Puddles In My Jeep - JeepForum.com
post #1 of 13 Old 02-21-2011, 10:31 PM Thread Starter
Prunetuck4X4
Puddles In My Jeep
so i was recently doing a tune up on my jeep (plugs,wires,cap,rotor) and was moving some stuff out of the back seat when i realized two puddles of water behind the passenger and driver seat . It has been raining hard here lately almost everyday last week and i think the weather seal on my jeep is not good anymore. i have a hardtop if it helps. i am pretty sure it is the weather seal from the hard top to the body but i am not 100% sure. any ideas or common problems i can look at before i take on the task of resealing the whole Jeep.
Thanks
Prunetuck4X4 is offline
post #2 of 13 Old 02-21-2011, 10:54 PM
rtiburon
I've got a 97 Sahara w/hard top and soft top and I swap them out now and then. There are two rubber pieces (with metal cores) that fit between the hard top and the body nearest the door latch. They complete the seal, right at the door jam and (at least on mine) they weren't permanently attached to the HT or the body. If you've ever pulled the top off you might have lost one (on mine one would stay on the HT and the other would just fall off). Water can trickle in through there into the rear foot-wells.
Another common leak is from under the cowl on the passenger side (here's a link http://www.jeepforum.com/forum/f9/tj...-fixed-893784/) but you'd notice that on the front passenger carpet.
rtiburon is offline
post #3 of 13 Old 02-21-2011, 10:56 PM
JC_Sahara
I second the seals on the hardtop by the door latches.. I had the same leak, and realized they werent in DOHH!
My Build Thread:
JC_Sahara is offline
post #4 of 13 Old 02-22-2011, 12:04 AM Thread Starter
Prunetuck4X4
thanks please explain more about the first leak you said by the door latches. maybe some pictures because i am not really sure what you are talking about. the farthest the water goes forward is about an inch under my passenger seat. so i do not think it is the weather seal under my hood like you said.
thanks for all the information.
post #5 of 13 Old 02-22-2011, 12:09 AM Thread Starter
Prunetuck4X4
what i mean is the farthest the water goes is about an inch under my seat so i donot think it is the weather seal under my hood. sorry for the confusion.
post #6 of 13 Old 02-22-2011, 12:45 AM
fang_x
i drilled drainage holes in the lowest corners of the tub.
to do this take a hose and fill ur jeep with water, the places where the water accumulates, drill a hole at the lowest point there...
'98 TJ Manual -2.5" rcx long arm on 31
'99 Xj, Stock on 30"
'86 Monte Carlo 357 stroker. 450hp.
fang_x is offline
post #7 of 13 Old 02-22-2011, 01:02 AM
rtiburon
Sorry I don't have my camera handy. Ok, so there are three bolts on both sides that hold down the hard top. The bolts that are closest to the doors on both sides go through the seal pieces I'm talking about. The first time I took the HT off I happened to notice one in the driveway, which was lucky because I was about to run over it. Here's a link to some place that has a picture (no idea who these guys are but they've got a picture of one albeit upside-down) http://www.acmejeepparts.com/products/13022_55.htm. Turns out it's called a mucket?...I guess it's got to be called something.
rtiburon is offline
post #8 of 13 Old 02-22-2011, 01:09 AM Thread Starter
Prunetuck4X4
Fang i am not down to drill holes in my jeep and plus i have carpet so that would be pointles to drill holes if my carpet just sucks it all up. but thanks for the idea.
rtiburon thanks for the information i will have to check this week sometime if i have the "muckets" haha wierd name i agree. no worries about the pictures i have all the info i need and hopefully this solves the problem as it is supposed to rain this weekend.
post #9 of 13 Old 02-22-2011, 07:15 PM
JC_Sahara
Passenger side = http://www.jeep4x4center.com/product...ber=55177256AB
Driver Side = http://www.jeep4x4center.com/product...ber=55177257AB
My Build Thread:
post #10 of 13 Old 02-22-2011, 08:58 PM Thread Starter
Prunetuck4X4
Thank you JCOOTJ
post #11 of 13 Old 02-22-2011, 09:48 PM
Cuder
Someone stole one of those mucket seals off my Jeep. I went to the dealer and payed $40 for one. I now take them off when I take the surrounds off. I use one of the surround bolts to attach the seals to the surrounds through the hole in the seal, so I wont lose them.
My Build Thread:
Cuder is offline
post #12 of 13 Old 02-22-2011, 10:06 PM
JeffB
2006 WK
Haha, that illustrates how different we all are with our Jeeps. I'm one of those that keeps my side windows and back window out full-time. The rain drains out of the holes in my tub. When we had snow in Dallas a few weeks ago (Super Bowl week) it laid about 2" of snow in the back of my Jeep. But only about 1/2 inch of snow settled into in the driver seat so no big deal... brush it out and roll.
JeffB is offline
post #13 of 13 Old 02-25-2011, 01:29 AM Thread Starter
Prunetuck4X4
checked for muckets and it appears i have them.
my weather seal on the hard top does look cracked and not in too good of shape. what do you all think? obviously i should replace it just wondering price on seals and how tough the install will be.
thanks.
water in the jeep after going through puddles?? Dan9 TJ Wrangler Technical Forum 9 08-11-2009 11:55 PM
Puddles in my Jeep dan_yoyo YJ Wrangler Technical Forum 5 07-01-2009 09:58 PM
jeep does not like puddles??? rogernes TJ Wrangler Technical Forum 7 02-10-2009 04:55 PM
Puddles on my floor ballallday89 TJ Wrangler Technical Forum 7 06-01-2008 08:42 PM
So I went through some big puddles... 04WranglerX TJ Wrangler Technical Forum 4 11-04-2007 01:26 PM
