Proper touch-up paint preparation? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Proper touch-up paint preparation?
8.8 Swap Kit w/ TRUSS for JeepsROCK BOTTOM prices on LIFT KITS at Rockridge4wd!! WANT TO Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 03-23-2015, 02:09 AM   #1
T-Jay
T-Jay's Avatar
I have this:
But I can't seem to get it to spray on even. The second it hits the surface it seems to blotch up into little puddles. Anybody know how to get an even coat with this stuff? I scuffed the existing paint lightly with a scotch bright pad until the shine was gone, then I sprayed. But I don't know much about body work. It's just a little can and I'd hate to waist it experimenting.
T-Jay is offline   Reply With Quote Quick reply to this message
Unread 03-23-2015, 02:23 AM   #2
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
That's often called fish eye or orange peel.
After prepping the surface for paint, wipe it down with lacquer thinner... IMO
TSB Information: http://www.automd.com/tsb/jeep_m/wrangler_mm/2000_y/
Knuckelhead is offline   Reply With Quote Quick reply to this message
Unread 03-23-2015, 02:29 AM   #3
T-Jay
T-Jay's Avatar
Ahhh. Thanks!
Unread 03-23-2015, 02:57 AM   #4
Jeepsr4me
Lots of folks just start sanding or using a abrasive to work the area, But fail to CLEAN the surface 1st..
Then you grind in all that wax and oil and bird poop and acid rain. Paint will never work right.. Unless its over spray then it stick like glue and never wipe off.
Clean then clean again then clean again.. May even have to use thinner on the abrasives so as to get all that you ground in off.
Lacquer paint is different than enamel it required wet sanding afterward........ that is just going on memory... I hate body work and really dont do it. Had a car that had cracking in paint over the whole car and I waxed over it many many many times trying to get all those cracks out... Then I wanted to repaint... I never got the wax off... 8 home paint jobs later I learned a hard lesson. Clean FIRST. I had to take that car to the metal. and then clean it....
Jeepsr4me is offline   Reply With Quote Quick reply to this message
Unread 03-23-2015, 03:23 AM   #5
T-Jay
T-Jay's Avatar
Originally Posted by Jeepsr4me
Lots of folks just start sanding or using a abrasive to work the area, But fail to CLEAN the surface 1st.. Then you grind in all that wax and oil and bird poop and acid rain. Paint will never work right.. Unless its over spray then it stick like glue and never wipe off. Clean then clean again then clean again.. May even have to use thinner on the abrasives so as to get all that you ground in off. Lacquer paint is different than enamel it required wet sanding afterward........ that is just going on memory... I hate body work and really dont do it. Had a car that had cracking in paint over the whole car and I waxed over it many many many times trying to get all those cracks out... Then I wanted to repaint... I never got the wax off... 8 home paint jobs later I learned a hard lesson. Clean FIRST. I had to take that car to the metal. and then clean it....
Yikes! Ok Gotcha. Thanks.
Unread 03-23-2015, 03:29 AM   #6
Jeepsr4me
I could peel sheets of it off... It would take a day or so before it started.... I almost just took it to a dealer and traded it in during the window of no peel... Every inch would peel off... I loved that car too...
Unread 03-23-2015, 05:53 AM   #7
jeepinhokie
jeepinhokie's Avatar
Originally Posted by T-Jay View Post
I have this:
I used the same thing on a test panel. took a couple of coats to even out, but that blotchyness you are talking about goes away after a few coats.
color was quite a fair bit off for me though.
jeepinhokie is offline   Reply With Quote Quick reply to this message
Unread 03-24-2015, 09:11 PM   #8
T-Jay
T-Jay's Avatar
Originally Posted by jeepinhokie
I used the same thing on a test panel. took a couple of coats to even out, but that blotchyness you are talking about goes away after a few coats. color was quite a fair bit off for me though.
Hmm. It didn't match? Are you sure the paint code was right? I ask because I know there are two very similar silvers that I had to pic from. I think one (mine) was slightly more metallic than the other. Thanks for the tip on the blotches.
Unread 03-25-2015, 04:45 AM   #9
jeepinhokie
Yup I'm sure. PBT. Patriot Blue Pearl.
Unread 03-25-2015, 10:06 AM   #10
T-Jay
T-Jay's Avatar
well that sucks... I hope mine is a match.
Unread 03-25-2015, 12:13 PM   #11
Tonellin
It's hard to match something that comes from a can to something that came painted over a decade ago professionally and then sat exposed to the elements. Best you can hope for is getting close, it's obviously a lot easier with some colors...good luck!
06 LJ Rubicon
http://www.jeepforum.com/forum/f22/lj-rubicon-build-1481013/
Tonellin is offline   Reply With Quote Quick reply to this message
Unread 03-25-2015, 01:00 PM   #12
jeepinhokie
make sure to do a test panel before painting anything important.
