Pulsing Vibe from 50-60 mpg - JeepForum.com
post #1 of 11 Old 12-03-2009, 02:08 PM Thread Starter
missionAvs
missionAvs's Avatar
I have a pulsing vibe that appeared a few months ago and just won't go away. I have read imped's thread and the symptoms seem to be similar to his vibes. For some reason, however, if I turn the OD off then the vibes go completely away which leads me to believe that it is different. Any thoughts as to what I should look at first? I've already checked, and rechecked the pinion angle and CA bushings and all seem to be in good order.
04 Willys Edition TJ Wrangler
missionAvs is offline
post #2 of 11 Old 12-03-2009, 02:14 PM
mdm
Farm Wheeler
Do you have a transfer case drop, MML, or SYE/CV drive shaft?
Remove the rear drive shaft and drive in 4HI to see if the vibration is still there.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #3 of 11 Old 12-03-2009, 04:51 PM Thread Starter
missionAvs
missionAvs's Avatar
No tcase drop but I do have an SYE/CV drive shaft. I'll try removing the drive shaft tomorrow.
post #4 of 11 Old 12-03-2009, 04:59 PM
2006_Sport
Here is your answer
I have the same issue even after a inch t case drop and a 2.5 inch suspension lift. Read posts 13 and 20. It has to do with the Jeeps skid plate and firing order when OD is engaged.
http://www.jeepforum.com/forum/f9/ha...8/#post5970075
2006_Sport is offline
post #5 of 11 Old 12-03-2009, 05:33 PM
Imped
Imped's Avatar
If you have an auto, I'd bet that's it. BTW, I fixed all vibes. Earlier this week, I got the jeep up to 100 (yes, 100) mph on a back road with no wobbles or vibes. It felt rock solid....even with my hands off the steering wheel.
OlllllllO
IndyORV
Imped is offline
post #6 of 11 Old 12-03-2009, 05:36 PM
2006_Sport
You crazy mofo!!!!!!!!!! 100 on 35s Although that's awesome you ditched the vibes man...good job!
post #7 of 11 Old 12-03-2009, 05:44 PM
Imped
Imped's Avatar
I thought you knew. I made a thread about it a while back and was helping people through their vibes. So you can call me the vibe guru..... It was just a loose rear output nut causing the rear output yoke to move ever so slightly. I couldn't move it with my bare hands nor could I tell the nut was loose until I got a wrench on it. I actually went to remove it to replace the rear output seal (killed by the vibes) and when I went to loosen it (preparing to have to hang on the wrench), it instantly loosened with no real effort. So I said AHHHHHHHHHHH!!!!!!! Tightened her to 180 ft lbs, went for a drive and no vibes. And yeah, 100mph was actually quite civilized. Well built jeeps will do just fine at higher speeds.... (besides the single digit mpg's). I usually don't go faster than 65 but decided to see how she would do. No worries safety freaks, I was on a wide open highway with a couple miles of open road late at night.
OlllllllO
IndyORV
Imped is offline
post #8 of 11 Old 12-03-2009, 10:09 PM Thread Starter
missionAvs
missionAvs's Avatar
Here is your answer
Wow sounds exactly like my issue, didn't even think to blame it on the skid plate. O well, guess its time for a new skid . Thanks for the help guys!
post #9 of 11 Old 12-03-2009, 10:10 PM Thread Starter
missionAvs
missionAvs's Avatar
Congrats on fixing your vibes man!!
post #10 of 11 Old 12-03-2009, 10:15 PM
2006_Sport
can you say Rokmen?
I couldnt believe it either. But im glad its that and not something else you know?
post #11 of 11 Old 12-03-2009, 11:01 PM Thread Starter
missionAvs
missionAvs's Avatar
can you say Rokmen?
I hear you man. I have been stumped by these vibes for a little while now and to know that its the skid plate really makes me feel more at ease.
pulsing vibration at 70+ mph sportcoupe TJ Wrangler Technical Forum 60 12-11-2016 10:11 AM
Pulsing vibration at 60+mph BoarderX47 TJ Wrangler Technical Forum 7 11-22-2012 01:27 PM
engine pulsing cosmo_j YJ Wrangler Technical Forum 18 12-29-2009 10:21 AM
94 2.5 engine pulsing? Shawn94 YJ Wrangler Technical Forum 1 08-31-2009 07:57 AM
Steering pulsing rick_chicago YJ Wrangler Technical Forum 2 05-07-2002 07:14 AM
