-   TJ Wrangler Technical Forum (http://www.jeepforum.com/forum/f9/)
-   -   Putting a 1994 AX15 into a 1998 TJ? (http://www.jeepforum.com/forum/f9/putting-1994-ax15-into-1998-tj-1711122/)
chadridesabike 10-22-2013 12:23 PM
I found a 1994 AX-15 Transmission on CL for a decent price, and he confirmed that it had the external slave cylinder. Will this fit my 98 TJ? My current transmission has a couple bad syncros for sure, and now I have a driveline vibration that may also be inside of there.
Any modifications needed? Should I keep my bell housing?
Along with the transmission, I need a new clutch. Anything else I should replace while it's tore apart?
Thanks JF
chadridesabike 10-23-2013 08:28 AM
Bump.
chadridesabike 10-23-2013 01:10 PM
Bump..
jeepwrangler97 10-23-2013 01:57 PM
224 Attachment(s)
That should work fine. I'm using an ax15 from a 95 XJ (just had to change clocking).
If you're doing your clutch, do not have the flywheel re-surfaced. The oem flywheel is not flat.
If you can afford it, I'd recommend putting in a b&m short shifter. I know it's not a race car, but it makes the shifts so much more precise. I think mine improves it enough so that if I were to get another jeep, that's probably the very first thing I'd order.
Edit: if the trans is from an XJ, the clocking on the trans, for the transfer case will need to be changed (re-drilled)
Sent by a messenger bird
chadridesabike 11-04-2013 09:52 AM
To any future searchers, here is a similar thread:
http://www.jeepforum.com/forum/f9/wi...fit-tj-103408/
The time now is 06:31 PM.
