#1 | |
putting top back up?
im a noob to this jeep stuff and just trying to learning everything the right way...it seems when im putting the top back up that it is a real pain to get all the plastic to pop back in on the two side back windows...are there any secrets or tips and tricks to make putting the top back up easier and quicker?
thanks
#2 |
zip the windows half way then pop all the plastic in, and then continue to zip up the windows the rest of the way
2004 Black Rocky Mountain Edition, Clayton 4 Linked w/ 4" Pro Comp Springs and MX6 Adjustable Shocks, 37" Iroks |
#3 | |
2006 Jeep Wrangler Unlimited (SOLD! Will be back in the jeep world in the future!) 2004 Ford Mustang Cobra Billet flow 2.76" pulley/idlers, 17x9/10.5 black cobra wheels, nitto nt555's, corbeau fx1's, corbeau 5 point harnesses, maximum motorsports roll bar, mgw short throw/shifter knob, jlt ram air, slp cat back, SRA in the works |
#4 |
Actually I just get the zipper started (like only an inch!!!) then I do the vertical plastic retainer (the one behind the door), then I zip the rest of the way, then I do the bottom retainer starting at the back and going forward.
First time I went to put my top up, it took me and a friend about 45 minutes. I've got it down to 10 minutes or less now by myself. Just takes practice and experimentation.
2003 TJ X Silver | 31x10.50x15 BFG A/Ts | 10k front tow hooks, factory rear tow hook | 2" coil spacers | Cobra 19 with RatShack 102" stainless whip on an Arizona RockyRoad tire carrier mount | Kilby Steering Box Skid | AtoZ Fabrication Rock Sliders | Olympic Slider Rear Bumper w Receiver | Skid Row Engine/Oil/Tranny skid (still sitting in my living room) |
#5 |
i zip an inch or so like bradg, then front plastic, then bottom plastic, then zip all the way. the most important thing i've noticed is to store the windows flat and not let them get deformed while they are being stored. the deformation creates tension when you go to zip them in. this took me 4 or 5 top up/downs to realize... i'm kinda slow
![]() oh and put a key ring through the zipper pull tab thing.
99 TJ, 3" sus lift, 33x12.50 mickey baja MTZ's, MM SE9500C winch .... more in the works ;D |
#6 | |
#7 |
sometimes unclasping the front clamps (but leaving them hooked in) gives you the extra bit of slack you need to get the back retainers in.
2006 TJ SE - Does what I want it to do. [URL="http://www.combatsylvania.com"]http://www.combatsylvania.com[/URL] |
#8 |
I always hook my top latches in the front but dont close them.. then zip an inch or two on the side window and put in the front retainer.. zip across the top and then do the bottom retainer.. as for the back 1/4 pieces you can pull down slightly on the top bow after you have the front latches hooked and those will pop right in.. then you can slide them either direction easily to zip in the sides or the back.. once you get all the windows in then I close the front latches and pop the plastic strips in above the windows.
-Christopher
Ordered 2008 4dr 11/24/07 got it 12/28/07 - mall crawler - goin for gadgets on this one. COMFORT Jeep Memories: 76 Cherokee Chief - got rusty (sold) 97 TJ Sahara 5sp soft top - mudded,sanded,rocked,sunk(sold) 00 TJ Sport 5 sp soft top - mudded, rolled in a blizzard{no damage except top} (sold) 02 TJ Sport auto soft top - roadtripped,mudded (sold) 06 TJ gold eagle 6 sp soft top- not enough room (sold) Number 10 million of the 'I Love my JeeP' Club |
#9 |
Watch this video: Owner's Manual (TJ) Video
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
