pulls to left when shifting - JeepForum.com
post #1 of 6 Old 12-15-2010, 12:02 PM Thread Starter
lil420camo
hey guys i noticed a couple of days ago when i shifted it wanted to pull to the left.i didnt think much of it at the time so i left it be.it seems to have gotten worse so im going to climb under it this weekend and see what it is.it seems to maily do it when its cold outside also.
i was wondering if yall have had this problem before and what i should look for.
i know the obvisous like bushings and etc.
its an 05 lj with 45,000 miles and the 6 speed with 4in lift.
any thought or help much appreciated
lil420camo is offline
post #2 of 6 Old 12-15-2010, 12:14 PM
LJ_Cool
2003 WJ
two possible conditions that may cause this...
Right side rear control arms are longer when under no load conditions (bad bushings, adjustment)
Left side (front or rear) brakes are dragging slightly
Best Regards
03 WJ Limited, 04 Overland
LJ_Cool is offline
post #3 of 6 Old 12-15-2010, 03:19 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
I would check your rear trackbar and swaybar.
GOLENJEEPTJ is offline
post #4 of 6 Old 12-15-2010, 03:31 PM
WV-TJ
If you have adjustable control arms, the jam nut could be loose on one or more of them, or they could be incorrectly adjusted. If you don't have adjustables, I would look to see if everything is tight and look closely at the control arm bushings.
WV-TJ is offline
post #5 of 6 Old 12-15-2010, 04:36 PM Thread Starter
lil420camo
thanks for the help.
every thing under the rear seems good but i did notice that my front left motor mount is worn out already.
im thinking this would cause my problem.
am i correct?
post #6 of 6 Old 12-15-2010, 04:55 PM
custom99
Mine was doing the same thing. Found the sway bar link was bad. I replaced both of them and back to normal.
1997 TJ, 2.5, 5 speed, Moog CC623 Caprice springs in the rear, Moog CC782 Zj springs with 2 inch spacer in the front, Monroe gas L/T shocks.
1997 TJ Sport, 4.0, Automatic, Ford Ranger wheels
1992 YJ, 2.5, 5 speed, 3" BL. SOLD
custom99 is offline
Gimme some answers! (pulls to left when braking, pulls to right when off the gas) dz1087 TJ Wrangler Technical Forum 21 03-05-2012 08:21 AM
pulls left? Marn TJ Wrangler Technical Forum 19 05-29-2010 01:46 PM
Pulls right driving pulls left braking aussied97tj TJ Wrangler Technical Forum 1 06-13-2009 09:32 PM
Help (Pulls right when acceleraing, pulls left when braking) 04tjor TJ Wrangler Technical Forum 37 02-19-2009 08:27 PM
pulls to the left RBurg44 TJ Wrangler Technical Forum 25 04-24-2007 02:53 PM
