question about bump stops - JeepForum.com
post #1 of 4 Old 07-12-2010, 02:38 AM Thread Starter
hritz77
hi do I need to use extended bump stops with a 2" pro comp spring lift? I was told its not necessary. if that is not true and I do need them can you recommend the ones I should use.
Thanks
. _ ____
[l_,[____],
l---L -Olllllll O-
()_) ()_)--)_)
2003 Sport
hritz77 is offline
post #2 of 4 Old 07-12-2010, 05:22 AM
Fropleyqk
Fropleyqk's Avatar
2014 JK Wrangler
The only way to really know for your jeep is to jack up your axle one wheel at a time and see if anything hits before the bumpstop. Keep an eye on your front trackbar/diff cover. Try turning the front wheels left and right keeping an eye on the steering linkage as you lift as well.
Someone else's jeep with the same setup may need them while yours doesnt or vice versa.
Fropleyqk is offline
post #3 of 4 Old 07-12-2010, 05:28 AM
g4x4xgeoff
I agree completely. only way to know is to test.
Originally Posted by Hurley91 View Post
I could be drunk, high, raped and almost dead.... and I could still recognize it.
g4x4xgeoff is offline
post #4 of 4 Old 07-12-2010, 07:28 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
you're on the right track...to add/correct some of that
basically do this for each axle:
1. Remove springs.
2. Reconnect shocks and all suspension components.
3. Lift axle up/lower frame down to bring bumpstops to set on the spring pad.
4. whatever hits first, thats how much bumpstop you need.
5. diff cover might hit track bar, shocks might bottom out, brackets might hit someplace, or maybe nothing will happen.
6. a lot will depend on the collapsed length of the shocks.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
tj , wrangler , bumpstops , bump , suspension
Bump stop extenders pushing past Bump stops. KraZeDav YJ Wrangler Technical Forum 5 09-12-2009 04:57 PM
are the bump stops suposed to hit when i go over a bump? MC_NickP TJ Wrangler Technical Forum 10 03-01-2009 07:40 PM
bump stops for 93 598BBC YJ Wrangler Technical Forum 1 11-08-2008 02:48 PM
Bump Stops Question OrangeSteel TJ Wrangler Technical Forum 4 07-22-2008 07:45 AM
Bump stops mckaax TJ Wrangler Technical Forum 2 12-01-2006 08:58 AM
