Pulsing Vibration after Regear - Page 6 - JeepForum.com
post #76 of 228 Old 12-20-2010, 06:14 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
I was trying to fix the vibes by adjusting the pinion angle, as you suggested earlier in the thread. I tried everything between 1 up to 3 down, in ~0.5 increments, and didn't change anything one bit. It's just currently at 2 because that was the last degree I tested.
Any driveshaft in the rear that I've run at that angle will induce vibes.
I am Savvy
blackmagicbrakes.com
mrblaine is online now
post #77 of 228 Old 12-20-2010, 06:27 PM Thread Starter
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
what about when the vibes are the same at 2 as they are at 0 straight?
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #78 of 228 Old 12-20-2010, 06:45 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Here's what I know about fixing difficult issues. Make everything you do be as good as it can be. Change one thing at a time.
I don't know about vibes not changing at various angles, but I do know I've never been able to get rid of them at 2 down and I can almost always create them with that much misalignment.
I am Savvy
post #79 of 228 Old 12-20-2010, 06:50 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Oh, go read post #8 again. where's that darn flip-off guy when you need him?
I am Savvy
post #80 of 228 Old 12-20-2010, 07:04 PM Thread Starter
Unlimited04
the flip-off guy is hanging out in Post #13
rear is dialed in dead on, no 1 deg down BS.
I'll set it back to 0 and try again with the new shaft.
Useful Write-Ups:
Funny:
post #81 of 228 Old 12-20-2010, 07:13 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
I truly know Sean is a great guy. That said, driveshafts are just driveshafts and even in all of his awesomeness, I humbly offer that Sean is unable to impart any mystical stayinbalance powers to a driveshaft.
I am Savvy
post #82 of 228 Old 12-20-2010, 08:05 PM
Stang5lgt
Stang5lgt's Avatar
Two other factors to throw in here. Sean ran 35s 37s. Unlimited is running 33s. Which means more RPMs. Other thing that is new besides the 33s. Is the true track. Next if it was the gears or true track wouldn't the vibes still happen with driveshaft removed. Unlimited said they go away. Unlimited I have spare Advanced Adapter SYE yoke you can borrow if you wanna try changing to a different one.
For Off Road Deployment
Stang5lgt is offline
post #83 of 228 Old 12-20-2010, 08:36 PM
Hendrix
TJOTY 2013
Hendrix's Avatar
Great advice. I am trying to track down the very same vibe. I have a 2004 Unlimited with a fresh 4.88 regear and 33s with the 42rle. I have the same vibe at any speed above 40. I removed the front shaft and the vibe goes away. The vibe is the very same shaking of the rear view mirror Unlimited04 has.
Unfortunatly I have not found a shop to High speed balance the factory shaft in my area.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #84 of 228 Old 12-20-2010, 08:36 PM Thread Starter
Unlimited04
LOL. That made me laugh out loud. Well stated
Ok, so I reset to 0. Got it up to 70mph. No appreciable change. Still at ~50% of original vibes, with same behavior.
Thanks for the help Blaine, Josh, Dave & others. I give up for now...I'm going home for the holidays and will address this again in 2011.
Useful Write-Ups:
Funny:
post #85 of 228 Old 12-20-2010, 08:49 PM
Stang5lgt
Stang5lgt's Avatar
Have a great Christmas and Happy New Year!
post #86 of 228 Old 12-20-2010, 09:02 PM
mudb8
want it rite or rite now?
mudb8's Avatar
Originally Posted by Stang5lgt View Post
It wasn't over spec. I hate to have you gear my axle 19 in. lbs is max on new bearings and 9 in. lbs. on old bearings for the Dana 44. If you are torquing them up to 25 in. lbs. well then you are putting some extra stress on the bearings.
That was EXACTLY my point.... Have you ever seen what the FSM says to set them at? It can turn into a big argument from inexperienced people and parts changers.
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline
post #87 of 228 Old 12-20-2010, 09:11 PM
mudb8
mudb8's Avatar
can you move the rear t-case output yoke/shaft in or out?
mudb8 is offline
post #88 of 228 Old 12-20-2010, 09:20 PM
mudb8
mudb8's Avatar
I just yanked a set of rubi carriers from an 06 LJ with 4.88's and installed ARB's and 5.38's running 33's & a 42RLE which had vibs around 65, the front shaft was rebalanced and the rear is a custom built unit by driveline tech, local here, no more vibs.
mudb8 is offline
post #89 of 228 Old 12-20-2010, 09:31 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
...Unfortunatly I have not found a shop to High speed balance the factory shaft in my area.
Where are you located?
Maybe there is a Fleet Pride in your area
Find a FleetPride Location
Wheelin98TJ is offline
post #90 of 228 Old 12-21-2010, 03:57 AM Thread Starter
Unlimited04
no play, solid as a rock. was one of the first things I checked, found the torque on the nut to be around 50 ft-lbs (but wasn't loose). Retorqued to AA's install spec with a good torque wrench.
Useful Write-Ups:
Funny:
pulsing , vibration , regear
pulsing vibration at 70+ mph sportcoupe TJ Wrangler Technical Forum 60 12-11-2016 10:11 AM
Pulsing vibration at 60+mph BoarderX47 TJ Wrangler Technical Forum 7 11-22-2012 01:27 PM
Vibration on acceleration and pulsing vibe at 40+ mph cubbieblue TJ Wrangler Technical Forum 41 07-07-2010 07:10 PM
Gas Pedal Vibration after Regear? willydigger TJ Wrangler Technical Forum 27 03-15-2010 06:22 AM
Steering pulsing rick_chicago YJ Wrangler Technical Forum 2 05-07-2002 07:14 AM
