-   TJ Wrangler Technical Forum (http://www.jeepforum.com/forum/f9/)
-   -   Putting Savvy Armor to the Test (http://www.jeepforum.com/forum/f9/putting-savvy-armor-test-1280685/)
steve578 10-24-2011 05:27 AM
I was able to test out all the Savvy products that I installed last month for the first time. I put the armor through some of the toughest trails at Green Acres in Clayton, OK. Here are the trails that we ran.
Day 1 - "Jeff's Ledges" - "Green Mamba" - "Green Mamba Extension" - "8-Point"
Day 2 - "Access Road/Walter's Mule Trail" - "Cake Walk" - "Black Sheep"
Everything held up well, but I was able to put a few scratches on them. :cool:
Let's start out with the Under Armor. I gave it a light tap to start the day off.
http://i86.photobucket.com/albums/k1...1/IMG_4248.jpg
It provides excellent clearance underneath!
http://i86.photobucket.com/albums/k1...1/IMG_4313.jpg
http://i86.photobucket.com/albums/k1...1/IMG_4315.jpg
How about a look at the Under Armor?
http://i86.photobucket.com/albums/k1...1/IMG_4319.jpg
steve578 10-24-2011 05:28 AM
Next up is the corner armor. I decided to test it out by laying the Jeep on its side.
http://i86.photobucket.com/albums/k1...1/IMG_4333.jpg
I must have hit it just right. Minor scratching on the corner armor and door, but it got my tub.
http://i86.photobucket.com/albums/k1...1/IMG_1759.jpg
http://i86.photobucket.com/albums/k1...1/IMG_1760.jpg
steve578 10-24-2011 05:31 AM
Here are a few pics of the rear bumper. I put a nice little dent in it.
http://i86.photobucket.com/albums/k1...1/IMG_1755.jpg
http://i86.photobucket.com/albums/k1...1/IMG_4487.jpg
http://i86.photobucket.com/albums/k1...1/IMG_4488.jpg
http://i86.photobucket.com/albums/k1...1/IMG_4489.jpg
steve578 10-24-2011 05:33 AM
Here are a few pics of the damage at the end of the day.
I put a crack in one of the Under Armor welds. It's kind of hard to see it in these pics.
http://i86.photobucket.com/albums/k1...1/IMG_1756.jpg
http://i86.photobucket.com/albums/k1...1/IMG_4491.jpg
Just a few scratches. I might have even put a small crease in it, but won't be able to confirm until I pull it.
http://i86.photobucket.com/albums/k1...1/IMG_4496.jpg
For the most part everything held up well. I'll have to look at getting the Under Armor replaced. When I get some more time, I'll post some more thoughts.
TJRHD 10-24-2011 06:02 AM
184 Attachment(s)
Wow I think your nuts. Haha jk but what a test. Thanks for sharing
Ironhead 10-24-2011 08:39 AM
is the under armor supposed to twist like that?
rubijosh 10-24-2011 08:46 AM
nice!
mrblaine 10-24-2011 09:01 AM
It's going to follow whatever the frame does. If the frame is twisted, it will twist right along with it.
KillerSloth 10-24-2011 09:04 AM
As much as I like the UA system, and I know how much Blaine has tested it, I don't trust the aluminum when it is welded and not heat treated afterward. (I never got confirmation that it was, so correct me if I'm wrong)
Welding the 6061 aluminum and not having it heat treat destroys the strength in the area that it is welded, and will cause it to crack a lot easier. I know it doesn't completely relate since mountain bikes are very thin aluminum (but aren't taking as much force), but you would never see an aluminum mountain bike not heat treated, it would snap in half the first time out...
I'm sure it would add some money to the cost to get them all heat treated, but I think it would help improve the system, making a better system, and would be worth the extra cost.
mrblaine 10-24-2011 09:11 AM
It doesn't need a weld there but for aesthetics. There should be a piece of steel strap spanning across that bend and then through bolted with two bolts on either side.
I'm not going to re-heat treat that much aluminum for two small splices that are readily done and very cost effective. There's literally 3" of weld and it's simply not worth it to pay a fortune to a heat treater.
geiman 10-24-2011 09:17 AM
Plus, all you have to do is ask (read that post and up a bit):
http://www.jeepforum.com/forum/f9/sa...l#post12257644
Can't say they don't go out of the way for you.
Savvy 10-24-2011 09:29 AM
Steve,
You need to come out and wheel with us! I like your style! It is almost time for you to get a buggy if you like playing in the rocks.
I'll send you some steel brackets we have that will fix the weld crack. You are the second person that has wheeled hard enough to need the brackets. You just need to drill a few 3/8" holes and add the brackets and all is good.
Thanks for sharing the cool pix. Man you drive like me. By Braille! :rofl:
John Currie and Blaine taught me ease up to the obstacle and when you hit it back up and drive around it. If you every get a chance to wheel with those guys, watch how smooth they are in the rocks. It still amazes me when we go wheeling. They drive around the rocks and I bash into them.
Sweeney 10-24-2011 10:07 AM
I think it's the taper of the forward skid that is providing an optical illusion.
Dabbill 10-24-2011 10:19 AM
Looks like you had a blast. Must have rattled your head good to dent that stuff. :rofl:
TJRHD 10-24-2011 10:23 AM
184 Attachment(s)
Clayton looks fun. A lot of my buddies used to go there. Everyone I know went to disney this year
The time now is 09:05 AM.
