Pure Jeep Rocker Guards - JeepForum.com
post #1 of 19 Old 03-28-2010, 12:44 PM Thread Starter
442Wrangler
In like Flynn.
442Wrangler's Avatar
Anyone run these on their TJ? Do they bolt to the body mounts as well as the body? Isn't that the best design? Just curious and please post pics
2008 JK Rubicon
-255/80/17 BFG KM2s, 16/59 JKU springs, 2013 Rubi rims, RC stubby hybrid front bumper, XRC8 winch with synthetic line, RR evap skid, and more to come
1959 Willys Wagon
-Going to be restored and painted Plantation White and Presidential Red
"I would rather wake up in the middle of nowhere than in any city on earth."
-Steve McQueen
442Wrangler is offline
post #2 of 19 Old 03-28-2010, 01:30 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
Beings there website only shows for 07 to present JKs. Sorry.... found them. My bad. I would say no because they don't show coverage from wheel well to wheel well.You want those extra inches of coverage.
GOLENJEEPTJ is offline
post #3 of 19 Old 03-28-2010, 02:03 PM Thread Starter
442Wrangler
In like Flynn.
Crawler Rocker Guards by PUREJEEP and Other Jeep Parts and Jeep Accessories by 4 Wheel Drive Hardware
there they are...and why do i need those extra inches? that means i would have to trim my fender flares and all that...I won't be doing extreme rock crawling, just moderate junk...wouldn't i be ok with the non WtoW coverage?
2008 JK Rubicon
1959 Willys Wagon
-Steve McQueen
post #4 of 19 Old 03-28-2010, 02:07 PM
2006_Sport
Your link is broken bud.
2006_Sport is offline
post #5 of 19 Old 03-28-2010, 02:13 PM
GOLENJEEPTJ
You don't have to trim anything! They slide behind your flares.If your going to spend that much money on armor you might as well get the best coverage!
post #6 of 19 Old 03-28-2010, 05:41 PM Thread Starter
442Wrangler
In like Flynn.
4 Wheel Drive Hardware Search
Middle of the page
2008 JK Rubicon
1959 Willys Wagon
-Steve McQueen
post #7 of 19 Old 03-28-2010, 05:42 PM Thread Starter
442Wrangler
In like Flynn.
forget it...4wd is retarded
These exist though
2008 JK Rubicon
1959 Willys Wagon
-Steve McQueen
post #8 of 19 Old 03-28-2010, 06:32 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
These exist though
lies!!
try here instead:
Rokmen Gear Up....Rok On
www.atozfabrication.com
Welcome to Savvy Off Road
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #9 of 19 Old 03-28-2010, 07:34 PM Thread Starter
442Wrangler
In like Flynn.
a to z doesn't bolt to the frame/body mounts...isn't that what i want to protect the underside a bit as well or what?
and the savvy ones? whats the advantage?
I know everyone raves about savvy but is the loss in weight worth the thing? and can you get them with steps built into them like a to z or poison spyder and such?
2008 JK Rubicon
1959 Willys Wagon
-Steve McQueen
post #10 of 19 Old 03-28-2010, 07:40 PM
Unlimited04
no.
smart design. less weight.
thats up to you.
Useful Write-Ups:
Funny:
post #11 of 19 Old 03-29-2010, 08:20 AM Thread Starter
442Wrangler
In like Flynn.
what's so funny about that?
some of us want functionality as well as everyday use, not just for off road abuse.
and if it doesn't bolt to the frame, then that sheet metal of the body will become bashed up over time and many hits...
2008 JK Rubicon
1959 Willys Wagon
-Steve McQueen
post #12 of 19 Old 03-29-2010, 10:16 AM
Mopar Fan
So you want your body mounted rocker guards to tie into the frame?
Mopar Fan is offline
post #13 of 19 Old 03-29-2010, 11:18 AM
GOLENJEEPTJ
Everyone on here is on the most trying to help you out.You just need to do some research on the best way of rocker guard mounting. These are also excellent guards. http://www.genright.com/category.aspx?categoryID=143
post #14 of 19 Old 03-29-2010, 11:50 AM
Unlimited04
http://www.jeepforum.com/forum/f9/sa...ml#post8806491
and because the body mounted sliders are too high to be used as a realistic step...
unforunately there isn't a best of both worlds here. either you have a crappy rocker with loss in ground clearance, or a crappy step with good ground clearance.
how do you figure? a frame mounted rocker can bend and smash into the tub. a body mounted rocker is already on the tub, where it distributes forces widely across all the body mounts...
Good reading on the subject:
http://www.jeepforum.com/forum/f9/an...ml#post6735773
http://www.jeepforum.com/forum/f9/in...tml#post944588
http://www.jeepforum.com/forum/f9/ro...ml#post7635984
if you're really worried about the body, try this: Rokmen - Slider Reinforcement
Useful Write-Ups:
Funny:
post #15 of 19 Old 03-29-2010, 11:53 AM
BlackBellamy
BlackBellamy's Avatar
1) Where does it say PUREJEEP rocker guards are mounted to the frame? Because nothing would make a set of rocker guards WORSE than having the side mounted to the tub (like the picture on the site shows) and the bottom mounted to the frame. First time you'd do some flexing something would rip.
2) If you go to the PUREJEEP site they only sell JK rocker guards. So whatever 4WD.com is selling is either a) another product rebranded as PUREJEEP, b) the remnants of a discontinued line, or c) an untried and brand new product. Either way, pass pass pass.
3) You should get your rockers bare steel and save $80-$90 because the rockers flex so the powdercoat will crack and peel anyway. It's a lot cheaper to spray them down with some black Rustoleum.
Having said all that, I run the W2W version of these and couldn't be happier Jeep® '97-'06 Wrangler TJ Rocker Guards :: Jeep Rocker Guards :: AtoZ Fabrication
The top and doors on this vehicle are designed only for protection against the elements. Do not rely on the top and doors to contain occupants within the vehicle or to protect against injury during an accident. Wear seatbelts at all times.
BlackBellamy is offline
Cheap, Entry Level Rocker Guards/Rocker Panels Croce JK Wrangler Technical Forum 14 03-03-2010 08:38 AM
A to Z Rocker Guards Vs. Rokmen Rocker Guards willhbauto TJ Wrangler Technical Forum 26 03-04-2008 04:48 PM
ARB-AEV rocker guards bfr TJ Wrangler Technical Forum 3 01-16-2008 06:04 AM
question about side of jeep and new rocker guards. kg21 TJ Wrangler Technical Forum 8 01-02-2008 12:53 PM
Rocker guards?? bryris YJ Wrangler Technical Forum 4 05-22-2006 11:02 AM
