#1 | |
Putting LJ Unlimited top down
Is putting the top down on an Unlimited much more difficult than a regular TJ? Does the longer folding mechanism get unwieldy for one person to operate?
Current: 2005 Wrangler Unlimited - Past: 90 and 92 Trackers and 98 Wrangler SE |
#2 |
No, once you have done it a few times takes a couple of minutes, the bars stick up a bit more, so I take the whole thing off on the trail or the kids would trip over / bend jumping in and out of the back.
04 Unlimited RE SF 4.5", 1" MORE BL and MML, ARB Bull Bar, AR23 15x8, 35x12.5 MTRs, Jeep Medic Engine and T/F Skid, Shrockworks Rockers, Warn 9.5ti, AA SYE, ARBs, 4.88s and Alloy USA Shafts, HPD30 w JJs 1967 M416 www.midatlanticjeepers.com |
#3 |
I find getting it down by myself to be easy, but putting it back up is much easier with two people. Not saying you can't put it back up solo (and I have before), but it gets very unwieldy trying to lift the top by yourself...
#4 |
Taking the top down is easy. Little more work, but not much getting it back up. When doing it alone, I have found that if you park on a slight downslope with the front of the vehicle lower then the back, gravity helps when putting the top back up.
“This isn’t the Old West, because the New West has never arrived. It’s just the West, like Wyatt Earp died yesterday.” ─ Michael Martin Murphey talking about the Eastern Sierra during an interview in 1996. |
#5 |
It is just as easy to take down as any other top. However when putting it up there are times when I wish I had a second person, I can do the top up in 5 to 10 minutes, down only in a few seconds. But i wouldn't say its to hard or anything.
2006 Rubicon Unlimited Khaki: AUTO, 4:11 D44/D44, REBB /w Mono tubes, Rancho front stabilizer, 31 x 9.5 LT245/75R16 MTRs, Stock 16in Moab Wheels, Olympic Reverse-A-Bars,KC Daylighters on windshield brackets, Garmin Nuvi GPS, Pioneer Sound, 3A fire extinguisher, Line-X interior... www.stevensinger.org <-- Photography website Hello, my name is Steve and I am a Jeepaholic. LJ Owners Member 155 Rubicon Owners Member 123 New Jersey Jeepers Member 44 |
#6 |
I stand on the rear bumper and swing the top up and let it fall forward.
Blue Jeep #231 |
#7 |
The trick is to zip out the windows, then be happy, and never put the top down. Ahahaha.
All joking aside, that is exactly what I do since I don't like getting a sunburn and in WA State, or OR State, the rain can return in 30 minutes anytime. So I can put the windows back in a hurry, if need be. P.S. - I assume you have the Sunrider top? So open that, remove window, and you're good. Personally I leave the sunrider top close cause I'm a white, white man who burns easily. |
#8 |
Standing in the interior and pulling it up works well too.... It makes it easy to keep a straight pull.
#9 |
Trail Proven
Been running with mine down for the last 3 weeks. I took the GF out on Monday and decided to at least put the top up. I about said forget it when I couldn't get the pins in on the side but finally got it after a few minutes of struggling.
I'm thinking that was a sign that I should get a safari,duster/jammer combo.
Over the mountains and through the woods, across the stream and up the slickrock, down the canyon and over the rocks to nobody's house I go. |
#10 | |
....and thats all I have to say about that. |
#11 |
i'm waiting for the www.vikingoffroad.com top
looks easier than screwing with a frame! stores between the roll bars or in some duffle bags. ![]()
Useful Write-Ups: SEARCH TUTORIAL TJ Tech BOOT CAMP-A Must Read! FAQ: Cold Air Intakes & K&N's Off-Road Tips and Techniques What is a CV shaft and why do I want one? So you want a Tummy Tuck? Tire size, lift height, bumpstops & shock guide DIY Shock Shifters for Long Travel Shocks Lug nuts and bolt patterns Catalytic Converters Busted TJ Track Bar Bolt Fix Brake Knuckle Divot/Groove Repair Coconut Oil for Drilling and Machining Fabrication & Build: My Build Thread Funny: Will it fit in my Jeep? |
#12 | |
#13 |
Trail Proven
snsmith - that's what I was attempting to do but I just couldn't get the pins in for the life of me. Finally one side cooperated. heh
#14 |
Yup, those two pins are the only big difference between the LJ and TJ tops.
The extra length of the top doesn't slow me down any, but those pins can add a few minutes to the raising time. I could put my old TJ's top up in the dark, but with my LJ I have to see to seat the pins. And if you fasten the back quarters first you'll never get them in. First the pins, then the rear flaps, then the front clamps. That makes it less difficult, if not exactly easy. Even with the extra work, I love my Sunrider top.
. 2005 Unlimited TJ - Patriot Blue . Mods: Pine Tree Air Freshener hanging on mirror |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
