Prothane progressive coil spring inserts write up - Page 4 - JeepForum.com
post #46 of 167 Old 05-07-2011, 07:21 PM
mJUSTINm
They're fine when crawling, don't even notice them. Just gotta make sure that they're the proper length.
-Justin
mJUSTINm is offline
post #47 of 167 Old 07-24-2011, 08:24 PM
mxtrails
Took the jeep to Silver Lake sand dunes on the west side of Michigan this weekend. Gave me a lot of time to test these prothane's. So far I still only have them in the front but what a difference! Landings are so smooth. I never thought I could get my jeep to hang with prerunners in whoops!
http://youtu.be/cr0gdoNldkM
Some guy snapped this one on his cell phone and sent to to me so the quality is pretty bad.
http://youtu.be/gmAGOYTJIeQ
sorry for the links, the embedded code wasn't working.
03 Rubicon, highlined rear fenders, RC long arm upgrade, 4" RC springs, OME shocks, 35" mt's, UCF lopro trans mount, UCF 2" deep skid, nates 4x4 rear bumper/tire carrier, 2" jks bumpstops, jks discos, RK frt track bar, tom woods cv. rebuild pics: http://s61.photobucket.com/albums/h57/mxtrails/Jeep/
mxtrails is offline
post #48 of 167 Old 07-24-2011, 08:38 PM
TJdualsport
niiiiiice!!! so when are you coming to so cal to play in the mojave with us???
TJdualsport is offline
post #49 of 167 Old 07-24-2011, 09:17 PM Thread Starter
chmo
cool they worked out for you as well
as mentioned before I have them front and rear now ... and now the scary stuff gets even more scary ... because FAAAASTER
and thanks for the feedback
"The more I know, the more I realize how much I don't know"
chmo is offline
post #50 of 167 Old 09-06-2011, 04:08 PM
mxtrails
Finally got a chance to install the rear prothanes this weekend. I decided to try the post mount idea. Here's a few photos of the install. I haven't had a chance to test it yet though.
I found some threaded rod that fit tight inside the insert to keep it secured to the axle.
The prothane was a very tight fit to get inside my 4" rough country coils. Lube was needed. I even extended the spring with a strut compressor to make more room.
Here it is installed with the suspension at full extension.
My flex did suffer after the install but some more testing will determine if they really are hindering my rock crawling ability. The rear tire used to tuck under the flare a little.
mxtrails is offline
post #51 of 167 Old 09-06-2011, 04:52 PM
mJUSTINm
Right on! We still haven't touched my rears. I'd like to do this and relocate the upper spring perch at the same time.
-Justin
mJUSTINm is offline
post #52 of 167 Old 09-06-2011, 07:02 PM
mxtrails
I'd also like to relocate my perch along with outboarding the shocks however, with the old man emu shock valving, and these bumps, it handles pretty darn good already!
mxtrails is offline
post #53 of 167 Old 09-06-2011, 09:09 PM
sduncan
sduncan's Avatar
Ok...you guys have got my attention. I like the slow trails but really enjoy playing in the dunes when I get a chance. I have already re located my rear coils and would like to try something to improve the suspension when hitting the whoops and on bigger hits. This looks like it might work until I can spring for my COs in the future. I have the RE 4.5 LA. What would you say would be the best lengths to start with? I know some trial and error will be needed but I'm looking for a starting point. For instance... a set of 4 "rings" for the front and 3s for the back, order the longest they have (10s I think) and cut to trim, or something else? I like the rear "mounts" that mxtrails did. I may try something similar.
Thanks for any input.
'98 TJ, 5.7 HEMI,
sduncan is offline
post #54 of 167 Old 09-06-2011, 10:18 PM
TJdualsport
love it, as long as your shocks arnt bottomed out you can cut a little more off to get more flex. or drill some holes in the prothane to soften em up a little
post #55 of 167 Old 09-07-2011, 05:02 AM
mxtrails
I bought a pair of 8 rib prothanes and cut them into 3 ribs for the front (also using the stock bump stop) and 5 rib in the rear (removed the stock bump stop and installed a spring retainer plate). There definitely was a lot of suspension cycling and measuring done before i settled on length of the prothanes. I still need to do something in the front but the rear, i used the prothane mount post as a solid stop just before my shocks bottom in the rear. i have at least 3 inches of progressive bump stop before that point. In theory the prothane stops compressing right around the point where the post will contact the upper plate. we'll see how it works out in real life.
Here's a photo of the prothane size vs the mount size.
mxtrails is offline
post #56 of 167 Old 09-07-2011, 12:34 PM
mJUSTINm
My rear end bottoms out a lot with my 4" springs and Bilstein 5100s, and that's with a relatively light rear end (no tire carrier or back seat, spare in the tub.) It's like the front floats over everything, and the rear just slams into it. Win tjdualsport relocated his rear springs he said it helped a lot with bottoming out.
-Justin
mJUSTINm is offline
post #57 of 167 Old 09-07-2011, 02:42 PM
TJdualsport
yup, taking the arc out of the rear coils really helped. i really wanna throw some prothanes in the back asap.
post #58 of 167 Old 09-07-2011, 05:36 PM
mJUSTINm
We need to stop talking about it and get to work!
-Justin
mJUSTINm is offline
post #59 of 167 Old 09-07-2011, 08:31 PM
mxtrails
I have another dunes trip planned in the next month sometime. Can't wait to try them out. I'll be sure to get a better video this time too.
mxtrails is offline
post #60 of 167 Old 09-07-2011, 09:06 PM
EricsGreen98Tj
sub. this is a really interesting idea.
Building my junk with more junk, so Im always on the look out for more junk....Free to cheap preferably. :D
My junk http://www.jeepforum.com/forum/f22/survivor-project-driveway-frame-swap-33s-build-1280626/index3.html
EricsGreen98Tj is offline
Rough Country 2.5" Progressive Spring Kit 01-TJ TJ Wrangler Technical Forum 28 01-17-2011 06:44 PM
Polyurethane Coil Spring Pads by Prothane undercoverfab TJ Wrangler Technical Forum 0 02-13-2010 12:02 PM
New Rough Country 2.5 Progressive rate Spring Lift and 1.25 Body Lift qf4phlyer JK Wrangler Technical Forum 7 11-24-2008 06:59 PM
ZJ spring install write up badoosh27 TJ Wrangler Technical Forum 11 10-30-2007 07:06 PM
Prothane Coil Spacers (97 TJ) rdiller TJ Wrangler Technical Forum 1 09-02-2003 08:19 PM
