PSC Tube fender install - JeepForum.com
post #1 of 16 Old 06-23-2005, 05:09 PM Thread Starter
biffstephens
biffstephens's Avatar
I guess I should provide some sort of a write up for these.....I am not good at the step by step things. PSC has instructions for the install and they are pretty step by step....I can and will say that I had no fitment issues of the fenders. Was the install a complete bolt on? No, nor is it sold to be.
I paid 425 for the set....unpainted, and they came with a template to cut your fender as well as a two pages worth of instruction. They are the Poision Spyder Customs Tube Fenders with the flare.
It is a simple concept but in practice it is a little more difficult to implament. They fit pretty good for something welded in another State and shipped UPS in my opinion....Have a few hands around to help massage them in place.....
As you can see they are very strong and I do believe them to be an upgrade to the origional Jeep fenders. If I were to be able to go back and do it again I would do it no questions asked. I might ear mark a little more time to install them but that is about it.
I am very happy with them so far. I need to get them painted of course and I also need to install some flashers but I will leave that for next week.
Biff
Wheel Spacers? Aluminum Fairleads? Winch Rope? LEDS? Winches? Accessories.....
Biff
biffstephens is offline
post #2 of 16 Old 06-23-2005, 05:14 PM
MMagnumPI9
They look good, definatly an upgrade. I have done a fair amount of damage to my fenders and will be doing this soon myself. I am going to be making my own set very similar to that design.
MMagnumPI9 is offline
post #3 of 16 Old 06-23-2005, 05:20 PM Thread Starter
biffstephens
I am sorry I do not......a friend has the pictures I will look through his but I am pretty sure that he does not either.....
Sorry again,
Biff
PS Thanks!
Biff
post #4 of 16 Old 06-23-2005, 05:36 PM
red99tj
red99tj's Avatar
so no problems with them fitting?, ive heard lots of stories of them not fitting correctly...but then again those were just stories
Frank
red99tj is offline
post #5 of 16 Old 06-23-2005, 05:38 PM
got4-Lo
what are u gonna do about turn signals?
stretched *** tj
got4-Lo is offline
post #6 of 16 Old 06-23-2005, 05:47 PM Thread Starter
biffstephens
As far as fitting.....they fit.....I had to cut and grind and bend some thing (I have to grind about an inch off of the Battery tray to get the inside tube to fit.
So were they grossly out of wack? No...as you can see I think they fit pretty good. I think there were some problems....I can understand that. At least in my case they fit fine....
In fact I have a few welder friends look at them and they were all very impressed at what the welds and tubing looked like. It is a very nice product....
Again....it is not a bolt on type of Mod.....it was not easy but it was worth it in my opinion....
Biff
Biff
post #7 of 16 Old 06-23-2005, 05:53 PM
TXST8tj
TXST8tj's Avatar
did you have to wait very long to get them?
after my accident in January i wanted to get those but they were on backorder until April they said. i obviously couldn't wait that long cause i needed a new front end. those look awesome though.
Patrick
TXST8tj is offline
post #8 of 16 Old 06-23-2005, 05:57 PM Thread Starter
biffstephens
I did have to wait a while for them...in fact I have 2 PSC things and I had to wait a while for both of them....
Biff
Biff
post #9 of 16 Old 06-24-2005, 08:13 PM
Testykalz
You finally got em! They look sweet. Where are you gonna put your turn signals at? I wanna flat fender too, but I am afraid if I dont put a tube fender on it'll look like crap. lol I don't care to have to take the grill out and put some there even though it is a good spot.
Anyways, I finally made it up there and got Tolly to regear the jeep. His RTI ramp had some sharp metal sticking up and gashed my sidewall pretty good when I was backing out of his garage. So those 35's will be coming sooner!
Curious, what else did you order from PSC?? lol
Testykalz is offline
post #10 of 16 Old 06-25-2005, 08:10 PM Thread Starter
biffstephens
I have the PSC trail cage as well....very happy with it to....
All in all they make good products. I would not worry one bit buying from them again.....
Biff
Biff
post #11 of 16 Old 06-25-2005, 11:22 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Well, how about something other than stories? I have a set, and two friends have sets of them and none of the three fit worth a crap. Hopefully they are no longer using a jeep that has been jumped off a dune and bent frame up in the front to mock them up on. All of ours when bolted up to the firewall were minimum 3" too high on the grill bolts. When I ratchet strapped mine down to get the bolts in and released the straps, it pulled the grill up against the front rubber mount so tightly that the fan rubbed on the shroud.
mrblaine is online now
post #12 of 16 Old 06-26-2005, 02:50 AM
jeep jake
do you have more clearence up in front
jeep jake is offline
post #13 of 16 Old 06-26-2005, 09:35 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
If you mean clearance for the tires to stuff, No, they actually limit uptravel. I lost about an inch or so.
post #14 of 16 Old 06-26-2005, 09:44 AM
StealthTJ
I've installed one set (mine) and helped install another set and both fit (on didn't fit) as Blaine described. Crappy....
Fred
Base - '98 Sahara, 4.0L 6 cyl, Auto (swap from 5 sp)
Suspension- 4.0" Procomp Springs + 1 1/4" bl. Rear tri-link. Currie J arms, F&R. Warn hubs with WJ knuckles, custom cross over/hi-steering setup, Currie A/R Sway Bar.
HPD30/D44 (rear disk conversion, WJ dual piston caliber conversion in the front); Detroits; 4.56
Misc - Tera 2wd lo.
Tires - 35x12.50 MT/R's siped on 15x7 Champion Beadlocks.
Recovery - Warn XD9000i
StealthTJ is offline
post #15 of 16 Old 06-26-2005, 11:11 AM Thread Starter
biffstephens
I didn't have clearance problems before the install and don't now. I didn't have any fitting problems with mine and I have a friend the has some as well and there were no fitting issues with his either.....
I don't think it really adds more room for you tires, I took some measurements before and after so I feel pretty good about this statement. What it does do is it puts a fender there that your tire can hit and not bend. The stock fenders as you know will bend and flex if you dont have clearance........the correct answer would to get enough clearance....not go buy tube fenders....
I like mine.....I would still do it again....
Sorry to the others that had problems.....
Biff
Biff
Gen-Right Hi-Fender kit (tube fender & high line combo) john NC TJ Wrangler Technical Forum 47 04-01-2011 01:18 PM
Tube fender/flat fender options thread... BlueJeepRME TJ Wrangler Technical Forum 10 04-15-2009 01:00 AM
River Raider tube fender install ? for JK ge2 JK Wrangler Technical Forum 0 10-17-2008 04:20 PM
Tube fender install. Relocate inner fender items where? Killedbybob TJ Wrangler Technical Forum 3 07-29-2008 03:50 PM
TNT Customs - Have pictures of your Tube Fender Install? SomerJeep TJ Wrangler Technical Forum 0 03-31-2007 09:36 AM
