Putting new engine in TJ, what should I do to the engine first? - JeepForum.com
post #1 of 10 Old 11-24-2010, 08:40 AM Thread Starter
andr3w
I just bought a 97 TJ with a blown 2.5 liter engine in it for really cheap...I have a 2.5 liter engine out of a rolled Jeep that I am gonna put in, but now I am wondering if there is any work I should do on the engine before swapping it in? I was already thinking about the rear main seal, valve cover gasket, etc...I would just like to replace stuff that might be an issue later down the road and would be easier to replace or fix while the engine is out of the Jeep.
Thanks,
Andrew
1992 YJ - "Heep of Faith" -- sold for parts
1995 Cherokee Country - 236,000 miles - Daily driver.
1997 TJ Sport - 99,000 miles - project
John 3:16, "For God so loved the world that He gave His only begotten son, so that whoever believes in Him will not perish but have eternal life."
andr3w is offline
post #2 of 10 Old 11-24-2010, 08:52 AM
tjwrangler99
Dono if the 4cyl have the problem, but make sure the exhaust manifold isnt cracked.
1999 TJ
BFG AT 31's | BDS 2" Lift | JKS Quick Disco's | Zone Rear Sway Links | TeraFlex 1/2" Drop+Washer | Warn M8000 | Viking 80' 3/8 Synthetic w/ Safety Thimble | Viking 350 Fairlead | MetalCloak AL Bumper | 99 Durango Steering Box | Uniden 520 CB w/ 3' FireStik | ebay header | Magnaflow Mid-Cat | Banks Cat-back | XJ Steering Linkage | Hella Black Magic (x4)
2011 Patriot FD1
tjwrangler99 is offline
post #3 of 10 Old 11-24-2010, 09:02 AM
NotURMailman
NotURMailman's Avatar
If you have the time, space, and equipment (and are really that concerned about it). You could put the engine on a stand, pressure wash it, and buy an engine gasket set and go to town replacing all of the seals and gaskets (obviously don't go replacing a good head gasket. WHile you have the valve cover and oil pan off you could clean out the engine oiling system really good. But, that's just if you feel like doing all of that just for a warm fuzzy...
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is online now
post #4 of 10 Old 11-24-2010, 09:04 AM
tjwrangler99
why not paint it =)
Make it look nice and new!
1999 TJ
2011 Patriot FD1
post #5 of 10 Old 11-24-2010, 09:05 AM
hefightsfire
Man I'd have a hard time putting the 2.5 back in. Have you considered just finding a 4.0?
hefightsfire is offline
post #6 of 10 Old 11-24-2010, 09:17 AM Thread Starter
andr3w
Originally Posted by NotURMailman View Post
If you have the time, space, and equipment (and are really that concerned about it). You could put the engine on a stand, pressure wash it, and buy an engine gasket set and go to town replacing all of the seals and gaskets (obviously don't go replacing a good head gasket. While you have the valve cover and oil pan off you could clean out the engine oiling system really good. But, that's just if you feel like doing all of that just for a warm fuzzy...
What would you suggest is the best way to clean out the oiling system? I wouldn't mind taking the time and putting in new seals and gaskets, even if its just for the warm fuzzy.
@hefightsfire = I thought about putting in the 4.0, but I have the 2.5 liter already so I am just gonna put that in, plus its an easier install then the 4.0.
andr3w is offline
post #7 of 10 Old 11-24-2010, 09:34 AM
NotURMailman
With the engine on a stand and the valve cover, oil pan and manifilds off you can put a large drip tray under it, set a container of solvent so that the oil pump pick up is submerged, install a new oil filter, and spin the oil pump with a drill. Or you can re-install the oil pan without a gasket (after you clean the inside of the pan really good),re-install the valve cover without a gasket, install the new oil filter, fill the oil pan with five quarts of solvent, and spin the oil pump with a drill.
DO NOT turn the engine with the solvent in the oiling system!
Do this BEFORE you install any of the new seals!
After you do this, install another new oil filter and repeat the process with fresh oil to get ALL of the solvent out of there!
Replace ALL of the seals (other than the head gasket, but including valve seals) after you do this.
After you install the engine, be sure to use engine break in additive with high ZDDP.
I would probably go the re-install oil pan and valve cover with out gaskets route to avoid a huge mess. Be sure to clean the oil pan and valve cover really well first.
Make sense?
post #8 of 10 Old 11-24-2010, 09:47 AM
chris142
Replace the freeze plugs.
chris142 is offline
post #9 of 10 Old 11-24-2010, 08:12 PM
mudb8
want it rite or rite now?
mudb8's Avatar
Differential gears......
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline
post #10 of 10 Old 11-24-2010, 09:00 PM
balzer
better cam
balzer is offline
2.5 liter , engine replacement , engine swap
Putting a Chevy Engine into YJ '90 Urb4nTr0ll YJ Wrangler Technical Forum 25 01-07-2009 11:54 AM
4.0 engine dies when putting in gear wusupra YJ Wrangler Technical Forum 1 11-06-2008 07:46 PM
putting a 93 2.5L engine in an 88...help! booeylouey YJ Wrangler Technical Forum 2 10-05-2008 09:42 PM
is it worth putting in a 304 engine wordo30 YJ Wrangler Technical Forum 8 07-29-2008 03:42 PM
Putting A Bigger Engine In My Jeep I Have A Few Questions pipisnack YJ Wrangler Technical Forum 5 05-14-2007 06:34 PM
