Pushing rear axle back vs trackbar clearance - JeepForum.com
post #1 of 3 Old 10-21-2013, 04:23 AM Thread Starter
glook
I've got a 3.5 inch lift with a UCF ultra high skid with a rear pinion set to about 19 degrees.
I'm running an "old style" rear Currie trackbar (single JJ) with a "new style" angled trackbar bracket. After pinion angle adjustments I had to shorten both lowers and uppers so that the trackbar would clear the lower part of the frame crossmember (where the gas tank skid bolts to).
I just relocated my upper rear spring perches and want to push the rear axle back. The question is - will the "new style" rear Currie track bar with double JJ allow me to push it back about 1/2" - 1" or so?
I'm also concerned with exhaust clearance - with my current setup the track bar touches the exhaust at full droop. Will the "new style" Currie bar still clear the exhaust?
2002 TJ 5.3L
glook is offline
post #2 of 3 Old 10-21-2013, 02:40 PM Thread Starter
glook
Checked tire against tub at full bump today. Tire and tub are only 3/8" apart (tire is close to the front side of the wheel arch), so I definitely need to move the rear axle...
2002 TJ 5.3L
glook is offline
post #3 of 3 Old 10-23-2013, 03:09 PM Thread Starter
glook
Bump. Any opinions?
2002 TJ 5.3L
glook is offline
