Protect the 42RLE oil Pan with options - JeepForum.com
post #1 of 4 Old 07-20-2016, 02:26 PM Thread Starter
grininmonkey
Meat Popsicle Stick
grininmonkey's Avatar
My factory transmission skid has two problems.
1: Its not on the Jeep due to the need to cut driver side bolt because the frame nutsert spun out.
2: Front drive shaft will rub against the cross member now and limit driver side articulation, tested articulation during fender install process with the trans-skid clamped in place. (due to this, I decided not to waste time and effort in fixing the spun nutsert)
I still have factory t-case skid (aka the shovel) for the time being and would like to look for a skid I could possible use with the factory skid and also a non factory skid when I can move forward on TT.
I believe I found one maybe two, but not 100% sure, so thought I would pop this question on the forum just in case it turns out that you can likely do what I am talking about with most of them? It's just not advertised or mentioned ?
Thoughts suggestions?
I am not tackling rock ledges and boulders just yet so I maybe overly nervous about it... who knows.
grininmonkey is offline
post #2 of 4 Old 07-20-2016, 02:47 PM
Ironhead
both Savvy and UCF skids can be used with the oem shovel or an aftermarket skid
Ironhead is offline
post #3 of 4 Old 07-20-2016, 03:04 PM Thread Starter
grininmonkey
Meat Popsicle Stick
This was what I was eye-balling... but not sure if it would work with factory shovel...
http://undercoverfab.com/aluminum-en...id-plate-.html
post #4 of 4 Old 07-20-2016, 03:09 PM
Ironhead
yep, it sure will, you'll have to drill 4 holes, but thats all
Ironhead is offline
