Pure Jeep TJ Stretch Gas Tank install - Page 3 - JeepForum.com
post #31 of 51 Old 12-09-2012, 03:15 PM
MisfitSeven
MAiL Crawler.
MisfitSeven's Avatar
I cut a slice out of the ring gasket this last time I installed the tank. I too have the long crank before it starts. I have no crimped lines or hoses.
Is that pressure regulator an in line model, or does it mount in the tank, or on the motor? I have no issues once the Jeep is running, but it does seem like the pump needs to be primed before it turns over.
Mail crawling.
MisfitSeven is offline
post #32 of 51 Old 12-09-2012, 04:32 PM
Timido
That the issue I have it losses its prime. The regulator/filter is on the top of the fuel pump. The round thing with the metal strap covering it
Timido is offline
post #33 of 51 Old 12-09-2012, 04:58 PM
MisfitSeven
MAiL Crawler.
I meant the one from the link that was posted. The Chevy one...
Where would that mount?
Mail crawling.
post #34 of 51 Old 12-09-2012, 05:48 PM
Timido
The Chevy part number is for the fuel filer hose. My tank overflows when I fill it up
Timido is offline
post #35 of 51 Old 12-10-2012, 12:51 PM Thread Starter
Tyler99TJ
Did anyone else call Pure Jeep to tell them theirs did not fit? When I called they acted like I was crazy and they have never had this problem before and now there are 4 of us with the exact same problem.
Tyler99TJ is offline
post #36 of 51 Old 12-10-2012, 01:54 PM
bmosing
I did not call them. I may do that though and give them a heads up. If they are as crappy to deal with as everyone says, I will advertise against their products from now on.
On another note, my jeep is starting fine right now. A tad longer than a normal start, but it is bearable. I will probably just leave it alone and drive it and see if the problem worsens.
My Jeep:
bmosing is offline
post #37 of 51 Old 03-21-2013, 03:33 PM
joe_jeep
flip the key on, but not to the start position, for 5 seconds before starting. i bet it starts right up after that. anti drain back valve issue i bet.
my 97 tj did that.
glfwda #6624
2005 rubicon sahara lj #592
joe_jeep is offline
post #38 of 51 Old 05-12-2013, 08:37 AM
TURBevO8
Bump for more up to date info and opinions!
2006 Impact Orange TJ X
2004 Apex Silver EVO VIII GSR
TURBevO8 is offline
post #39 of 51 Old 05-12-2013, 09:45 AM
TroubleNEO
My opinion is to not waste time and money on this and to buy a fuel cell.
Looking for: 03-06 interior plastic trim. PM me.
TroubleNEO is offline
post #40 of 51 Old 05-12-2013, 10:59 AM
TURBevO8
Fuel cell is not an option for me. I need to retain the back seat and cargo area and there is no chance of passing inspection with a comp cut anyway (to justify a fuel cell) so Genright stretch corners and 5" in back is as far as I can go.
Just trying to determine if the Genright tank is worth the extra $175 over the PJ.
TURBevO8 is offline
post #41 of 51 Old 05-12-2013, 05:34 PM
MisfitSeven
MAiL Crawler.
What rear axle do you have?
Edit: never mind, you should be fine.
Mail crawling.
post #42 of 51 Old 05-12-2013, 11:03 PM
stryder94
Comp cuts are legal in Pa, just need to have a flare cover tire at the top is all. Just wanted to pass that on.
stryder94 is offline
post #43 of 51 Old 05-13-2013, 07:53 AM
TroubleNEO
It's not even about a comp cut, it's just nice to have the extra room. After not fighting my tank to get to everything in the rear to work on it I would gladly sacrifice my back seats and/or cargo area. I currently do not have seats, and have a tuffy trunk in my cargo area and my cell where the rear seats would be.
post #44 of 51 Old 05-13-2013, 09:48 AM Thread Starter
Tyler99TJ
If I were to redo my Pure Jeep tank, I would buy the RCI 2162b fuel cell and have a local fab shop cut and weld a dimple into it. Then I would mount it in the factory location with a steel skid holding it up. It would require some fabrication, but I think the overall products would be better. I would rather not mount mine in the tub to have more storage and piece of mind. This would give you more clearance at the axle depending on how you modify the cell (my Ford 8.8 is close to hitting because its offset diff). It would not hang down as low as the Pure Jeep tank because the 2162 is about 3" shorter in height compared to the Pure Jeep. I am thinking about selling mine and doing this anyway.
post #45 of 51 Old 05-13-2013, 10:06 AM Thread Starter
Tyler99TJ
Correction I would use this cell, http://www.ebay.com/itm/NEW-RCI-17-G...a91848&vxp=mtr, because it is only 7"deep and has the filler hole in a much better location. You would have to cut the whole front piece off and make it short and add the dimple, but you are already modifying it, so whats a little more work.
EDIT: forgot that this would be too short for factory fuel pump. Will not work.
Anyone have the stretch corners from pure jeep? RUoffroader TJ Wrangler Technical Forum 4 02-13-2012 01:16 PM
Anyone use the Purejeep stretch gas tank? rd97tj TJ Wrangler Technical Forum 2 03-13-2010 07:34 PM
OME Install: Comments, questions, and pure hatred for Torx bolts PackMan TJ Wrangler Technical Forum 11 04-29-2007 09:36 PM
GenRights stretch gas tank Dans01TJ TJ Wrangler Technical Forum 8 03-07-2007 02:21 PM
