Pulsing vibration at 60+mph - JeepForum.com
post #1 of 8 Old 01-12-2010, 10:55 PM Thread Starter
BoarderX47
Hey guys, just recently, as in this winter, I have been getting a pulsating vibration coming from the jeep as soon as I hit 60mph and above. The vibration comes and goes about every 10 seconds and can be felt in the seats but not in the gas pedal. Any ideas as to what this could be.
Thanks
BoarderX47 is offline
post #2 of 8 Old 01-13-2010, 03:13 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Originally Posted by BoarderX47 View Post
.... a pulsating vibration .....
Usually points to worn out u-joints. Most likely, the rear drive shaft. If fresh u-joints doesn't fix the noise, the slip yoke on the drive shaft may be worn or you may need to look into a Slip Yoke Eliminator (SYE).
CJ7-Tim is offline
post #3 of 8 Old 01-13-2010, 06:05 AM
MeltdWhiskey
ahh ...the old pulsing vibe issue.
good luck isolating it. ...many have tried and failed.
i just learned to live with it.
MeltdWhiskey is offline
post #4 of 8 Old 01-13-2010, 06:13 AM
IOUnlimited
I'd begin by pulling the rear shaft and driving with just the front shaft and see if it takes care of the issue.
IOUnlimited is offline
post #5 of 8 Old 11-22-2012, 12:03 PM
Kodiak17
Thread revive: If I pull the rear shaft, how fast can I go on 4-hi.
Maintain, wheel, upgrade, repeat.
My build: http://www.jeepforum.com/forum/f22/thor-dd-weekend-warrior-1348534/
Kodiak17 is offline
post #6 of 8 Old 11-22-2012, 12:41 PM
biffgnar
biffgnar's Avatar
I've driven for hours at highway speeds just on the front driveshaft. No problems.
Romney in 2020!
biffgnar is offline
post #7 of 8 Old 11-22-2012, 01:05 PM
Jeepin72
As fast as you want. Just pay attention to the the Jeep. If you feel a new vibe, back off.
Jeepin72 is offline
post #8 of 8 Old 11-22-2012, 01:27 PM
Kodiak17
Alright I'll pull both shafts, hoping it isn't as stubborn as the OP's problem.
Kodiak17 is offline
pulsing vibration at 70+ mph sportcoupe TJ Wrangler Technical Forum 60 12-11-2016 10:11 AM
engine pulsing cosmo_j YJ Wrangler Technical Forum 18 12-29-2009 10:21 AM
Pulsing Vibe from 50-60 mpg missionAvs TJ Wrangler Technical Forum 10 12-03-2009 11:01 PM
94 2.5 engine pulsing? Shawn94 YJ Wrangler Technical Forum 1 08-31-2009 07:57 AM
Steering pulsing rick_chicago YJ Wrangler Technical Forum 2 05-07-2002 07:14 AM
