-   TJ Wrangler Technical Forum (http://www.jeepforum.com/forum/f9/)
-   -   Pushing rear axle back vs trackbar clearance (http://www.jeepforum.com/forum/f9/pushing-rear-axle-back-vs-trackbar-clearance-1706138/)
glook 10-21-2013 05:23 AM
I've got a 3.5 inch lift with a UCF ultra high skid with a rear pinion set to about 19 degrees.
I'm running an "old style" rear Currie trackbar (single JJ) with a "new style" angled trackbar bracket. After pinion angle adjustments I had to shorten both lowers and uppers so that the trackbar would clear the lower part of the frame crossmember (where the gas tank skid bolts to).
I just relocated my upper rear spring perches and want to push the rear axle back. The question is - will the "new style" rear Currie track bar with double JJ allow me to push it back about 1/2" - 1" or so?
I'm also concerned with exhaust clearance - with my current setup the track bar touches the exhaust at full droop. Will the "new style" Currie bar still clear the exhaust?
glook 10-21-2013 03:40 PM
Checked tire against tub at full bump today. Tire and tub are only 3/8" apart (tire is close to the front side of the wheel arch), so I definitely need to move the rear axle...
glook 10-23-2013 04:09 PM
Bump. Any opinions?
The time now is 04:15 PM.
