Pulsing Vibration after Regear - Page 2 - JeepForum.com
post #16 of 228 Old 08-30-2010, 01:01 PM
crusty1007
Remove the rear DS & drive it in front wheel drive. See if it goes away.
FYI the vehicle is going to handle differently.
Click the sig for everything you need to build a JEEP... 805-706-0232
NEW PRODUCTS ADDED DAILY !!!
----> Click and download the new catalog!!!
crusty1007 is offline
post #17 of 228 Old 08-30-2010, 02:02 PM
Stang5lgt
Stang5lgt's Avatar
rear pinion seal is leaking like crazy too.
ideas? rear shaft balance? pinion bearing preload?
Well the seal that came with your install kit was not the same as the one I removed so I wondered if it would be a leaker. The rubber was touching but didn't seem snug against the yoke. Pinion bearing preload won't give you vibes just makes noise. I wonder if you have a u joint going bad in the rear shaft. We will check it out when you get here.
For Off Road Deployment
Stang5lgt is offline
post #18 of 228 Old 08-30-2010, 07:51 PM Thread Starter
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
had the front driveshaft balanced - that definitely wasn't the problem.
pulled the rear shaft and having it rebuilt & balancede at the driveline shop...new non-greasable u-joints, centering ball and fixing slight play in the slip shaft.
very little vibration with the rear shaft removed...so hopefully that was the issue!
and Josh (Stang5lgt) installed a new rear pinion seal
hopefully i'll be good to go for labor day weekend wheeling
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #19 of 228 Old 08-30-2010, 09:53 PM
Stang5lgt
Stang5lgt's Avatar
So I take it the new seal didn't leak. LOL Good deal.
post #20 of 228 Old 08-30-2010, 10:28 PM Thread Starter
Unlimited04
honestly, i didnt even look.
Useful Write-Ups:
Funny:
post #21 of 228 Old 09-01-2010, 06:10 PM Thread Starter
Unlimited04
ok...
Rear drive shaft is rebuilt & balanced.
Rear output yoke wasn't torqued properly. Set to 150 ft-lbs per AA install manual.
Rear pinion seal still leaking, not quite as bad this time.
Vibes are still there when rear shaft is installed. Obviously related to rear, since removal of rear shaft eliminates them.
Next idea?
Other than this mystery vibe @ 60 mph and greater, the Jeep drives freakin' amazing.
Useful Write-Ups:
Funny:
post #22 of 228 Old 09-01-2010, 06:24 PM
Stang5lgt
Stang5lgt's Avatar
ok...
Next idea?
If the rear axle isn't making any noise it shouldn't be the problem. I would get a timken seal I think Autozone has them. I have had good luck with those. If it was the rear axle I think you would have still noticed it when the shaft was off. Try taking the shaft and rotating it 180 degrees at one of the yokes. Mustang guy I know has to put his rear shaft on the same every time otherwise he gets vibes.
post #23 of 228 Old 09-01-2010, 07:23 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
ok...
Next idea?
Make some small adjustments to the pinion angle and see if it changes anything.
Also, make sure you don't have a control arm in a bind. On level ground, you should be able to loosen the upper bolts at either end and put a jack under the pinion and raise it very slightly until you can spin the bolts by hand. If you can't, make it so.
After you do that, take it for another drive.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #24 of 228 Old 09-01-2010, 09:01 PM
-dirt-
Sorry you can't get this pinned down, Unlimited! Hope you can figure it out.
I'll throw a WAG in the hat: didn't you install a new tcase? Would a bent rear output cause this? Or something related to the tcase? I have no idea if this would cause what you were experiencing. Just wanted to throw it out there.
Good luck man!
-dirt- is offline
post #25 of 228 Old 09-06-2010, 08:48 PM Thread Starter
Unlimited04
still vibrating. starts being barely noticable around 55mph...definitely pronounced by 60mph, then very obvious by 70mph and increases in amplitude as you go faster. it vibes enough to shake the rearview mirror like a set of 12" subwoofers. i can also put the tranny in neutral on a downhill (maintaining speed), and it still does it, absolutely no change.
I played with the pinion angle, between 1 down to 0.5 up. loosened the UCA's, LCA's, loosened the tranny mount, all retorqued to spec & no binding.
At this point I'm at a complete loss. The diff makes no unusual noises, sounds just like stock. TrueTrac works like a champ. Maybe it's just a "Jeep thing"??
Useful Write-Ups:
Funny:
post #26 of 228 Old 09-06-2010, 09:31 PM
popeyesides
popeyesides's Avatar
Hey 04, I feel your pain I am sure you are following the other thread on driveline vibe by AZjeepnewbie, I have spent alot of time on this and I am done screwing with this and am going to enjoy my rig. The 5.13's are worth it.
popeyesides is offline
post #27 of 228 Old 09-06-2010, 09:47 PM
AZJeepNewbie
Wow, hadn't seen this thread before. Probably the same issue as popeyesides and me. With 5.13s, we're running driveshafts at 4,000+ RPM that are only balanced to 2,000 or maybe 2,500 RPM. I'm looking into high speed balancing options. There are shops that will balance shafts at up to 10,000 RPM. Stay tuned for another episode of "As the Driveshaft Turns".
2005 Rubicon, Currie JJ SA lift with AEV 3" springs.
"Confidence is that feeling you have before you fully understand the situation."
AZJeepNewbie is offline
post #28 of 228 Old 09-06-2010, 10:05 PM Thread Starter
Unlimited04
I see you guys both have 42RLE's....maybe this is another added benefit of the steep OD ratio?
btw, mine isn't all that RPM dependent...3rd gear, 2nd gear, or OD...doesn't seem to make much difference, although its hard to tell when screaming the engine at 3200+ RPM in 3rd at 65+mph
Useful Write-Ups:
Funny:
post #29 of 228 Old 09-06-2010, 10:20 PM
AZJeepNewbie
No, it won't be engine RPM related at all. Tranny gears would make no difference either. It's strictly a tire size versus differential gear ratio issue. That's what dictates your driveshaft speed.
post #30 of 228 Old 12-17-2010, 01:38 AM
cpleasant
cpleasant's Avatar
I've been chasing mine for years. 02 manual with 4.10's and 2" BB. New front axle and control arms did help some, but that's only because the pinion nut had lossened. Plling the front ds lessens it, but that it seemingly only because the front is acting like a conductor to the entire vehicle through the front axle/steering. Pulling the rea ds seemd to help alot, but that was before the front axle change so it needs to be done again.
I'm currently getting a cheap used rear ds to see if it changes anything. If not I'm going to try some adjustable rear control arms.
In all, I'm in the same boat as you.
Originally Posted by liredneck View Post
I know your rite I seid the dealer seid the same thing as you and that I don't want them there , but I was asking another qeustin as in what do I do about the slots in the brackets couse if I just put a bolt in there it will slide back and fourth but again thank you all knowing and powerfull jeep god sorry us lesser jeep peeons might have some more qeustins in the future , so please if there to much for you sit back relax go to the next post
cpleasant is offline
pulsing , vibration , regear
pulsing vibration at 70+ mph sportcoupe TJ Wrangler Technical Forum 60 12-11-2016 11:11 AM
Pulsing vibration at 60+mph BoarderX47 TJ Wrangler Technical Forum 7 11-22-2012 02:27 PM
Vibration on acceleration and pulsing vibe at 40+ mph cubbieblue TJ Wrangler Technical Forum 41 07-07-2010 08:10 PM
Gas Pedal Vibration after Regear? willydigger TJ Wrangler Technical Forum 27 03-15-2010 07:22 AM
Steering pulsing rick_chicago YJ Wrangler Technical Forum 2 05-07-2002 08:14 AM
