 07:44 PM
QUESTION: front axle(DANA 30) why does mine look like a DANA 35 713JeepTJ TJ Wrangler Technical Forum 5 03-06-2005 08:20 PM
