psi for 35 inch tires - JeepForum.com
post #1 of 9 Old 06-25-2010, 11:39 PM Thread Starter
inglisleslie
What do you guys run in your 35 inch tires on the road...28-32psi? I am about to get 35/12.5/15 and do not trust any tire shop. Whats your opinion for on road DD driving for a good balancing. Also how often do you rotate your tires...5k?
inglisleslie is offline
post #2 of 9 Old 06-25-2010, 11:44 PM
Benderff
Benderff's Avatar
Here is some good info thanks to google.
So, answering the question of what is the "correct" tire pressure is not that easy. There are several DIY tests that you can try:
1. The "Business Card Test": On a smooth, hard surface, try inserting a business card between the tire and the pavement. If it goes in less than about 3mm-1/8", the the tire may be under-inflated, if it goes in more than about 6mm-1/4", it may be overinflated.
2. The "Chalk Line Test": Draw a heavy chalk line across all the tread faces. drive slowly forward in a straight line for a few revolutions of the tire. Get out and observe the wear pattern of the chalk. If it has worn away evenly, then the inflation is correct. If either the edge or center of the line is worn first, then the tire is under or over inflated, respectively.
3. The "Water Puddle Test": Similar to test #2, but drive through a puddle of water in a straight line, then get out and observe the wet tire tracks and see if the wet imprint is even, especially as the track starts to dry out after a few revolutions.
4. Heat is the #1 enemy of high-speed tires. The flexing of the tire's sidewalls as the tire rolls under load is the source of the heat. Higher inflation pressures mean less flexing of the sidewall and therefore less heat. Another test for proper inflation pressure is to measure the tire pressure when cold then again after 15 minutes at highway speed. If the pressure rise due to the temperature rise is more than about 3 psi, then the tire may be under-inflated
From here; Technical Information: Wheels and Tires
Benderff is offline
post #3 of 9 Old 06-26-2010, 12:18 AM
Tom Hartz
1967 CJ5
I go by the Chalk test. I have the old BFG Muds they are just over 2 years old with 30,000 plus miles and are 1/2 worn. I have been doing 5 tire rotations every other service (that is 6000 miles) and run 25 psi in all of them.
Tom
Tom Hartz is offline
post #4 of 9 Old 06-26-2010, 12:26 AM Thread Starter
inglisleslie
thanks a bunch guys...great guidelines!
post #5 of 9 Old 06-26-2010, 12:33 AM
BYuen
BYuen's Avatar
I've found 28psi runs great for my heavier set TJ. I rotate my MTRs every 3,000-4,000 miles.
And I'm with ya about not trusting some shops. Once they inflated my tires to 40 psi and the MAX cold psi is 35... Another time I went to a different shop, they tried to convince me I needed to run 35psi in my tires and no less due to safety Stock tire size psi on the door sticker isn't even 35 psi.
BYuen is offline
post #6 of 9 Old 06-26-2010, 01:54 AM
BlueFlame
BlueFlame's Avatar
Those really only work for 'normal' sized tires. Try to get a 35 to wear evenly across the entire face and you'll be down around 10psi...
I have found over many years and many tires that 28 psi works best. Less will yield better tread life but cost more $ in fuel. More just wears out the tires and doesn't increase fuel mileage much.
BlueFlame is offline
post #7 of 9 Old 06-26-2010, 08:28 AM
xjfever
xjfever's Avatar
1995 XJ Cherokee
I run 26 psi in mine.
xjfever is offline
post #8 of 9 Old 06-26-2010, 08:40 AM
tulman22
Very interesting thoughts and views. Been curious also.
US Navy "SPOOK" RETIRED
Impact Orange member # 39
tulman22 is offline
post #9 of 9 Old 06-26-2010, 08:55 AM
robncar
robncar's Avatar
We run 24psi on the street. We've also performed an MPG test with pressures from 20 to 40. The tire pressure did not seem to have an effect on MPG, a heavy brick is a heavy brick.
http://www.jeepforum.com/forum/f9/diy-alignment-kit-steps-w-pics-2264465/
robncar is offline
tire , psi
2 inch lift and 32 inch tires orangetj05 TJ Wrangler Technical Forum 17 07-29-2010 03:51 AM
2 inch spacers on ravines and 30 inch tires wrangler10 TJ Wrangler Technical Forum 4 10-12-2009 10:44 PM
What tires size tires are you running on a 3 inch lift afaletto YJ Wrangler Technical Forum 8 07-01-2009 02:04 PM
33 inch tires on a 4 cyl. junderwood TJ Wrangler Technical Forum 7 11-05-2004 12:21 PM
30 inch tires Mitch TJ Wrangler Technical Forum 4 06-27-2002 01:26 PM
